[Solved] I2C OLED Only Displays if Reset is Pressed??
Franke39
Post by Franke39 »
My setup:
• STM32F103C8T6
• ST Arduino core
• 0.96 SSD1306 I2C OLED
• Program: Adafruit "ssd1306_128x64_i2c" example program
The program compiles fine and uploads without issue using ST-Link and serial.
After upload, the program starts and the display works.
BUT if I disconnect the power (provided by the ST-Link or the FTDI USB to TTL adapter) then apply power, the program starts (confirmed by blinking the LED on PC13 I added to troubleshoot) and the display stays dark/off.
It doesn't show anything UNTIL I press reset, then the programs runs as expected and the display is functioning as expected.
I tried another STM32 and it did the exact same thing.
I have also used the same OLEDs on Nano, and the they functioned as expected.
I am going to dig out a logic analyzer and verify the I2C clock & data lines.
Any idea what is happening or how to resolve this?
Franke39
Re: I2C OLED Only Displays if Reset is Pressed??
Post by Franke39 »
UPDATE from logic analyzer:
• Upon start up the OLED address (0x3C) is sent and the OLED responds with a negative acknowledgement / NAK
• After I press reset, the OLED address is sent, and the OLED responds with a positive acknowledgement / ACK
Next steps... get out the DSO and look at the raw signals.
Do you used a bootloader ?
Do you used PU on I2C line ?
Franke39
Post by Franke39 »
fpiSTM wrote: Fri Jan 15, 2021 3:55 pm Do you used a bootloader ?
(Thanks for the quick reply!!)
Answers :)
(1) Before this project, I did load the "STM32duino-bootloader". I didn't want to load a ST USB driver on my Mac, so I erased it (using the STMCubeProgrammer) and reprogrammed from the Arduino IDE using the ST-Link. I believe this erases or overwrites the bootloader.
I also tried a new STM32 that has never had a boot loader flashed to it and had the same result.
(2) Yes, the OLED board uses two 4.7K pull up resistors and did function as expected on a Nano clone.
I have have powered the OLED with 5 and 3.3 volts and get the same result.
ALSO....
I have also learned that a NAK is the same as the I2C device not responding.
In the Adafruit SSD1306 example program, I put in a 1 second delay after this line:
Display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
That made no difference...
I should have it on the scope in the next hour and will update then.
It looks like OLED controller might need more time to start then STM. Try adding delay before initializing display.
I also recommend u8g2 library. It's faster than adafruit and much more fonts. You can also create own font quite easily.
Franke39
Post by Franke39 »
GonzoG wrote: Fri Jan 15, 2021 9:14 pm It looks like OLED controller might need more time to start then STM. Try adding delay before initializing display.
Thanks, for the reply.
Tonight I will:
• Check the I2C clock (SCK) frequency with logic analyzer. It should be 400Khz
• Scope the start up of the 3.3 rail, SCK and SDA and compare to the startup of the Nano
• Add 1 second delay at the very beginning of the program
• Try the u8g2 library
For the product I am developing, I really want to use the I2C OLEDs as I can easily display information on two 128x64 with only 4 wires.
PLUS with the I2C multiplexer, I can add up to 8 more displays.
I hope to update this thread in a few hours. :)
Franke39
Post by Franke39 »
Adding a 25ms delay right after StartUp() resolved the issue.
20ms was not enough, so I will add a buffer just in case temperature is an issue and use 100ms.
That is a long time to a uC, but the end user won't notice a slower boot up.
stan
Re: [Solved] I2C OLED Only Displays if Reset is Pressed??
Post by stan »
Look at this program it has ;
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
In instruction is says that 3 wire connection is needed but I using only 2, SDA and SCL
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
//#if (SSD1306_LCDHEIGHT != 64)
#if (SSD1306_LCDHEIGHT != 32)
///#error("Height incorrect, please fix Adafruit_SSD1306.h!");
int sensorValue = 0;
int voltage = 0;
const int analogInPin = PA7;
//display.invertDisplay(true); // invert the colours of led display
//display.invertDisplay(false);
//display.drawPixel(10, 10, WHITE);//to highlight a particular pixel
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize I2C addr to 0x3C ( for 128x64 Display )
  display.clearDisplay(); // clear the display before starting the program to avoid adafruit splashscreen ( *we can also skip it by modifing header file )
  // display.drawBitmap(x-axis position, y-axis position, bitmap data, bitmap width, bitmap height, color)
  display.drawPixel(100, 15, WHITE);//to highlight a particular pixel
  display.setTextSize(4);
  display.setTextColor(WHITE);
  sensorValue = analogRead(analogInPin);
  voltage = map(sensorValue, 0, 4096, 0, 3300);
  display.setCursor(0, 0);
  display.print(voltage);
  display.display();
stan
Post by stan »
Can you connect OLED to PB10 and PB11 and tell me the scanner results ?
Franke39
Post by Franke39 »
The number of connections/wires needed is determined by the OLED display. The Adafruit ones have a dedicated connection for reset, (and may also have optional SPI) BUT the cheaper ones don't. I am using one of the cheaper ones and it has 4 connections: ground, Vcc, SCL and SDA.
When you asked for a "scan" I assume you are asking for the results of a I2C scanner. Most I2C scanners I see, are for the Uno/Nano type boards and only look for one I2C bus. If you use that type of I2C scanner, it doesn't know to look on the second I2C bus (SCL2 @ PB10, SDA2 @ PB11)... It will only show the first I2C bus (SCL1 @ PB6, SDA1 @ PB7)
If you want to use the second I2C bus you need to add these lines before setup()
 #define OLED_RESET -1 // use -1 if no reset pin on OLED board
// use second I2C bus on STM32F103
// TwoWire Wire2(SDA2, SCL2);
TwoWire Wire2(PB11, PB10);
Adafruit_SSD1306 Display
// below is for a 128x64 OLED. Other option is 128x32 for smaller OLED
(128, 64, &Wire2, OLED_RESET);
Then after setup():
   Display1.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // if nothing is displayed using 0x3C, try 0x3D
  //  Display1
  Display1.clearDisplay();
  Display1.setTextSize(2);
  Display1.setTextColor(WHITE, BLACK);
  Display1.setCursor(0, 0 );
  Display1.println("Display");
  Display1.println("I2C #2 @ 3C");
  Display1.display();
I hope this helps :)
