STM32F103C ----- SDFat Library
jim_patrick
Post by jim_patrick »
Hello all,
I'm trying to get the SDFat library to work on my STM32, I've read this library is much faster than the original SD library, and I need to write data while the chip is doing a lot of work so this sounds like the library of choice.
In the examples folder for SDFat there is a sketch called 'STM32TEST' (below) and simply trying to compile it I get the following error:
"no matching function for call to 'SdFat::SdFat(SPIClass*)'"
relating to this line in the exmaple: "SdFat sd2(&SPI_2);"
Unfortunately I just don't understand what that means, if anyone had any ideas or suggestions that would be appreciated.
Thanks.
 * Example use of two SPI ports on an STM32 board.
 * Note SPI speed is limited to 18 MHz.
#include <SPI.h>
#include "SdFat.h"
#include "FreeStack.h"
// set ENABLE_EXTENDED_TRANSFER_CLASS non-zero to use faster EX classes
// Use first SPI port
SdFat sd1;
// SdFatEX sd1;
const uint8_t SD1_CS = PA4;  // chip select for sd1
// Use second SPI port
SPIClass SPI_2(2);
SdFat sd2(&SPI_2);
// SdFatEX sd2(&SPI_2);
const uint8_t SD2_CS = PB12;   // chip select for sd2
const uint8_t BUF_DIM = 100;
uint8_t buf[BUF_DIM];
const uint32_t FILE_SIZE = 1000000;
const uint16_t NWRITE = FILE_SIZE/BUF_DIM;
// print error msg, any SD error codes, and halt.
// store messages in flash
#define errorExit(msg) errorHalt(F(msg))
#define initError(msg) initErrorHalt(F(msg))
  // Wait for USB Serial
  while (!Serial) {
  // fill buffer with known data
  for (size_t i = 0; i < sizeof(buf); i++) {
    buf[i] = i;
  Serial.println(F("type any character to start"));
  while (!Serial.available()) {
  Serial.print(F("FreeStack: "));
  Serial.println(FreeStack());
  // initialize the first card
  if (!sd1.begin(SD1_CS, SD_SCK_MHZ(18))) {
    sd1.initError("sd1:");
  // create Dir1 on sd1 if it does not exist
  if (!sd1.exists("/Dir1")) {
    if (!sd1.mkdir("/Dir1")) {
      sd1.errorExit("sd1.mkdir");
  // initialize the second card
  if (!sd2.begin(SD2_CS, SD_SCK_MHZ(18))) {
    sd2.initError("sd2:");
// create Dir2 on sd2 if it does not exist
  if (!sd2.exists("/Dir2")) {
    if (!sd2.mkdir("/Dir2")) {
      sd2.errorExit("sd2.mkdir");
  // list root directory on both cards
  Serial.println(F("------sd1 root-------"));
  sd1.ls();
  Serial.println(F("------sd2 root-------"));
  sd2.ls();
  // make /Dir1 the default directory for sd1
  if (!sd1.chdir("/Dir1")) {
    sd1.errorExit("sd1.chdir");
  // remove test.bin from /Dir1 directory of sd1
  if (sd1.exists("test.bin")) {
    if (!sd1.remove("test.bin")) {
      sd2.errorExit("remove test.bin");
  // make /Dir2 the default directory for sd2
  if (!sd2.chdir("/Dir2")) {
    sd2.errorExit("sd2.chdir");
  // remove rename.bin from /Dir2 directory of sd2
  if (sd2.exists("rename.bin")) {
    if (!sd2.remove("rename.bin")) {
      sd2.errorExit("remove rename.bin");
  // list current directory on both cards
  Serial.println(F("------sd1 Dir1-------"));
  sd1.ls();
  Serial.println(F("------sd2 Dir2-------"));
  sd2.ls();
  Serial.println(F("---------------------"));
  // set the current working directory for open() to sd1
  sd1.chvol();
  // create or open /Dir1/test.bin and truncate it to zero length
  SdFile file1;
  if (!file1.open("test.bin", O_RDWR | O_CREAT | O_TRUNC)) {
    sd1.errorExit("file1");
  Serial.println(F("Writing test.bin to sd1"));
  // write data to /Dir1/test.bin on sd1
  for (uint16_t i = 0; i < NWRITE; i++) {
    if (file1.write(buf, sizeof(buf)) != sizeof(buf)) {
      sd1.errorExit("sd1.write");
  // set the current working directory for open() to sd2
  sd2.chvol();
  // create or open /Dir2/copy.bin and truncate it to zero length
  SdFile file2;
  if (!file2.open("copy.bin", O_WRONLY | O_CREAT | O_TRUNC)) {
    sd2.errorExit("file2");
  Serial.println(F("Copying test.bin to copy.bin"));
