[STM32F1] ADC_AnalogWatchdog example
Answers: 91
Hi all,
I've converted an example from STM32F1Cube to Arduino sketch using the STM32 Core.
The Cube example is the ADC_AnalogWatchdog which use several feature ADC, DMA, watchdog for the Nucleo F103RB.
It is available here:
https://github.com/STMicroelectronics/S ... ogWatchdog
To achieve this I simply disable the HAL ADC usage by the arduino API by defining -DHAL_ADC_MODULE_ONLY in build_opt.h file.
Then I mainly copy all required code and prefixed functions by extern "C" .
For some GPIO config and write, I've used the standard API.
Main has been splitted in the setup() and loop() of the sketch.
/* Private define ------------------------------------------------------------*/
#define ADCCONVERTEDVALUES_BUFFER_SIZE ((uint32_t) 256)     /* Size of array containing ADC converted values */
#define RANGE_12BITS                   ((uint32_t) 4095)    /* Max value with a full range of 12 bits */
/* Private variables ---------------------------------------------------------*/
/* ADC handler declaration */
ADC_HandleTypeDef    AdcHandle;
/* Variable containing ADC conversions results */
__IO uint16_t   aADCxConvertedValues[ADCCONVERTEDVALUES_BUFFER_SIZE];
/* Variable to report ADC analog watchdog status:   */
/*   RESET <=> voltage into AWD window   */
/*   SET   <=> voltage out of AWD window */
uint8_t         ubAnalogWatchdogStatus = RESET;  /* Set into analog watchdog interrupt callback */
    @brief  This function handles ADC interrupt request.
    @param  None
    @retval None
extern "C" void ADC1_2_IRQHandler(void)
  HAL_ADC_IRQHandler(&AdcHandle);
  @brief  This function handles DMA interrupt request.
  @param  None
  @retval None
extern "C" void DMA1_Channel1_IRQHandler(void)
  HAL_DMA_IRQHandler(AdcHandle.DMA_Handle);
    @brief ADC MSP initialization
           This function configures the hardware resources used in this example:
             - Enable clock of ADC peripheral
             - Configure the GPIO associated to the peripheral channels
             - Configure the DMA associated to the peripheral
             - Configure the NVIC associated to the peripheral interruptions
    @param hadc: ADC handle pointer
    @retval None
extern "C" void HAL_ADC_MspInit(ADC_HandleTypeDef *hadc)
  GPIO_InitTypeDef          GPIO_InitStruct;
  static DMA_HandleTypeDef  DmaHandle;
  RCC_PeriphCLKInitTypeDef  PeriphClkInit;
  /*##-1- Enable peripherals and GPIO Clocks #################################*/
  /* Enable clock of GPIO associated to the peripheral channels */
  //  __HAL_RCC_GPIOA_CLK_ENABLE();
  /* Enable clock of ADCx peripheral */
  __HAL_RCC_ADC1_CLK_ENABLE();
  /* Configure ADCx clock prescaler */
  /* Caution: On STM32F1, ADC clock frequency max is 14MHz (refer to device   */
  /*          datasheet).                                                     */
  /*          Therefore, ADC clock prescaler must be configured in function   */
  /*          of ADC clock source frequency to remain below this maximum      */
  /*          frequency.                                                      */
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC;
  PeriphClkInit.AdcClockSelection = RCC_ADCPCLK2_DIV6;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
  /* Enable clock of DMA associated to the peripheral */
  __HAL_RCC_DMA1_CLK_ENABLE();
  /*##-2- Configure peripheral GPIO ##########################################*/
  /* Configure GPIO pin of the selected ADC channel */
  GPIO_InitStruct.Pin = ADC_CHANNEL_4;
  GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
  GPIO_InitStruct.Pull = GPIO_PIN_4;
  /*##-3- Configure the DMA ##################################################*/
  /* Configure DMA parameters */
  DmaHandle.Instance = DMA1_Channel1;
  DmaHandle.Init.Direction           = DMA_PERIPH_TO_MEMORY;
  DmaHandle.Init.PeriphInc           = DMA_PINC_DISABLE;
  DmaHandle.Init.MemInc              = DMA_MINC_ENABLE;
  DmaHandle.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;   /* Transfer from ADC by half-word to match with ADC configuration: ADC resolution 10 or 12 bits */
  DmaHandle.Init.MemDataAlignment    = DMA_MDATAALIGN_HALFWORD;   /* Transfer to memory by half-word to match with buffer variable type: half-word */
  DmaHandle.Init.Mode                = DMA_CIRCULAR;              /* DMA in circular mode to match with ADC configuration: DMA continuous requests */
  DmaHandle.Init.Priority            = DMA_PRIORITY_HIGH;
  /* Deinitialize  & Initialize the DMA for new transfer */
  HAL_DMA_DeInit(&DmaHandle);
  HAL_DMA_Init(&DmaHandle);
  /* Associate the initialized DMA handle to the ADC handle */
  __HAL_LINKDMA(hadc, DMA_Handle, DmaHandle);
  /*##-4- Configure the NVIC #################################################*/
  /* NVIC configuration for DMA interrupt (transfer completion or error) */
  /* Priority: high-priority */
  HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 1, 0);
  HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
  /* NVIC configuration for ADC interrupt */
  HAL_NVIC_SetPriority(ADC1_2_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(ADC1_2_IRQn);
    @brief ADC MSP de-initialization
           This function frees the hardware resources used in this example:
             - Disable clock of ADC peripheral
             - Revert GPIO associated to the peripheral channels to their default state
             - Revert DMA associated to the peripheral to its default state
             - Revert NVIC associated to the peripheral interruptions to its default state
    @retval None
extern "C" void HAL_ADC_MspDeInit(ADC_HandleTypeDef *hadc)
  /*##-1- Reset peripherals ##################################################*/
  __HAL_RCC_ADC1_FORCE_RESET();
  __HAL_RCC_ADC1_RELEASE_RESET();
  /*##-2- Disable peripherals and GPIO Clocks ################################*/
  /* De-initialize GPIO pin of the selected ADC channel */
  HAL_GPIO_DeInit(GPIOA, GPIO_PIN_4);
  /*##-3- Disable the DMA ####################################################*/
  /* De-Initialize the DMA associated to the peripheral */
  if (hadc->DMA_Handle != NULL)
    HAL_DMA_DeInit(hadc->DMA_Handle);
  /*##-4- Disable the NVIC ###################################################*/
  /* Disable the NVIC configuration for DMA interrupt */
  HAL_NVIC_DisableIRQ(DMA1_Channel1_IRQn);
  /* Disable the NVIC configuration for ADC interrupt */
  HAL_NVIC_DisableIRQ(ADC1_2_IRQn);
    @brief  ADC configuration
    @param  None
    @retval None
static void ADC_Config(void)
  ADC_ChannelConfTypeDef   sConfig;
  ADC_AnalogWDGConfTypeDef AnalogWDGConfig;
  /* Configuration of ADCx init structure: ADC parameters and regular group */
  AdcHandle.Instance = ADC1;
  AdcHandle.Init.DataAlign             = ADC_DATAALIGN_RIGHT;
  AdcHandle.Init.ScanConvMode          = ADC_SCAN_DISABLE;              /* Sequencer disabled (ADC conversion on only 1 channel: channel set on rank 1) */
#if defined ADC_TRIGGER_FROM_TIMER
  AdcHandle.Init.ContinuousConvMode    = DISABLE;                       /* Continuous mode disabled to have only 1 conversion at each conversion trig */
#else
  AdcHandle.Init.ContinuousConvMode    = ENABLE;                        /* Continuous mode to have maximum conversion speed (no delay between conversions) */
  AdcHandle.Init.NbrOfConversion       = 1;                             /* Parameter discarded because sequencer is disabled */
  AdcHandle.Init.DiscontinuousConvMode = DISABLE;                       /* Parameter discarded because sequencer is disabled */
  AdcHandle.Init.NbrOfDiscConversion   = 1;                             /* Parameter discarded because sequencer is disabled */
  AdcHandle.Init.ExternalTrigConv      = ADC_EXTERNALTRIGCONV_Tx_TRGO;  /* Trig of conversion start done by external event */
#else
  AdcHandle.Init.ExternalTrigConv      = ADC_SOFTWARE_START;            /* Software start to trig the 1st conversion manually, without external event */
  if (HAL_ADC_Init(&AdcHandle) != HAL_OK)
    /* ADC initialization error */
    Error_Handler();
  /* Configuration of channel on ADCx regular group on sequencer rank 1 */
  /* Note: Considering IT occurring after each ADC conversion if ADC          */
  /*       conversion is out of the analog watchdog window selected (ADC IT   */
  /*       enabled), select sampling time and ADC clock with sufficient       */
  /*       duration to not create an overhead situation in IRQHandler.        */
  sConfig.Channel      = ADC_CHANNEL_4;
  sConfig.Rank         = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_41CYCLES_5;
  if (HAL_ADC_ConfigChannel(&AdcHandle, &sConfig) != HAL_OK)
    /* Channel Configuration Error */
    Error_Handler();
  /* Set analog watchdog thresholds in order to be between steps of DAC       */
  /* voltage.        */
  /*  - High threshold: between DAC steps 1/2 and 3/4 of full range:          */
  /*                    5/8 of full range (4095 <=> Vdda=3.3V): 2559<=> 2.06V */
  /*  - Low threshold:  between DAC steps 0 and 1/4 of full range:            */
  /*                    1/8 of full range (4095 <=> Vdda=3.3V): 512 <=> 0.41V */
  /* Analog watchdog 1 configuration */
  AnalogWDGConfig.WatchdogMode = ADC_ANALOGWATCHDOG_ALL_REG;
  AnalogWDGConfig.Channel = ADC_CHANNEL_4;
  AnalogWDGConfig.ITMode = ENABLE;
  AnalogWDGConfig.HighThreshold = (RANGE_12BITS * 5 / 8);
  AnalogWDGConfig.LowThreshold = (RANGE_12BITS * 1 / 8);
  if (HAL_ADC_AnalogWDGConfig(&AdcHandle, &AnalogWDGConfig) != HAL_OK)
    Error_Handler();
    @brief  Conversion complete callback in non blocking mode
    @param  AdcHandle : AdcHandle handle
    @note   This example shows a simple way to report end of conversion
            and get conversion result. You can add your own implementation.
