STM32 - detachInterrupt and deepSleep
Beuzekom
Post by Beuzekom »
Working on STM32 project in which I have an external sensor with interrupt (PA11).
When in deepsleep I am looking at 2 different ways to wake up.
  • (1) Sensor wakes up the MCU thru an interrupt
  • (2) MCU wakes up "itself" due to timer that runs out (e.g. lp.deepsleep(60000))
    In this case the MCU should never wake up from the external sensor interrupt (PA11)
The 1st scenario works fine and MCU wakes up from deepsleep due to interrupt from sensors.
For the second scenario I had the idea to use detachInterrupt() and go to sleep and wait for the timer to expire.
However the following is happening:
  • After powerup it goes to sleep and wakes up after 1 minutes, goes to sleep, wakes up etc etc -> no problem.
    But when triggering the sensor (motion) the MCU wakes up and not able to sleep again
Code snapshots below
STM32LowPower lp;
lp.attachInterruptWakeup(PA11, wakeUpNow, LOW, DEEP_SLEEP_MODE);
void sleepLight2(bool useIntFromSensor)
  if (useIntFromSensor == true)
    interruptFlagMotion = false;
  else
  { // Disable the interrupt from sensor
    detachInterrupt(PA11);
    __DSB();
    __ISB();
  // ***** Deepsleep
  lp.deepSleep( 60000 );                                              // deepsleep 1 minute
} // end of sleepLight2
Any suggestions why this is happening and what I am doing wrong?
Thanks!
Answers: 109
Re: STM32 - detachInterrupt and deepSleep
Maybe you have a pending interrupt.
You probably needs to clear it.
You can have a look on this:
https://github.com/stm32duino/Arduino_C ... /pull/1258
How do you manage the call of:
Beuzekom
Post by Beuzekom »
Thanks for the feedback.
Clearing potential pending interrupt might be the cause. Will have a look at it.
For the 328p processor I cleared the INTs by setting the following (but of course obsoleted for the STM32):
//  Atmega 328P (obsoleted)
//  EIFR = bit (INTF0);                                               // clear flag for interrupt 0 (D2)
//  EIFR = bit (INTF1);                                               // clear flag for interrupt 1 (D3)
For the current stmduino version it seems it is still in development(?). Will give it a try and implement it. Post results later on.
The function
is called from the mail loop. It should remain there till the sleep is finished (timeout or thru a sensor int)
Beuzekom
Post by Beuzekom »
Implemented the clearPendingInterrupt() (see below). It is going to sleep now but the interrupt is not detached (as in deepSleep the MCU wakes up from the sensor INT).
  #ifdef DEBUG
    Serial.print(F("sleepLight:     Int on (1) or off (0):  "));
    Serial.println( useIntFromSensor );
    Serial.flush();
  else
    clearPendingInterrupt(PA11);
    __DSB();
    __ISB();
  // ***** Deepsleep
Any ideas?
Beuzekom
Post by Beuzekom »
Was not able to solve it and decided to switch off (power down thru MCU) the sensor instead of using the detachInterrupt().
Still looking for the solution and detach the Interrupt.
mlundin
Post by mlundin »
Looking at the source code in the Low Power library:
https://github.com/stm32duino/STM32LowPower
void STM32LowPower::attachInterruptWakeup(uint32_t pin, voidFuncPtrVoid callback, uint32_t mode, LP_Mode LowPowerMode)
this function does two things, it attaches the pin interrupt and it enables the pin wakeup function
LowPower_EnableWakeUpPin(uint32_t pin, uint32_t mode);
This one in turn calls the HAL function
HAL_PWR_EnableWakeUpPin(wkup_pin);
So when the interrupt is detached it seems the pin wakeup functionality is still active, but there is no interrupt callback.
The solution might be to call the
HAL_PWR_DisableWakeUpPin(wkup_pin);
This is just from reading the code, I have not done any tests
Beuzekom
Post by Beuzekom »
Thanks for the suggestion / going to test it tonight and share the results.
Jacobjsdhfg
Post by Jacobjsdhfg »
Beuzekom wrote: Tue Feb 16, 2021 7:26 am Thanks for the suggestion / going to test it tonight and share the results.Drive Mad 2
I look forward to hearing about your test results.
TerrellDarrough
Post by TerrellDarrough »
Jacobjsdhfg wrote: Thu Nov 23, 2023 7:02 am
Publish the results and have a look