  // copy file1 to file2
  file1.rewind();
  uint32_t t = millis();
  while (1) {
    int n = file1.read(buf, sizeof(buf));
    if (n < 0) {
      sd1.errorExit("read1");
    if (n == 0) {
      break;
    if ((int)file2.write(buf, n) != n) {
      sd2.errorExit("write2");
  t = millis() - t;
  Serial.print(F("File size: "));
  Serial.println(file2.fileSize());
  Serial.print(F("Copy time: "));
  Serial.print(t);
  Serial.println(F(" millis"));
  // close test.bin
  file1.close();
  file2.close();
  Serial.println(F("------sd1 -------"));
  sd1.ls("/", LS_R | LS_DATE | LS_SIZE);
  Serial.println(F("------sd2 -------"));
  sd2.ls("/", LS_R | LS_DATE | LS_SIZE);
  Serial.println(F("Renaming copy.bin"));
  // rename the copy
  if (!sd2.rename("copy.bin", "rename.bin")) {
    sd2.errorExit("sd2.rename");
  Serial.println(F("Done"));
void loop() {}
Re: STM32F103C ----- SDFat Library
Which core do you use?
viewtopic.php?f=2&t=301
jim_patrick
STM32F103C8 Blue Pill
I asked about the core you use, not the board.
Have you read the info behind the link?
jim_patrick
I'm using #1, the Roger Clark files from Github. Although I seem to be using an older version (that works) whereas when I download the latest zip the sketches won't compile. There is no obvious error message, just says exit 1.
You can turn verbose on in Arduino IDE so that you can see the compilation warnings and errors. Then post those error here.
jim_patrick
n file included from /Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:38:0,
                 from /Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:6:
/Users/james/Documents/Arduino/libraries/SdFat/SdFile.h:44:7: error: conflicting return type specified for 'virtual int SdFile::write(const char*)'
   int write(const char* str);
In file included from /Users/james/Documents/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/HardwareSerial.h:38:0,
                 from /Users/james/Documents/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/wirish.h:69,
                 from /Users/james/Documents/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/Arduino.h:30,
                 from /var/folders/94/f3hz7ssd1z57fv4jg6cnhy480000gn/T/arduino_build_4511/sketch/STM32_SDFat.ino.cpp:1:
/Users/james/Documents/Arduino/hardware/Arduino_STM32/STM32F1/cores/maple/Print.h:40:20: error:   overriding 'virtual size_t Print::write(const char*)'
     virtual size_t write(const char *str);
STM32_SDFat:11:17: error: no matching function for call to 'SdFat::SdFat(SPIClass*)'
 SdFat sd2(&SPI_2);
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:11:17: note: candidates are:
In file included from /Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:6:0:
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:49:3: note: SdFat::SdFat()
   SdFat() {}
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:49:3: note:   candidate expects 0 arguments, 1 provided
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:47:7: note: constexpr SdFat::SdFat(const SdFat&)
 class SdFat {
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:47:7: note:   no known conversion for argument 1 from 'SPIClass*' to 'const SdFat&'
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:47:7: note: constexpr SdFat::SdFat(SdFat&&)
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:47:7: note:   no known conversion for argument 1 from 'SPIClass*' to 'SdFat&&'
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino: In function 'void setup()':
STM32_SDFat:43:39: error: 'SD_SCK_MHZ' was not declared in this scope
STM32_SDFat:25:44: error: no matching function for call to 'SdFat::initErrorHalt(const __FlashStringHelper*)'
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:44:9: note: in expansion of macro 'initError'
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:25:44: note: candidates are:
