for my bachelors thesis I first wrote a code for an Arduino Uno and now I ported it to a STM32F407VG Discovery.
I also wrote a Program in Python which sends (utf-8) an array of 40 characters with " " inbetween, the µC then does a task depending on what the first entry is.
I use it in combination with a Shield from Mikroelectronika, equipped with a UART FTDI (See page 7):
https://download.mikroe.com/documents/a ... l-v100.pdf
The code itself works fine so far, however the Serial connection causes errors. I can send that array only once, then the STM32 gets faulty data I guess.
If I send the same array again, it will not run the task it is supposed to and not run "return_data(...)".
Sending this array in Arduinos' Serial monitor (ending with NL, CR) does not change effect.
However if I send "50 ", it works the first time and after an unpredictable amount of attempts, somewhere between 2 - 14 times.
Resetting the STM32 before each transmission also makes it work fine for the first array of data.
This worked fine with the Arduino Uno, I could do this as often as I want to.
The algorithm of Serial communication works as follows:
-> check if Serial.Available() > 0
-> if so, enter function "receive_data()"
-> read serial data until "\n\r" or Serial.available() == 0
-> check first char of array
-> enter function "return_data()" if first char has a defined function
#include <HardwareSerial.h>
HardwareSerial Serial2(USART2);
int numChars = 39;
void setup(){
Serial2.setRx(PA3);
Serial2.setTx(PA2);
Serial2.begin(9600);
while (!Serial2);
float receive_data() {
int rc;
char endMarker = '\n\r';
digitalWrite(PD14, HIGH);
while (Serial2.available() > 0 && newData == false) {
rc = Serial2.readStringUntil(' ').toInt();
if (rc != endMarker) {
receivedChars[ndx] = rc;
rc = 0;
ndx++;
} else {
newData = true;
delay(5);
float checksum = 0;
for (i = 0; i <= numChars; i++) {
if (receivedChars[i] == -1) TransceiveByte[i] = 10; //convert 10 to -1 since arduino reads this as LF
else if (receivedChars[i] == -2) TransceiveByte[i] = 13; //convert 13 to -2 since arduino reads this as CR
else TransceiveByte[i] = receivedChars[i];
if ((i < numChars) && i != 0 && i != 35 && i != 36 && i != 37 && i != 38) {
checksum += TransceiveByte[i];
delay(10);
receivedChars[i] = 0;
if (i == numChars) {
TransceiveByte[numChars] = checksum;
//IWatchdog.reload();
digitalWrite(PD14, LOW); //Turn LED off to signal function is done
return checksum;
void return_data(byte wert) {
int return_data_int;
digitalWrite(PD15, HIGH);
for (j = 0; j <= numChars; j++) {
//if ( j % 4 == 0) digitalWrite(motor_output, LOW);
//if ( j % 8 == 0) digitalWrite(motor_output, HIGH);
if (j == 0) TransceiveByte[0] = wert;
return_data_int = TransceiveByte[j];
Serial2.println(return_data_int);
delay(10);
TransceiveByte[0] = 0;
digitalWrite(PD14, LOW); //Indicate that this function was run, let onboard LED blink
delay(250);
delay(250);
delay(250);
delay(250);
digitalWrite(PD15, LOW);
int checksum2;
if (Serial2.available() > 0) {
delay(100);
checksum2 = receive_data();
Serial2.flush();
if ((HAL_GetTick() - starttimer >= endtimer) || newData == 1) { // Check data every second
newData = 0;
starttimer = HAL_GetTick();
TransceiveByte[numChars] = checksum2;
if (TransceiveByte[0] == 50) { // Task 1
return_data(51);
if (TransceiveByte[0] == 2) { // Task 2
return_data(5);
