[SOLVED]Imposible to flash with STLink v2 key ( STM32F1xx and STM32F4xx)
jcbuntu
Post by jcbuntu »
Hello.
Since most days, i try to flash STM32 boards with STLink key ( v2) and STM32duino last version ( recently uploaded).
My PC ( intel i7 - 16GB RAM ...) run with Linux Ubuntu 20.04.2 64 bits.
All the Arduino files are installed on a USB drive in portable mode. STM32duino is installed in this hard USB drive, in "hardware" directories of Arduino 1-8-13 system.
Flash is OK with USB-Serial converter ( FTDI) on Maple mini and Blue pils.
When i want use STLink key, it's failing. "Port" field of the IDE stay in grey. The STLink key is recognize bye the OS and benefit of number 49 udev rule.
On terminal, STM32duino IDE say :
arduino-1.8.13/hardware/Arduino_STM32-master/tools/linux/stlink/st-flash: error while loading shared libraries: libusb-1.0.so.0: cannot open shared object file: No such file or directory
I'd installed libusb-1.0-dev librarie but same issue.
If this problem is not important for STM32F1xx witch can be flashed in serial mode, it's more badly with STM32F4xx whitch can only be fashed with stlink key ... and it's my project !
Re: Imposible to flash with STLink v2 key ( STM32F1xx and STM32F4xx)
You use Arduino_STM32 or STM32duino?
Please post the complete flashing process output.
He used https://github.com/rogerclarkmelbourne/Arduino_STM32/ as we can see in the terminal log:
jcbuntu
Post by jcbuntu »
Hello.
Thank you for interest of my problem.
As fpiSTM say, y use Arduino_STM32-master, which is in hardware directorie of Arduino system. Before say the complete processing, i would repeat that it's not a problem for STM32F1xx wich can be flash by UART1 but for STM32F4xx wich can be flash only whith STlibnk v2 key. But for simplify, i've the same fail when i want flash a STM32F1xx ( chinese blue pill) with STlibnk v2 key and example after is with a STM32F407VE board.
Hardware linkage :
STLink key F407VE board
RST x
SWCLK SWCLK
SWDIO SWDIO
GND GND
3.3v 3.3v
Arduino IDE field "Type of board" = Generic STM32F407v series
Arduino IDE field "USB configuration" = USB serial (CDC)
First power up, with BOOT0 on GND ->
STLink key = Blue LED ON
F407VE = power LED ON and LED 2 and 3 BLINK
Arduino IDE, field "port" = grey - field "upload method" = STLink
Linux system command "lsusb" =
ID 0483:3748 STMicroelectronics ST-LINK/V2
Linux system symbolic link ( /dev) = stlinkv2_5 ( as 49-stlinkv2.rules file say - Roger Clark install system)
Perhaps Arduino IDE would have ttyUSB0 symbolic link ?
Second power up, with BOOT0 on 3.3v + Reset button one shot ->
F407VE = power LED ON and LED 2 and 3 OFF
Try sequence with blink example file and clic on upload Arduino IDE button :
Le croquis utilise 18040 octets (3%) de l'espace de stockage de programmes. Le maximum est de 514288 octets.
Les variables globales utilisent 5544 octets (4%) de mémoire dynamique, ce qui laisse 125528 octets pour les variables locales. Le maximum est de 131072 octets.
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/tools/linux/stlink/st-flash: error while loading shared libraries: libusb-1.0.so.0: cannot open shared object file: No such file or directory
No LED blink ( STLink key or board) but, for me, it's correct because Arduino IDE dont know the port of communication ( Arduino IDE, field "port" = grey ).
So, i don't know where is THE problem !
Please set "verbose" on in Arduino settings for compilation, then try again and post here the message.
fredbox
Post by fredbox »
Official STM32 v2.0 core with STM32Cube programmer makes this process easy.
Sketch uses 10316 bytes (1%) of program storage space. Maximum is 524288 bytes.
Global variables use 620 bytes (0%) of dynamic memory, leaving 130452 bytes for local variables. Maximum is 131072 bytes.
                        STM32CubeProgrammer v2.3.0
ST-LINK SN  : 30FF6F065242383956401443
ST-LINK FW  : V2J29S7
Voltage     : 3.22V
SWD freq    : 4000 KHz
Connect mode: Under Reset
Reset mode  : Hardware reset
Device ID   : 0x413
Device name : STM32F405xx/F407xx/F415xx/F417xx
Flash size  : 1 MBytes (default)
Device type : MCU
Device CPU  : Cortex-M4
Memory Programming ...
  File          : Blink.ino.bin
  Address       : 0x08000000
Erasing internal memory sector 0
Download in Progress:
File download complete
Time elapsed during download operation: 00:00:01.158
RUNNING Program ...
  Address:      : 0x8000000
Application is running
jcbuntu
Post by jcbuntu »
Fredbox -> OK, it's an issue if i can't use Arduino IDE ... but i prefer this IDE for portability of code with Arduino MKRZ or Due ...
Hello, Stevestrong.
The result is at bottom ... and very long ! Verbose mode for compilation and flash.
My message contains too much characters.
Your message contains 100052 characters.
The maximum number of allowed characters is 60000.
So i post in two parts !