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:62:8: note: void SdFat::initErrorHalt()
   void initErrorHalt();
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:62:8: note:   candidate expects 0 arguments, 1 provided
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:63:8: note: void SdFat::initErrorHalt(const char*)
   void initErrorHalt(char const *msg);
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:63:8: note:   no known conversion for argument 1 from 'const __FlashStringHelper*' to 'const char*'
STM32_SDFat:24:40: error: no matching function for call to 'SdFat::errorHalt(const __FlashStringHelper*)'
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:49:11: note: in expansion of macro 'errorExit'
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:24:40: note: candidates are:
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:55:8: note: void SdFat::errorHalt()
   void errorHalt();
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:55:8: note:   candidate expects 0 arguments, 1 provided
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:56:8: note: void SdFat::errorHalt(const char*)
   void errorHalt(char const *msg);
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:56:8: note:   no known conversion for argument 1 from 'const __FlashStringHelper*' to 'const char*'
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:58:9: note: in expansion of macro 'errorExit'
   void errorHalt();
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:63:11: note: in expansion of macro 'errorExit'
   void errorHalt();
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:77:9: note: in expansion of macro 'errorExit'
   void errorHalt();
STM32_SDFat:82:3: error: 'file1' was not declared in this scope
   file1.rewind();
STM32_SDFat:88:7: error: 'sd1' was not declared in this scope
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:94:11: note: in expansion of macro 'errorExit'
   void errorHalt();
STM32_SDFat:110:39: error: no matching function for call to 'SdFat::ls(const char [2], int)'
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:110:39: note: candidates are:
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:66:8: note: void SdFat::ls(uint8_t)
   void ls(uint8_t flags = 0);
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:66:8: note:   candidate expects 1 argument, 2 provided
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:67:8: note: void SdFat::ls(Print*, uint8_t)
   void ls(Print* pr, uint8_t flags = 0);
/Users/james/Documents/Arduino/libraries/SdFat/SdFat.h:67:8: note:   no known conversion for argument 1 from 'const char [2]' to 'Print*'
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:115:9: note: in expansion of macro 'errorExit'
   void errorHalt();
Multiple libraries were found for "SPI.h"
 Used: /Users/james/Documents/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI
Multiple libraries were found for "SdFat.h"
 Used: /Users/james/Documents/Arduino/libraries/SdFat
 Not used: /Users/james/Documents/Arduino/libraries/SdFat-master
Multiple libraries were found for "FreeStack.h"
 Used: /Users/james/Documents/Arduino/libraries/SdFat-master
STM32_SDFat:119:39: error: no matching function for call to 'SdFat::ls(const char [2], int)'
/Users/james/Documents/Arduino/STM32_SDFat/STM32_SDFat.ino:119:39: note: candidates are:
Using library SPI at version 1.0 in folder: /Users/james/Documents/Arduino/hardware/Arduino_STM32/STM32F1/libraries/SPI
Using library SdFat in folder: /Users/james/Documents/Arduino/libraries/SdFat (legacy)
Using library SdFat-master at version 1.1.0 in folder: /Users/james/Documents/Arduino/libraries/SdFat-master
exit status 1
That's the whole error output message. Hopefully that can be of some use. TIA.
I would recommend to use my SdFat fork, it is made compatible with the libmaple (aka Roger's and my) core.
