Page 1 of 2
Code doesn't seem to run Nucleo-F401RE
Posted: Fri Jul 17, 2020 4:01 pm
by quasio
Hi All,
been trying to get this STM32 Nucleo - F401RE working. Downloaded the stm32 core libraries (1.9.0) for arduino 1.8.9.
Managed to update STLink to V2.J37.M26 ( attached picture) as the flasher asked to.
- flashed_stlink.png (42.39 KiB) Viewed 11485 times
The settings i used to flash:
- settings.jpg (58.42 KiB) Viewed 11485 times
And then it seemed to be able to flash the Nucleo F401RE using STM32Cubeprogrammer(SWD) , the default program of blinking led light dissapeared.
- flashswd.png (24.88 KiB) Viewed 11485 times
However it doesn't seem the program runs. I did the default blink led sketch and nothing, and then tried to look at the serial monitor (for other programs with serial.println and also nothing.)
Anyone know what i'm doing wrong?
(thanks in advance)
Re: Code doesn't seem to run Nucleo-F401RE
Posted: Mon Aug 03, 2020 11:53 am
all seems right. I've tested with the latest STLink FW V2.J37.M26 and it works.
Did you made some change on the jumper configuration or soldier bridge?
Could you try with the mass storage upload method ?
Posted: Wed Nov 18, 2020 2:25 pm
by pablomuro
Did You solved the problem?
I have the same problem here, my Nucleo F401RE works perfectly on STM32 Cube IDE, but in Arduino, all the responses from IDE are ok, but the programs not run, even if I click on the reset button. However, if I select in the boards manager, the "Core Board F401RCT6" all the functions works, but the serial communication didn't work. The upload method that I'm using is STM Cube Programmer(SWD).
I will attach the images below.
Best regards.
- Configs.png (82.28 KiB) Viewed 10880 times
- IMG_20201118_105641455~2.jpg (80.32 KiB) Viewed 10880 times
Posted: Wed Nov 18, 2020 2:40 pm
by mlundin
For the Nucleo board use "Nucleo-64" and not "Generic STM32F4 series", then select "Nucleo F401RE"
What code are you trying to run?
Posted: Wed Nov 18, 2020 3:33 pm
by pablomuro
Thanks.
But if I set "Nucleo-64" and not "Generic STM32F4 series", then select "Nucleo F401RE", nothing works, the response of Arduino is ok, but the board didn't work.
Posted: Wed Nov 18, 2020 3:36 pm
by pablomuro
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
const int analogOutPin = PA5; // Analog output pin that the LED is attached to
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
// initialize serial communications at 9600 bps:
// read the analog in value:
sensorValue = analogRead(analogInPin);
// map it to the range of the analog out:
outputValue = map(sensorValue, 0, 1023, 0, 255);
// change the analog out value:
analogWrite(analogOutPin, outputValue);
// print the results to the Serial Monitor:
Serial.print("sensor = ");
Serial.print(sensorValue);
Serial.print("\t output = ");
Serial.println(outputValue);
// wait 2 milliseconds before the next loop for the analog-to-digital
// converter to settle after the last reading:
delay(2);
Posted: Wed Nov 18, 2020 4:04 pm
by mlundin
The photo looks like an X3 crystal has been added, in that case the clock configuration must be changed in SystemClock_Config(void) defined in variant.cpp
Posted: Wed Nov 18, 2020 4:48 pm
by pablomuro
I added the 8MHz crystal and it's capacitors triyng to solve the problem, but this didn't help. I think that the problem is the clock configuration, becouse even if I use the clock from the st-link(default source clock), the results are the same. I will try to do that you recomended and post the results here.
Thanks.
Posted: Wed Nov 18, 2020 5:41 pm
just 2cents, and out of curiosity not tested
try to find
variants/NUCLEO_F4x1RE/variant.cpp
in the location of your installed core source codes
https://github.com/stm32duino/Arduino_C ... t.cpp#L137
__HAL_RCC_PWR_CLK_ENABLE();
#ifdef ARDUINO_NUCLEO_F401RE
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
#else /* ARDUINO_NUCLEO_F411RE */
RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
next try my little python script that play with frequencies
viewtopic.php?f=41&t=78
copy that code by clicking 'select all', then control-C
you would need to edit that to start searching at a lower frequency say fmin 80mhz
then goto say
https://www.python.org/shell/
and run it there, sample output:
Python 3.8.0 (default, Nov 14 2019, 22:29:45)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> #!/usr/bin/python3
... #FHSE in mhz
... FHSE = 8
>>> #cpu search frequency range
... fmin = 80
>>> fmax = 110
>>> #clk1 = clk / m
... m = list(range(1,64))
>>> #vco = clk1 * n
... n = list(range(0,512))
>>> #vco / p = system clock - mcu speed (not systick)
FHSE: 8 m: 1 n: 24 p: 2 (RCC_PLLP_DIV2) q: 4 fusb: 48.0 fcpu: 96.0
FHSE: 8 m: 1 n: 42 p: 4 (RCC_PLLP_DIV4) q: 7 fusb: 48.0 fcpu: 84.0
FHSE: 8 m: 1 n: 48 p: 4 (RCC_PLLP_DIV4) q: 8 fusb: 48.0 fcpu: 96.0
FHSE: 8 m: 1 n: 54 p: 4 (RCC_PLLP_DIV4) q: 9 fusb: 48.0 fcpu: 108.0
FHSE: 8 m: 2 n: 48 p: 2 (RCC_PLLP_DIV2) q: 4 fusb: 48.0 fcpu: 96.0
FHSE: 8 m: 2 n: 84 p: 4 (RCC_PLLP_DIV4) q: 7 fusb: 48.0 fcpu: 84.0
FHSE: 8 m: 7 n: 378 p: 4 (RCC_PLLP_DIV4) q: 9 fusb: 48.0 fcpu: 108.0
FHSE: 8 m: 8 n: 192 p: 2 (RCC_PLLP_DIV2) q: 4 fusb: 48.0 fcpu: 96.0 <<<
FHSE: 8 m: 8 n: 336 p: 4 (RCC_PLLP_DIV4) q: 7 fusb: 48.0 fcpu: 84.0 <<<
FHSE: 8 m: 8 n: 384 p: 4 (RCC_PLLP_DIV4) q: 8 fusb: 48.0 fcpu: 96.0
FHSE: 8 m: 8 n: 432 p: 4 (RCC_PLLP_DIV4) q: 9 fusb: 48.0 fcpu: 108.0
FHSE: 8 m: 9 n: 216 p: 2 (RCC_PLLP_DIV2) q: 4 fusb: 48.0 fcpu: 96.0...
for
FHSE 8 mhz
m : 8
n: 336
q: 7
you get a 84mhz system clock on the stm32f401 which is according to specs
Posted: Wed Nov 18, 2020 5:47 pm
by mlundin
Since the external 8MHz signal from the STLink has been replaced by an 8MHz crystal, the internal oscillator must be active and not bypassed. Therefore I think you must replace the line:
with