    @retval None
extern "C" void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef * ) {
    @brief  Conversion DMA half-transfer callback in non blocking mode
    @retval None
extern "C" void HAL_ADC_ConvHalfCpltCallback(ADC_HandleTypeDef * ) {
    @brief  Analog watchdog callback in non blocking mode.
    @retval None
extern "C" void HAL_ADC_LevelOutOfWindowCallback(ADC_HandleTypeDef * ) {
  /* Set variable to report analog watchdog out of window status to main      */
  /* program.        */
  ubAnalogWatchdogStatus = SET;
    @brief  ADC error callback in non blocking mode
           (ADC conversion with interruption or transfer by DMA)
    @retval None
extern "C" void HAL_ADC_ErrorCallback(ADC_HandleTypeDef * )
  /* In case of ADC error, call main error handler */
  Error_Handler();
// the setup routine runs once when you press reset:
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(PA4, INPUT_ANALOG);
  /* Configure the ADC peripheral */
  ADC_Config();
  /* Run the ADC calibration */
  if (HAL_ADCEx_Calibration_Start(&AdcHandle) != HAL_OK) {
    /* Calibration Error */
    Error_Handler();
  /* Start ADC conversion on regular group with transfer by DMA */
  if (HAL_ADC_Start_DMA(&AdcHandle,
                        (uint32_t *)aADCxConvertedValues,
                       ) != HAL_OK) {
    /* Start Error */
    Error_Handler();
// the loop routine runs over and over again forever:
  /* Turn-on/off LED_BUILTIN in function of ADC conversion result */
  /*  - Turn-off if voltage is into AWD window */
  /*  - Turn-on if voltage is out of AWD window */
  /* Variable of analog watchdog status is set into analog watchdog         */
  /* interrupt callback                                                     */
  if (ubAnalogWatchdogStatus == RESET) {
    digitalWrite(LED_BUILTIN, LOW);   // turn the LED on (HIGH is the voltage level)
  else {
    digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
    /* Reset analog watchdog status for next loop iteration */
Answers: 24
Re: [STM32F1] ADC_AnalogWatchdog example
would it be necessary to patch up the interrupt vector table?
https://github.com/STMicroelectronics/S ... 32f103xb.s
i've been wondering how to do this 'elegantly' as it would seem it would be necessary to use a different startup_stm32fxxyy.s that has the HAL definitions patched into it
Answers: 91
ag123 wrote: Fri Jan 17, 2020 6:39 am would it be necessary to patch up the interrupt vector table?
No, it is not needed.
Answers: 24
hi fpistm, i hope to a hint here as i'd try to get my stack working, in part as working within vscode my setup is apparently broken in some ways.
i resort to eclipse and a makefile build and it actually works ! i can contribute that makefile if anyone is interested.
however.as i'm looking at the vector tables for the interrupt tables e.g. say STM32F4xx
i seem to find
https://github.com/stm32duino/Arduino_C ... 32f401xe.s
i'm seeing codes like such
   .weak      DMA1_Stream5_IRQHandler
   .thumb_set DMA1_Stream5_IRQHandler,Default_Handler
   .weak      DMA1_Stream6_IRQHandler
   .thumb_set DMA1_Stream6_IRQHandler,Default_Handler
   .weak      ADC_IRQHandler
   .thumb_set ADC_IRQHandler,Default_Handler
does it mean those are pointing to the default handler? Are there different .s file that contains the vector hooks that points into HAL?
e.g. for DMA, ADC, timers etc
or that i'd need to change/patch them in sram after the core 'booted up' into the sketch?
Answers: 91
You don't need to change this. They aer weaked that's all.
Answers: 24
thanks, i'd try with using a .c or .s file in project folders so that i'd re-define the hooks as needed
Return to “Code snippets”
