[ERROR] class EEPROMClass has no member named length
LORDHADES
Post by LORDHADES »
Hey all !!!
I hope y'all are doing well...
I'm using Setup : Digital weighing scale using Renesas chip connected to one channel of Max232, another channel of Max232 connected to STM32. STM32 is connected to PC via FTDI232 serial to USB converter. A push button is attached to STM32, to facilitate data printing on serial monitor when enabled.
I used this tutorial for preliminary setup : "https://www.instructables.com/Getting-S ... duino-IDE/"
Arduino IDE: v1.8.13(Windows Store 1.8.42.0) from Microsoft store
Board Manager: STM32F1XX/GD32F1XX by stm32duino v2020.11.14
Additional board manager URL: "http://dan.drown.org/stm32duino/package ... index.json"
I am trying to save the serially received data into stm32's EEPROM(emulated flash memory in this case). For this, I wrote a dummy code derived from inbuilt examples. The code is :
#include <EEPROM.h>
int addr = 0;
int address = 0;
int ledPin = PC13;
int inByte;
int inByte_1;
const char welMsg[] = "Ciao, Press :\r\n" \
                    "0 to write data\r\n" \
                    "1 to read written data\r\n" \
                    "2 to display status\r\n";
uint16 DataWrite = 0;
uint16 AddressWrite = 0;
  pinMode(ledPin, OUTPUT);
  Serial.print(welMsg);
  uint16 Status;
  uint16 Data;
  while (Serial.available())
    char cmd = (char)Serial.read();
    Serial.println(cmd);
    if(cmd == '0')
      Serial.println("Enter something");
      inByte = Serial.read();
      EEPROM.write(addr, inByte);
      addr = addr + 1;
      if (addr == EEPROM.length())
        addr = 0;
    delay(100);
    else if (cmd == '1')
      inByte_1 = EEPROM.read(address);
      Serial.print(address);
      Serial.print('\t');
      Serial.print(inByte_1, DEC);
      Serial.println();
      address = address + 1;
      if (address == EEPROM.length())
        address = 0;
    else if (cmd == '2')
      Status = EEPROM.write(AddressWrite, DataWrite);
      Serial.print("EEPROM.write(0x");
      Serial.print(AddressWrite, HEX);
      Serial.print(", 0x");
      Serial.print(DataWrite, HEX);
      Serial.print(") : Status : ");
      Serial.println(Status, HEX);
    else
  digitalWrite(ledPin, HIGH);
  digitalWrite(ledPin, LOW);
But unfortunately, while compiling, I get an error like :
EEPROM_trial:39:26: error: 'class EEPROMClass' has no member named 'length'
EEPROM_trial:56:29: error: 'class EEPROMClass' has no member named 'length'
Using library EEPROM in folder: C:\Users\IIoT\OneDrive\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2020.11.27\libraries\EEPROM (legacy)
exit status 1
When I took a look on EEPROM.h file, length was not defined there. Since i'm a novice programmer, I really dunno how to define length on that library. I tried to figure it out, but I failed to do it and found nothing useful on internet.
Somebody please gimme a suggestion on this concern. Thanks in advance. God bless y'all.
P.S. I use STM32F103C6/8, with 128 KB internal flash.
Hades
Re: [ERROR] class EEPROMClass has no member named length
The EEPROM library for Libmaple (Roger's core) seems to not support the length() function.
This library was last updated 3 years ago, there is no active support for that.
So I am afraid you should either implement yourself this function, or look for alternative solutions (use external EEPROMs).
Those examples are for arduino compatible cores (like STM32 core).
Roger's core has own EEPROM library. It has 2 functions:
uint16 EEPROMClass::count(uint16 *Count);
and
uint16 EEPROMClass::maxcount(void);
Don't know what exactly they do but they return some value related to EEPROM size.
Now one big "BUT":
If you want to do many writes to EEPROM don't use emulated EEPROM. It will damage MCU's flash memory.
With emulated EEPROM every write to EEPROM erases whole page in flash and rewrites it. So even if you change 1 byte it erases whole page. And flash life is about 10k erase cycles.
I recommend using external EEPROM chip. They are cheap, you can write/erase each byte and have better life (100k - 1M cycles for each cell).
