STM32f401 upload
STM32f401 upload
hello all, I have a problem that happens every once in a while with my f401 chip, while uploading code after I press reset to upload the code, computer will say malfunction in chip not recognized , so I have to unplug the chip from the usb and plug it back in after a few attempts it will work again, is it the reset sw getting bad on the chip ? IM using arduino IDE and prog by usb serial.
Re: STM32f401 upload
STM32F401 has DFU mode built in.
Set Boot0=1 and upload method to STM32CubeProgrammer (DFU).
With USB port connected, press reset and upload. Your program should start automatically.
During development, you can leave Boot0=1, putting it back to 0 when you are finished coding.
If you need serial output, set the CDC options to enable serial communications.
The boards I have use a USB-C connector.
STM32CubeProgrammer v2.3.0
USB speed : Full Speed (12MBit/s)
Manuf. ID : STMicroelectronics
Product ID : STM32 BOOTLOADER
SN : 356436553433
FW version : 0x011a
Device ID : 0x0423
Device name : STM32F401xB/C
Flash size : 256 KBytes (default)
Device type : MCU
Device CPU : Cortex-M4
Memory Programming ...
File : Blink.ino.bin
Address : 0x08000000
Erasing internal memory sector 0
erasing sector 0000 @: 0x08000000 done
Download in Progress:
File download complete
Time elapsed during download operation: 00:00:00.511
RUNNING Program ...
Address: : 0x8000000
