Issue with Installing and Uploading to Blue Pill
Posted: Tue Oct 20, 2020 8:18 pm
I am a newbie here so I must be doing something wrong here.
I installed the bootloader (generic_boot20_pc13.bin) and installed the boards on ArduinoIDE, copied the Arduino_STM32 folder and ran the install_driver.bat file.
After the first code upload the blue pill since flashing with the bootloader. I get the following output in my IDE.
The blue pill is running the sketch though, but all subsequent uploads fail with the following:
I also checked the device manager and the COM3 port which was available before the first upload is missing. There is also an Unknown USB device.
I don't know what I did wrong. Please help.
Sketch uses 9968 bytes (7%) of program storage space. Maximum is 131072 bytes.
Global variables use 844 bytes (4%) of dynamic memory, leaving 19636 bytes for local variables. Maximum is 20480 bytes.
maple_loader v0.1
Found it!
Found Runtime: [0x1eaf:0x0003] devnum=1, cfg=0, intf=0, alt=2, name="STM32duino bootloader v1.0 Upload to Flash 0x8002000"
Setting Configuration 1...
Claiming USB DFU Interface...
Setting Alternate Setting ...
dfuIDLE, continuing
Transfer Size = 0x0400
bytes_per_hash=205
error resetting after download: usb_reset: could not reset device, win error: A device which does not exist was specified.
Done!
timeout waiting for COM3 serial
maple_loader v0.1
Couldn't find the DFU device: [1EAF:0003]
dfu-util - (C) 2007-2008 by OpenMoko Inc.
