SIMPLE QUESTION BLUE PILL COMMUNICATIONS SETTINGS
RobertoBerner
Post by RobertoBerner »
Hi all !
I am new to STM32 but I have experience with C and other MCUs families.
I need to make it work with Arduino IDE, now using Arduino IDE version 1.8.15
If I want to run this basic code on my Blue Pill board with STM32F103C8T6, I am having trouble to use the native USB connection to program and also to Serial.print to the IDE console terminal.
  Serial.println("Hello");
Here are the board & communication settings by STMicroelectronics:
- Board: Generic STM32F1 series
- Board port number: "BluePill F103C8"
- U(S)ART support "Enabled" (Generic serial)
- USB support (if available): "CDC (generic Serial)
- USB speed (if available): "Low/Full Speed"
- Optimize: "Smallest (-Os default)
- Upload method: HID Bootloader 2.0
- Port: COM12
- Get Board Info: working fine
With this configuration I am unable to program my BluePill. This is what I get:
> Trying to open the [COM12]...
> Toggling DTR...
> Searching for [1209:BEBA] device...
Error - [1209:BEBA] device is not found :(> Searching for [COM12] ...
> Finish
Note: My BluePill has been previously programmed via USB but with STM32F1xx/GD32F1xx boards by stmduino
In this case, the settings change as follows:
- Board: "Generic STM32F103C8 series"
- Variant: STM32F103C8 (20K RAM; 64K Flash)
- Upload method "STM32duino bootloader"
- CPU speed (MHz): 72 MHz (Normal)
- Optimize: "Smallest (default)"
- Port: COM12
- Get board info: working fine
This means that the bootloader works. But I am working in a project that need a timer interrupt event.
The timer functions compile if I use the first setting configuration by STMicroelectronics, but I am unable to program.
If I don't use the timer library, and using the second configuration by stmduino, I am able to program the BluePill using the classic USB connection.
I need help to know how the STMicroelectronics libraries can be used and still program the board via USB from the Arduino IDE.
Thank you
Answers: 28
Re: SIMPLE QUESTION BLUE PILL COMMUNICATIONS SETTINGS
You don't have HID bootloader on your board.
stm32duino bootloader is based on Maple bootloader and you need to select "Maple bootloader 2.0" or flash HID bootloader: https://github.com/Serasidis/STM32_HID_Bootloader
RobertoBerner
OK, here's what I have in the table:
hid_generic_pc13.bin (downloaded from https://github.com/Serasidis/STM32_HID_ ... /tag/2.2.2)
hid-flash.exe (downloaded from https://github.com/Serasidis/STM32_HID_ ... r/releases)
My BluePill has LED in PC13 as written over the board
The hid-flash.exe says:
| HID-Flash v2.2.1 - STM32 HID Bootloader Flash Tool |
| (c) 2018 - Bruno Freitas http://www.brunofreitas.com |
| (c) 2018-2019 - Vassilis Serasidis https://www.serasidis.gr |
| Customized for STM32duino ecosystem https://www.stm32duino.com |
Usage: hid-flash <bin_firmware_file> <comport> <delay (optional)>
From the literature here https://github.com/Serasidis/STM32_HID_ ... /tag/2.2.2 ...
... I should do this:
hid-flash hid_generic_pc13.bin COMx <ENTER> with the BluePill on the USB and one jumper in 3.3V
Problem: after last Arduino program upload now my board does not show any COM port over USB
It shows under LibUSB-Win32 Devices : Maple-DFU
So, what COMx port should I use ?
I tested all 4 boot jumper combinations.
Answers: 28
You need a programmer to flash bootloader to F103 (ST-Link or usb-ttl). There is no other way. There are instructions how to flash HID bootloader.
hid_flash tool is for flashing your programs using HID bootloader.
RobertoBerner
OK, I have both ST-Link and a Serial TTL to USB cable.
I am a newbie to STM32, and I thank all the help I am receiving.
Could you please give me some clue on how to flash the HID-bootloader by using this serial tools?
The hid_generic_pc13.bin file is still OK ?
I understand that once you have the HID-bootloader installed, the USB connection is able to flash programs from Arduino IDE and also keep the COMx port working after loading ?
RobertoBerner
PROBLEM SOLVED !
I could successfully flashed the HID-bootloader to my BluePill.
Now I can program from Arduino IDE and also Serial.print to the serial monitor.
I used my ST-Link and the STM32CubeProgrammer to flash the hid_generic_pc13.bin file.
An excellent YouTube video explains the process very clearly.
https://www.youtube.com/watch?v=Myon8H111PQ&t=425s
Having reached this point, I have a next issue to consult in another post.
Thank you all !
Roberto
RobertoBerner
Hello friends, after some time, I would like to add something about my newbie experience.
I started using the bootloader but...
I reached the point in which I had to reFLASH the HID bootloader each time before Arduino uploads, because the bootloader under certain conditions, got corrupted. Later I found that this is a very well known issue. Sometimes the bootloader simply fails to switch between USB mode to COM mode so Arduino can't program the part.
Erased the FLASH and returned to ST-Link V2, despite the lack of the serial monitor is a burden. Any ideas or a better approach?
Roberto
hobbya
Post by hobbya »
I always use STLink v2.1. It comes with a virtual com port.
STLink v2 do not have the virtual com port.
Some more info here:
https://stm32world.com/wiki/DIY_STM32_P ... Link/V2-1)
Nucleo boards also has a built-in STLink v2.1 and it can be "broken off" from the board:
https://jeelabs.org/book/1547a/index.html
Some shops sell the above e.g.
https://modtronix.com/product/pgm-nucleo/
Certainly you can also look for STLINK v3 but it is more expensive.
RobertoBerner
Hello hobbya, thank you for this excellent information.
I will take a closer look tomorrow, but I find interesting the 6 pin ST-Link V2.1
However I understand that the VCOM port ends in TX/RX pins and that these pins need to be connected to TX/RX in the Bluepill (STM32F103C8T6) with 2 wires. If so, this is really convenient.
Thank you very much, greetings from Buenos Aires
Roberto
hobbya
Post by hobbya »
Yes your understanding is correct.
v2.1 has Tx/Rx pins which can be connected to the Bluepill serial port.
