is it possible to use a X-NUCLEO-IDB05A2 with a NUCLEO-F401RE as a bluetooth hid or serial device
What are you developing?
hannescam
Post by hannescam »
i need a library for the X-NUCLEO-IDB05A2 as a bluetooth serial or hid for a project of mine
Re: is it possible to use a X-NUCLEO-IDB05A2 with a NUCLEO-F401RE as a bluetooth hid or serial device
It connects using SPI so not Serial or HID. If you want to connect this way, you'll have to write a program for STM32 that acts as an adapter (receives data on Serial/USB and sends to IDB05A2 via SPI).
hannescam
Post by hannescam »
no i ment that the bluetooth chip connects to the pc as a keyboard or bluetooth serial device controlled by the stm32
for that it is called STM32-WB
https://www.st.com/resource/en/flyer/flstm32wb.pdf
https://www.st.com/en/evaluation-tools/ ... -wb55.html
but mainly Bluetooth LE.
hid & all that would require implementation 'from scratch'
but if you understand Bluetooth LE, you can program mostly any generic BLE custom profile and apps.
smart watches, bLE scales and many more does it that way and connects to android phones.
hannescam
Post by hannescam »
could you implement the serial bluetooth protocoll for this module for me
hannescam
Post by hannescam »
no none of them did work and the first one is the ps side software and it is the one i am corrently using in another setup
Return to “Projects”
