Ethernet_Manager_STM32 for STM32 Credentials Management. Now supports LAN8720
Posted: Wed Dec 23, 2020 7:37 pm
Ethernet_Manager_STM32 Library
Why do we need this Ethernet_Manager_STM32 Library
- This is the new library, adding to the current WiFiManager sets of libraries. It's designed to help you eliminate hardcoding your Credentials in STM32F/L/H/G/WB/MP1 boards using Ethernet shields (W5100, W5200, W5500, ENC28J60, built-in LAN8742A Ethernet). It's currently not supporting SSL. Will support soon.
- You can update Credentials any time you need to change via Configure Portal. Data are saved in configurable locations in EEPROM.
- DoubleDetectDetector feature to force Config Portal when double reset is detected within predetermined time, default 10s.
- Configurable Config Portal Title to be either BoardName or default undistinguishable names.
- Examples are redesigned to separate Credentials / Defines / Dynamic Params / Code so that you can change Credentials / Dynamic Params quickly for each device. Example MQTT_ThingStream_Ethernet_STM32 will demonstrate how to use the dynamic parameters, entered via Config Portal, to connect to ThingStream MQTT Server at mqtt.thingstream.io.
New recent features:
Releases v1.0.0
1. Initial coding to support STM32F/L/H/G/WB/MP1.
2. Provide support to W5x00, ENC28J60 and built-in LAN8742A Ethernet.
3. Supporting Ethernet, EthernetLarge, Ethernet2, Ethernet3, EthernetENC, UIPEthernet and STM32Ethernet Libraries
Currently Supported Boards
1. STM32 boards with built-in Ethernet LAN8742A such as :
- Nucleo-144 (F429ZI, F767ZI)
- All STM32 boards (STM32F/L/H/G/WB/MP1) with 32K+ Flash, with Built-in Ethernet
2. STM32F/L/H/G/WB/MP1 boards (with 32+K Flash) running W5x00 or ENC28J60 shields)
- Nucleo-144
- Nucleo-64
- Discovery
- Generic STM32F0, STM32F1, STM32F2, STM32F3, STM32F4, STM32F7 (with 64+K Flash): x8 and up
- STM32L0, STM32L1, STM32L4
- STM32G0, STM32G4
- STM32H7
- STM32WB
- STM32MP1
- LoRa boards
- 3-D printer boards
- Generic Flight Controllers
- Midatronics boards
Currently Supported Ethernet shields/modules
1. Built-in LAN8742A Ethernet using STM32Ethernet library v1.2.0+ and LwIP library v2.1.2+
2. W5x00 using Ethernet, EthernetLarge, Ethernet2 or Ethernet3 library
3. ENC28J60 using EthernetENC or UIPEthernet library
Examples:
1. AM2315_Ethernet_STM32
2. DHT11_Ethernet_STM32
3. Ethernet_STM32
4. MQTT_ThingStream_Ethernet_STM32
Releases v1.0.0
- Nucleo-144
- Nucleo-64
- Discovery
- STM32G0, STM32G4
- STM32H7
- STM32WB
- STM32MP1
- LoRa boards
Examples:
3. Ethernet_STM32
