can USB be used to create a virtual com port?
STM32_Newbbe
Re: can USB be used to create a virtual com port?
Post by STM32_Newbbe »
But why do I get no output on Serial / LPUART1 as soon as CDC / SerialUSB is activated?
Answers: 109
What is your code?
STM32_Newbbe
It is a quickly written test for playing with optocouplers
I added a bit to test different Serials/UARTs
done in sloeber, thats why there is the first include satement
// Do not remove the include below
#include "Test_L4R5.h"
long unsigned int currentmillis = 0;
long unsigned int pastmillis = 0;
HardwareSerial Serial3(PC11, PC10);
//HardwareSerial SerialLP1(PG8, PG7);
	Serial3.begin(115200);
	SerialLP1.begin(115200);
	pinMode(3, INPUT_PULLUP);
	pinMode(4, INPUT_PULLUP);
	pinMode(5, OUTPUT);
	pinMode(6, OUTPUT);
	Serial.println("L4R5 Test starting...");
	char SerialBuffer[128];
	memset(SerialBuffer, 0, sizeof(SerialBuffer));
	unsigned char offset = 0;
	currentmillis = millis();
	if((currentmillis - pastmillis) >= 1000)
		pastmillis = currentmillis;
		offset = snprintf(SerialBuffer, sizeof(SerialBuffer), "%6d ", int(currentmillis / 1000));
	strncat(SerialBuffer, "Input 3 is ", sizeof("Input 3 is "));
	if(digitalRead(3) == HIGH)
		strncat(SerialBuffer, "High", sizeof("High"));
		digitalWrite(5, HIGH);
	else
		strncat(SerialBuffer, "Low", sizeof("Low"));
		digitalWrite(5, LOW);
	strncat(SerialBuffer, ", Input 4 is ", sizeof(", Input 4 is "));
	if(digitalRead(4) == HIGH)
		digitalWrite(6, HIGH);
	else
		strncat(SerialBuffer, "Low\n", sizeof("Low\n"));
		digitalWrite(6, LOW);
	Serial.println(SerialBuffer);
	Serial3.println(SerialBuffer);
	SerialLP1.println(SerialBuffer);
STM32_Newbbe
and this are the settings for the board:
STM32_Newbbe
Hah! Seems like I solved it :)
I have absolutely no idea why, but redefining the Rx and Tx pins has fixed it!
I only added
	SerialLP1.setRx(PG8);
	SerialLP1.setTx(PG7);
before
and now I have output on all serial channels !
Although I am quite happy that it works now, I really would like to know about the "why"...
So if anyone can shed some light on this topic, that would be great!
I could not find out where - besides the variant_NUCLEO_L4R5ZI.cpp file the pins are set. Maybe its part of the magic that happens with the settings in the Arduino/sloeber IDE?
STM32_Newbbe
Now I noticed that output via the VCP is not happening in the first few moments...
The above code should output a startup message
but it appears only on th STLink Serial and not on the USB VCP Serial
the next loop, 1 second later is output on both channels
any idea why?
Answers: 109
Add a while(!Serial); four USB issue. About the other one I will have a look next week anyway I see no reason why it does not work. Maybe Sloeber issue...
STM32_Newbbe
That thought occured to me as well, therefore I tried it in Arduino IDE with the same result.
No output on LPUART1 until I redefine the pins.
Thanks for the while(!Serial); idea!
Is this non-blocking, or do I have to add a timeout some way or another?
It takes about 350ms, so not tooooo long :)
STM32_Newbbe
Alright, found out myself about if(Serial) and while(!Serial)
I indeed have to assure that something is connected or have to implement some kind of timeout
Another thought:
can I check at runtime (i.e. in my code) whether CDC USB Serial is activated?
Answers: 109
OK I found why and it is normal (at least with the current implementation).
As Serial is no more mapped to SerialLP1 then the default pins defined in the variant_NUCLEO_L4R5.h (PIN_SERIAL_RX/PIN_SERIAL_TX) are not used as they are defined for the "Serial" instance.
So the correct way is to use setRX/TX.
I will check if I can use those defined pins when Serial is mapped to USB.
