missing signal on PA6
stan
Post by stan »
Hi
This is a generator code, I have a signal on PB7 but can't get second output on PB6.
#define SAMPLES 77
#include <libmaple/dma.h>
dma_tube_config dma_cfg, dma_cfg2;
int flag = 0;
int flag1 = 0;
int out = PB6;
int out1 = PB7;
int val[SAMPLES];
int val1[SAMPLES];
int16 shift = 0;
int amp = 40;
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
int ret = 17;
timer_dev *dev = PIN_MAP[out].timer_device;
uint8 cc_channel = PIN_MAP[out].timer_channel;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
void fun()
  flag++;
void fun1()
  flag1++;
void timer_conf()
  timer_dma_set_base_addr(dev, TIMER_DMA_BASE_CCR2);
  timer_dma_set_burst_len(dev1, 1);
  timer_dma_enable_req(dev, cc_channel1);
  timer_set_reload(dev, 102);
  timer_set_prescaler(dev, 0);
  timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
  timer_dma_enable_req(dev1, cc_channel1);
  timer_set_reload(dev1, 102);
  timer_set_prescaler(dev1, 0);
void dma_conf()
  dma_init(DMA1);
  /* T4C2 DMA C4 */
  dma_cfg.tube_dst = &(dev->regs.gen->DMAR);
  dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
  dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
  dma_cfg.tube_src = val;
  dma_cfg.tube_src = val1;
  dma_cfg.tube_src_size = DMA_SIZE_32BITS;
  dma_cfg.tube_nr_xfers = SAMPLES;
  dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH1;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
  dma_cfg.target_data = 0;
  ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg);
void dma_start()
  dma_attach_interrupt(DMA1, DMA_CH4, fun);
  dma_enable(DMA1, DMA_CH4);
  timer_resume(dev1);
    dma_enable(DMA1, DMA_CH1);
  dma_enable(DMA1, DMA_CH2);
void init_wave()
  int i;
  for (i = 0; i < SAMPLES; i++)
    val[i] = 40 + amp * sin(stp * i);
    val1[i] = 40 + amp * sin(stp * i);
   // val1[i] = 40 + amp * cos(stp * i);//
  int i;
  // pinMode(out1, PWM);
  pinMode(out, OUTPUT);
  pinMode(out1, OUTPUT);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
  int i;
    //if ( val1[i]  > 40)
    if ( val1[i]  > 38)
      digitalWrite(PB7, HIGH);
    else
      digitalWrite(PB7, LOW);
Answers: 109
Re: missing signal on PA6
Check your dma conf. You override several params... so only out1 is really set...
stan
Post by stan »
I was checking many times but can't find the problem
In timer_conf, the first
I think it should be dev instead dev1.
stan
Post by stan »
I changed it = no difference
stan
Post by stan »
I turned off the lines related to out1 = PB7, so I have to deal with one channel
#define SAMPLES 77
int flag = 0;
int flag1 = 0;
int out = PB6;
int out1 = PB7;
int val[SAMPLES];
int val1[SAMPLES];
int16 shift = 0;
int amp = 40;
int cnt = 0;
int time_track = 0;
int ret = 17;
//timer_dev *dev1 = PIN_MAP[out1].timer_device;
//uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
void fun()
  flag++;
void fun1()
  flag1++;
void timer_conf()
  timer_dma_set_burst_len(dev, 1);
void dma_conf()
  dma_init(DMA1);
  /* T4C2 DMA C4 */
 // dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
//  dma_cfg.tube_src = val1;
void dma_start()
  //timer_resume(dev1);
void init_wave()
  int i;
  int i;
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
  int i;
    if ( val1[i]  > 38)
    else
, and have this error
Arduino: 1.8.9 (Mac OS X), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), STLink, 72Mhz (Normal), Smallest (default)"
/Users/Documents/Arduino/missing_signal_on_PA6/missing_signal_on_PA6.ino: In function 'void timer_conf()':
missing_signal_on_PA6:43:29: error: 'cc_channel1' was not declared in this scope
/Users/Documents/Arduino/missing_signal_on_PA6/missing_signal_on_PA6.ino:43:29: note: suggested alternative: 'cc_channel'
cc_channel
exit status 1
stan
Post by stan »
alternative suggestion gives signal on PB7
i'm not too sure if you are hitting an issue i've once encountered
for alternate functions such as timer outputs, you'd need to set the alternate function multiplexers registers
to choose the alternate function that you need e.g. timer output
viewtopic.php?p=2681#p2681
stan
Post by stan »
Now I can have signal on PB6 or PB7 but not both on one time.
by making changes in those lines
timer_dma_set_base_addr(dev2, TIMER_DMA_BASE_CCR1);
CCR1, CCR1 = signal only on PB6
CCR1, CCR2 = signal only on PB7
CCR2, CCR2 = signal only on PB7
CCR2, CCR1 =signal only on PB6
#define SAMPLES 100
int val1[SAMPLES];
int val2[SAMPLES];                   // *******************
int amp = 35;
int cnt = 0;
int time_track = 0;
int ret = 17;
int out1 = PB7; // TIM4_CH2 DMA_CH4 .
int out2 = PB6; // TIM4_CH1 DMA_CH3 .                     ***************************
timer_dev *dev1 = PIN_MAP[out2].timer_device;
timer_dev *dev2 = PIN_MAP[out2].timer_device;
void timer_conf()
  // PB7 TIM4_CH2 DMA_CH4
  timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR1); //
  timer_dma_enable_req(dev1, PIN_MAP[out1].timer_channel);
  // PB6 TIM4_CH1 DMA_CH3 .                                  *********************
  timer_dma_set_base_addr(dev2, TIMER_DMA_BASE_CCR);
  timer_dma_set_burst_len(dev2, 1);
  timer_dma_enable_req(dev2, PIN_MAP[out2].timer_channel);
  timer_set_reload(dev2, 102);
  timer_set_prescaler(dev2, 0);
void dma_conf()
  dma_init(DMA1);
  dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);                // PB7
  dma_cfg.tube_dst = &(dev2->regs.gen->DMAR);                // PB6********************
  dma_cfg.tube_src = val1;                                   // PB7
  dma_cfg.tube_src = val2;                                   // PB6********************
  dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;               //PB7
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH1;               //PB6 ********************
  ret = dma_tube_cfg(DMA1, DMA_CH3, &dma_cfg);
void dma_start()
 timer_resume(dev1);
  dma_enable(DMA1, DMA_CH3);
  timer_resume(dev2);
void init_wave()
  int i;
    val1[i] = 50 + amp * sin(stp * i);
    val2[i] = 50 + amp * sin(stp * i);                      //************************
  pinMode(out1, PWM);
  pinMode(out2, PWM);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
