I2C communication between 2 STM32F103C8T6 does not work
eeaciu21048
Post by eeaciu21048 »
I am trying to communicate I2C between 2 STM32F103C8T6 but it does not work
Master code:
#include<Wire.h>
int z[16];
  delay(50);
  Wire.begin();
  delay(50);
  Wire1.requestFrom(0x09, 16);  //to receive 16-byte;
  delay(50);
  Serial.print("Slave data: ");
  for (int i = 0; i < 16; i++)
    z[i] = Wire.read();
    delay(50);
    Serial.print(z[i], DEC);
  Serial.println();
Slave code:
#include<Wire.h>
const uint8_t a = 0x09;
int transferArray[16] = {1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1};
bool flag1 = LOW;
  delay(50);
  Wire.begin(a);
  delay(50);
  Wire.onRequest(sendEvent);
  delay(50);
void sendEvent()
  for (int i = 0; i < 16; i ++ )
      Wire.write((transferArray[i]));
      delay(50); //I2C is byte-oriened Bus
      //Wire.write(lowByte(transferArray[i]));
The result is: -1-1-1-1-1-1-1-1
I also use 2 pull-up resistors 4.7k for both SCL and SDA lines.
This code works on 2 Arduino Uno but I can not understand why it does not work on STM32.
Can somebody help me, please. Thank you very much!
Andre
Re: I2C communication between 2 STM32F103C8T6 does not work
Post by Andre »
Did you get it to work?
I have this issue myself: https://github.com/stm32duino/Arduino_C ... ssues/2585
At the same time I have been using STM32F103 as master, and knows that that works.
