timer = solved
What are you developing?
stan
timer = solved
Post by stan »
HI
I want to have signal on PB7 when PB11 is pressed, I think can be done by attachInterrupt / detachInterrupt in timer or pin PA7.
This is what I was trying, not working.
HardwareTimer pwmtimer3(3);
  pinMode(PA7, PWM);// CH2
  pinMode(PB11, INPUT_PULLDOWN);
  pwmtimer3.pause();
  pwmtimer3.setPrescaleFactor(180);
  pwmtimer3.setOverflow(100 - 1);
  pwmtimer3.setCompare(TIMER_CH2, 50);
  //pwmtimer3.attachCompare1Interrupt(timer3);
  pwmtimer3.refresh();
  pwmtimer3.resume();
  if (digitalRead(PB11) == HIGH)
    attachInterrupt(digitalPinToInterrupt(PA7));
  else {
    detachInterrupt(digitalPinToInterrupt(PA7)) ;
Re: timer
don't think attachInterrupt works that way, an alternative implementation is to pause() the timer in setup() then resume() the timer when pressed.
so one of the if clauses is to pause() the timer the other to resume() the timer
stan
Re: timer
Post by stan »
Thanks for suggestions, problem solved.
  pwmtimer3.pause();
  //pwmtimer3.refresh();
  pwmtimer3.resume();
  if (digitalRead(PB11) == LOW)
Return to “Projects”
