NUCLEO-G474RE BMP183 Output Problem
Re: NUCLEO-G474RE BMP183 Output Problem
Ok you use the STM32 core anyway your sketch is not correct. Try the code I've put above.
MasterT
Post by MasterT »
It's always good idea to test SPI separately, w/o sensor connected. Try build-in the IDE loop back test:
_ File/Examples/SRM32duino_Examples/NoNReg/SPI_Loop
enesert
Post by enesert »
fpiSTM wrote: Sat May 22, 2021 6:07 pm Ok you use the STM32 core anyway your sketch is not correct. Try the code I've put above.
I tried your sketch. It gave same output. Is there any possibility of a problem in library?
enesert
Post by enesert »
MasterT wrote: Sat May 22, 2021 6:30 pm It's always good idea to test SPI separately, w/o sensor connected. Try build-in the IDE loop back test:
It can pass the test. There is no problem.
enesert wrote: Sat May 22, 2021 7:18 pm
And you properly wire the sensor on pin D9, D11,D12 and D13 ?
If the SPI loop works so probably an issue with the Library. Maybe SPI clock speed. Seems the max frequency for this sensor is 8MHz as stated here:
https://github.com/adafruit/Adafruit_BM ... pp#L78-L83
but by default max SPI clock speed is set to 4 MHz so this should be correct.
enesert wrote: Sat May 22, 2021 7:19 pm
Did it pass test when connected to D14/D15 ??
enesert
Post by enesert »
fpiSTM wrote: Sun May 23, 2021 3:34 pm
Yes i wired it like that. Aha yes i think its about frequency. I will check it and write here results.
enesert
Post by enesert »
GonzoG wrote: Sun May 23, 2021 3:47 pm
Nope it passed D12 D11
enesert
Post by enesert »
enesert wrote: Mon May 24, 2021 6:59 pm
Why i cant change spi freq. How can i set to 8 mhz spi pins? I added this code to void setup:
  SPI.begin();
  SPI.setClockDivider(6);
MasterT
Post by MasterT »
Try:
  // SPI.begin(CS_PIN);
  SPI.beginTransaction(CS_PIN, SPISettings(8000000, MSBFIRST, SPI_MODE0));
