OLED SSD1306 I2C e STM32F103C8T6
What are you developing?
Domenico
Post by Domenico »
Hello.
I'm trying to run 2 0.96 "(128x64 px) OLED displays model SSD1306 with my STM32F103C8T6 card.
I use Windows 7, Arduino IDE 1.8.12, STM32 Cores 1.9.0 (from STMicroelectronics), 128x64 px I2C OLED display and AdaFruit Adafruit_SSD1306 library.
I state that I view the testimonials with Arduino UNO and Nano and verified.
To demonstrate the beginning of the Adafruit SSD1306 example for STM32 and the compiler of a series of errors.
I kindly ask if anyone could help me.
These are the writings that show me after the compilation:
In file included from C:\Users\Perito Industriale\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_MonoOLED.h:31:0,
                 from C:\Users\Perito Industriale\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_MonoOLED.cpp:20:
C:\Users\Perito Industriale\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_SPIDevice.h:40:43: error: 'SPI_BITORDER_MSBFIRST' was not declared in this scope
                      BitOrder dataOrder = SPI_BITORDER_MSBFIRST,
C:\Users\Perito Industriale\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_SPIDevice.h:45:43: error: 'SPI_BITORDER_MSBFIRST' was not declared in this scope
C:\Users\Perito Industriale\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_MonoOLED.cpp: In constructor 'Adafruit_MonoOLED::Adafruit_MonoOLED(uint16_t, uint16_t, int8_t, int8_t, int8_t, int8_t, int8_t)':
C:\Users\Perito Industriale\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_MonoOLED.cpp:102:75: error: call to 'Adafruit_SPIDevice::Adafruit_SPIDevice(int8_t, int8_t, int8_t, int8_t, uint32_t, BitOrder, uint8_t)' uses the default argument for parameter 6, which is not yet defined
   spi_dev = new Adafruit_SPIDevice(cs_pin, sclk_pin, -1, mosi_pin, 1000000);
C:\Users\Perito Industriale\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_MonoOLED.cpp: In constructor 'Adafruit_MonoOLED::Adafruit_MonoOLED(uint16_t, uint16_t, SPIClass*, int8_t, int8_t, int8_t, uint32_t)':
C:\Users\Perito Industriale\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_MonoOLED.cpp:135:53: error: 'SPI_BITORDER_MSBFIRST' was not declared in this scope
   spi_dev = new Adafruit_SPIDevice(cs_pin, bitrate, SPI_BITORDER_MSBFIRST,
Più di una libreria trovata per "Wire.h"
Usata: C:\Users\Perito Industriale\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\Wire
Non usata: C:\Users\Perito Industriale\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\WireSlave
exit status 1
Errore durante la compilazione per la scheda Generic STM32F103C series.
Arduino IDE.jpg (73.58 KiB) Viewed 28424 times
Bakisha
Re: OLED SSD1306 I2C e STM32F103C8T6
Post by Bakisha »
Try to downgrade Adafruit_GFX library from library manager.
I founded that last version that doesn't require Adafruit_BusIO library is 1.7.2
It will compile, but i can't say will it work.
Domenico
Post by Domenico »
I downgraded the Adafruit_GFX library to version 1.7.2 and checked the sample code, it didn't give me any problems.
Tomorrow morning I will load the code in the board and verify that it works.
Thank you for your suggestion.
You have chosen the board of the wrong core, according to the attached picture you selected a board from the Libmaple(Roger's) core.
Domenico
Post by Domenico »
Domenico wrote: Fri Jun 05, 2020 8:57 pm I downgraded the Adafruit_GFX library to version 1.7.2 and checked the sample code, it didn't give me any problems.
I uploaded the sketch to the MCU and it works perfectly !! : D Thanks!
The pins to which I connected the I2C are PB6 (SCL1) and PB7 (SDA1).
I have tried connecting to pins PB8 (SCL1) and PB9 (SDA1) and it doesn't work.
If I wanted to use I2C2 how could I do it? (is this part of another post?)
Domenico
Post by Domenico »
stevestrong wrote: Sat Jun 06, 2020 7:58 am You have chosen the board of the wrong core, according to the attached picture you selected a board from the Libmaple(Roger's) core.
Which one should I choose?
"Generic STM32F1 series"?
Then use STM32CubeProgrammer to load the sketch?
What is the difference?
I'm not very knowledgeable about it.
I though you want to use STM32 Cores 1.9.0 (from STMicroelectronics), as you posted above.
For that, you have to select another board which is part of this core.
But then I don't know whether the Adafruit library will work.
Please read this:
viewtopic.php?f=2&t=301
myksj1105
Post by myksj1105 »
@Domenico
Was it successful? I wonder.
Thank you for your reply.
Return to “Projects”
