Interrupt FALLING not working as excepted
Posted: Sat Jan 16, 2021 11:58 pm
by leouz
Hello all,
I'm programming a stm32F103C6 with platformio
I'm being mad with this script.
i have setup 2 interrupt pins, one to rise the variable "start" value and one to decrease it.
then the a pwm pin will be set with the "start" value.
The problem rise when I change the logic from RAISING to FALLING.
because the Interrupt don't trigger only when the pin change state from HIGH to LOW , but also from LOW to HIGH
in fact the result are the same as CHANGE
anyone excepted the same behaviour?
here my code
#include <Arduino.h>
#define PWM PA6   //T3
#define INDIETRO PB10  //T4
#define AVANTI PB9  //T2  sono stati invertiti
#define period 1000
int start = 0;
unsigned long tempo = 0;
void newstep (){
  start++;
void newstep_i (){
  start--;
 attachInterrupt(digitalPinToInterrupt(AVANTI),newstep,FALLING);
 attachInterrupt(digitalPinToInterrupt(INDIETRO),newstep_i,FALLING);
 pinMode(PWM,OUTPUT);
 digitalWrite(PWM, LOW);
 pinMode(AVANTI,INPUT_PULLUP);
 pinMode(INDIETRO,INPUT_PULLUP);
 Serial.println("Ready 1.1.4");
  if (start > 255 )start = 255;
    else if (start < 0) start = 0;
analogWrite(PWM, start);
if (millis()>= tempo + period){
  tempo += period;
  Serial.println(start);
Re: Interrupt FALLING not working as excepted
Posted: Sun Jan 17, 2021 8:57 am
by stevestrong
If you use mechanical switches /pushbuttons then the behavior is normal, becase they cause spuorious transitions low->high->low... when activating them.
You have to debounce those inputs.
Posted: Sun Jan 17, 2021 10:24 am
by leouz
I'm not using a mechanical switches, I'm using a second board to generate the signal.
the fact is if i set the RISING logic it work as excepted.
Posted: Fri Jan 22, 2021 12:12 pm
by leouz
No one have encountered problem with the FALLING logic?
Posted: Fri Jan 22, 2021 1:48 pm
I've tested this sketch on my BP:
const byte ledPin = LED_BUILTIN;
const byte interruptPin = PA6;
volatile byte state = LOW;
  pinMode(ledPin, OUTPUT);
  pinMode(interruptPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin), blink, FALLING);
  // Instantiate HardwareTimer object. Thanks to 'new' instantiation, HardwareTimer is not destructed when setup() function is finished.
  HardwareTimer *MyTim = new HardwareTimer(TIM2);
  // Configure and start PWM
  MyTim->setPWM(1, PA0, 100, 50); // 100 Hertz, 50% dutycycle
  digitalWrite(ledPin, state);
void blink() {
  state = !state;
And there is no issue with FALLING, channel 0 is the PWM and 1 the LED:
Of course, I've tested RISING and CHANGE and result is as expected.
I think a potential issue in your sketch is that the start should be volatile.
