Netduino Plus 2 board + BME280
jarwil
Post by jarwil »
Hi all.
Recently I successfully got ethernet running on a Netduino Plus 2.
Thread from: viewtopic.php?t=1771
Now I have a problem with libraries for temperature sensors. I am trying to read the temperature from DHT22 and BME280, unfortunately without success, none of the libraries work. Could it be a problem with configuring the clock settings?
I would like to add that I tested the libraries for the above-mentioned sensors on the STM32F4-Discovery board, Leonardo and also on BluePill. Everything works on these boards.
Can anyone verify that the settings I used are correct for Netduino Plus 2?
	/**Configure the main internal regulator output voltage
	__HAL_RCC_PWR_CLK_ENABLE();
	/**Initializes the CPU, AHB and APB busses clocks
	RCC_OscInitStruct.PLL.PLLM = 25;
	RCC_OscInitStruct.PLL.PLLN = 336;
		Error_Handler();
	RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
	if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK) {
		Error_Handler();
	/* Ensure CCM RAM clock is enabled */
	__HAL_RCC_CCMDATARAMEN_CLK_ENABLE();
	//clock setup
	//SystemClock_Config(); (extern)
	//PA8 as clock for enc28J60
	HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSE, RCC_MCODIV_1);
	//PB4 as MISO
	SPI.setMISO(PB4);
	//PC8 as chip sellect
	Ethernet.init(PC8);
	//start ethernet
	Ethernet.begin(mac, Eth_ModuleIP);
Also I changed the definition of HSE_VALUE in file stm32f4xx_hal_conf_default.h to 25000000.
economicair
Re: Netduino Plus 2 board + BME280
Post by economicair »
jarwil wrote: Thu Dec 15, 2022 6:37 pm Hi all.
Thread from: viewtopic.php?t=1771phrazle
		Error_Handler();
		Error_Handler();
	//clock setup
	//PB4 as MISO
	SPI.setMISO(PB4);
	Ethernet.init(PC8);
	//start ethernet
Okay, so now I'm having trouble with temperature sensor library issues. I've tried using several libraries to read the temperature from DHT22 and BME280, but to no avail. It can be time zone issues.
jarwil
Post by jarwil »
What do you mean the problem could be with the timezone? What can I do or check in this case?
ozcar
Answers: 5
Post by ozcar »
jarwil wrote: Wed Jan 04, 2023 4:29 pm What do you mean the problem could be with the timezone? What can I do or check in this case?
I never tried to get a Netduino, or any custom board to work, and I can't say if what you tried is correct, but it is hard to see why a sensor library would stop working altogether because some time zone was incorrect.
Certainly such libraries could have trouble if basic time-related functions like delay(), millis() and micros() are not working correctly. Some libraries may also use the defined value for F_CPU to calculate something, but I'm not sure if anything at all could work correctly if that was wrong. In your other thread you mentioned trouble with millis() and micros(), but it is not clear to me if you still have that problem after you tried to change the HSE_VALUE.
If those time-related functions are working correctly, I think you would need to be a bit more specific about exactly what library you are trying to use, how the sensor is attached (particularly for something like BME280 where there is a choice), and in what way it does not work.
jarwil
Post by jarwil »
One of Murphy's laws says:
It works better if you plug it in.
What I wanted to do, I have already done on BluePill and a separate ENC28J60. The netduino board was already intended for the archive box.
Thanks to your answer, I gave Netduino another chance :)
This time I decided to check HW.
What was my surprise when I saw that where there should be 5V there was 0V. The sensors I tested had no power.
A quick glance at the diagram and everything became clear :)
Now it work perfectly.
Also the ethernet works well.
Thank You!
