New APM32F103CB
Pito
Re: New APM32F103CB
Post by Pito »
Squonk42 wrote: Mon Apr 06, 2020 10:17 am Good!
So, just a simple single-precision floating point ALU with Cordic exposed in peripheral address space.
No SIMD vector or MAC operations and no saturation, so almost useless for all DSP usage.
Better than nothing :-(
I doubt there will be Cordic. They do it standard way, imo.
blue-man
Re: New APM32F103CB
Post by blue-man »
I received now some of the APM32F103CB black pills from RobotDyn.
Today I tried to use the library from the SDK to compile a little first test program of the FPU.
But it seems the beginner needs a tip how to use this precompiled library sc_math.lib in STM32Duino.
I get the compile error:
.../arduino15/packages/STM32/tools/xpack-arm-none-eabi-gcc/9.2.1-1.1/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: /tmp/arduino_build_835900/sketch/APM-Test.ino.cpp.o: in function `loop':
APM-Test.ino.cpp:(.text.loop+0x26): undefined reference to `sc_math_sin(float)'
I already tried to rename the .lib to .a or .so without success.
APM-Test.zip
Test Programm
(7.37 KiB) Downloaded 1267 times
blue-man
Re: New APM32F103CB
Post by blue-man »
The compilation problem is principally solved viewtopic.php?f=39&t=405 - but leads to other errors ..
blue-man
Re: New APM32F103CB
Post by blue-man »
The really disappointing thing is that the APM32F103CB has no FPU !
The MCU of the black pill from RobotDyn is described with an FPU https://github.com/RobotDynOfficial/Doc ... -MCU-Board
Now i found out that only APM32E103 models have an FPU! https://www.apexmic.com/uploads/tool/MC ... 496340.pdf
The E stands for Enhanced.
So this black pill can be seen as an blue pill with 128KB flash memory.
comparison
comparison
ozcar
Answers: 5
Re: New APM32F103CB
Post by ozcar »
blue-man wrote: Sun May 10, 2020 5:07 pm The really disappointing thing is that the APM32F103CB has no FPU !
I was just looking at the Robotdyn site yesterday and saw there where they say "with a higher frequency 96MHz (1.5DMIPS) and a built-in FPU". They go on with more about the benefits of having the FPU.
So did you advise them of this? Maybe they did not know they were lying?
Edit: I just noticed that the 96MHz is also only the Enhanced version.
fredbox
Re: New APM32F103CB
Post by fredbox »
Looks like bootsector already reported this to their github.
blue-man
Re: New APM32F103CB
Post by blue-man »
ozcar wrote: Sun May 10, 2020 9:38 pm So did you advise them of this? Maybe they did not know they were lying?
Yes - an dispute is opened with the correct informations.
fredbox
Re: New APM32F103CB
Post by fredbox »
Quoting from a different thread:
arpruss wrote: Wed Apr 15, 2020 5:01 pm I would love to hear how well the APM32 functions. It seems very promising, except the costs are a bit high for smaller quantities. I am particularly curious if USB is fully functional at the higher clock rate, and whether power usage is comparable.
20 pieces from the RobotDyn store on Ali is about $29. There is a discount for 20 pieces and free shipping over $25. https://www.aliexpress.com/item/4000807291937.html
I've noticed that Ali now charges state sales tax.
I paid nearly that much for the original Arduino many years ago.
blue-man
Re: New APM32F103CB
Post by blue-man »
Please remember that all additional functionality maybe only when you get the APM32E103 !
But i have never seen an offer for it. ;)
So you get an "STM32F103-Clone" with 128KB flash memory - not more.
When you compare the dies you can see that there is no additional space for such a FPU-logic.
APM32F103C8T6: https://www.richis-lab.de/STM32_05.htm
CKS32F103C8T6: https://www.richis-lab.de/STM32_03.htm
The same chip has been used on a Blue-Pill as STM32-Fake.
STM32 Fake
STM32 Fake
Kenjutsu
Re: New APM32F103CB
Post by Kenjutsu »
blue-man wrote: Sun May 17, 2020 7:44 am So you get an "STM32F103-Clone" with 128KB flash memory - not more.
Have you tested it under STM32 Core and if so, which option did you select under Board part number?
TIA ;)
Pieter
macOS: 14.5 M1
Arduino: 1.8.19
Arduino IDE: 2.3.2
STM32 Core: 2.8.0