Part one ->
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/arduino-builder -dump-prefs -logger=machine -hardware /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware -hardware /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages -tools /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/tools-builder -tools /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/tools/avr -tools /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages -built-in-libraries /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/libraries -libraries /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/sketchbook/libraries -fqbn=Arduino_STM32-master:STM32F4:generic_f407v:usb_cfg=usb_serial,upload_method=STLinkMethod,opt=osstd -ide-version=10813 -build-path /tmp/arduino_build_64894 -warnings=none -build-cache /tmp/arduino_cache_82205 -prefs=build.warn_data_percentage=75 -verbose /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/examples/01.Basics/Blink/Blink.ino
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/arduino-builder -compile -logger=machine -hardware /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware -hardware /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages -tools /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/tools-builder -tools /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/tools/avr -tools /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages -built-in-libraries /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/libraries -libraries /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/sketchbook/libraries -fqbn=Arduino_STM32-master:STM32F4:generic_f407v:usb_cfg=usb_serial,upload_method=STLinkMethod,opt=osstd -ide-version=10813 -build-path /tmp/arduino_build_64894 -warnings=none -build-cache /tmp/arduino_cache_82205 -prefs=build.warn_data_percentage=75 -verbose /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/examples/01.Basics/Blink/Blink.ino
Using board 'generic_f407v' from platform in folder: /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4
Using core 'maple' from platform in folder: /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4
Detecting libraries used...
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -w -x c++ -E -CC -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /tmp/arduino_build_64894/sketch/Blink.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -w -x c++ -E -CC -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /tmp/arduino_build_64894/sketch/Blink.ino.cpp -o /tmp/arduino_build_64894/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_64894/preproc/ctags_target_for_gcc_minus_e.cpp
Compilation du croquis...
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /tmp/arduino_build_64894/sketch/Blink.ino.cpp -o /tmp/arduino_build_64894/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v/generic_f407v.cpp -o /tmp/arduino_build_64894/core/generic_f407v.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -x assembler-with-cpp -MMD -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/start.S -o /tmp/arduino_build_64894/core/libmaple/start.S.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -x assembler-with-cpp -MMD -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/stm32_vector_table.S -o /tmp/arduino_build_64894/core/libmaple/stm32_vector_table.S.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -x assembler-with-cpp -MMD -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/stm32_isrs.S -o /tmp/arduino_build_64894/core/libmaple/stm32_isrs.S.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -x assembler-with-cpp -MMD -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/exc.S -o /tmp/arduino_build_64894/core/libmaple/exc.S.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/dcmi.c -o /tmp/arduino_build_64894/core/libmaple/dcmi.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/dac.c -o /tmp/arduino_build_64894/core/libmaple/dac.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/bkp.c -o /tmp/arduino_build_64894/core/libmaple/bkp.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/dmaF4.c -o /tmp/arduino_build_64894/core/libmaple/dmaF4.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/ethernet.c -o /tmp/arduino_build_64894/core/libmaple/ethernet.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/itoa.c -o /tmp/arduino_build_64894/core/itoa.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/adc.c -o /tmp/arduino_build_64894/core/libmaple/adc.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/avr/dtostrf.c -o /tmp/arduino_build_64894/core/avr/dtostrf.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/exti.c -o /tmp/arduino_build_64894/core/libmaple/exti.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/fpu.c -o /tmp/arduino_build_64894/core/libmaple/fpu.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/fsmc.c -o /tmp/arduino_build_64894/core/libmaple/fsmc.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/gpio.c -o /tmp/arduino_build_64894/core/libmaple/gpio.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/i2c.c -o /tmp/arduino_build_64894/core/libmaple/i2c.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/iwdg.c -o /tmp/arduino_build_64894/core/libmaple/iwdg.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/libc_repl.c -o /tmp/arduino_build_64894/core/libmaple/libc_repl.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/nvic.c -o /tmp/arduino_build_64894/core/libmaple/nvic.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/pwr.c -o /tmp/arduino_build_64894/core/libmaple/pwr.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/rccF4.c -o /tmp/arduino_build_64894/core/libmaple/rccF4.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/rtc.c -o /tmp/arduino_build_64894/core/libmaple/rtc.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/sdio.c -o /tmp/arduino_build_64894/core/libmaple/sdio.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/spi.c -o /tmp/arduino_build_64894/core/libmaple/spi.c.o
jcbuntu
Post by jcbuntu »
Second part, for Stevestrong. But another problem of message size.
Your message contains 63982 characters.
A thirth part will arive !
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/spi_f4.c -o /tmp/arduino_build_64894/core/libmaple/spi_f4.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/start_c.c -o /tmp/arduino_build_64894/core/libmaple/start_c.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/syscalls.c -o /tmp/arduino_build_64894/core/libmaple/syscalls.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/systick.c -o /tmp/arduino_build_64894/core/libmaple/systick.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/timer.c -o /tmp/arduino_build_64894/core/libmaple/timer.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/timer_map.c -o /tmp/arduino_build_64894/core/libmaple/timer_map.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usart.c -o /tmp/arduino_build_64894/core/libmaple/usart.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/util.c -o /tmp/arduino_build_64894/core/libmaple/util.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/usb.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/usb.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/STM32_USB_Device_Library/Class/cdc/src/usbd_cdc_core.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_Device_Library/Class/cdc/src/usbd_cdc_core.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/STM32_USB_Device_Library/Core/src/usbd_core.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_Device_Library/Core/src/usbd_core.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/STM32_USB_Device_Library/Core/src/usbd_ioreq.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_Device_Library/Core/src/usbd_ioreq.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/STM32_USB_Device_Library/Core/src/usbd_req.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_Device_Library/Core/src/usbd_req.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/STM32_USB_OTG_Driver/src/usb_core.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_OTG_Driver/src/usb_core.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/STM32_USB_OTG_Driver/src/usb_dcd.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_OTG_Driver/src/usb_dcd.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/STM32_USB_OTG_Driver/src/usb_dcd_int.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_OTG_Driver/src/usb_dcd_int.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/VCP/misc.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/VCP/misc.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/VCP/usb_bsp.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/VCP/usb_bsp.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/VCP/usbd_cdc_vcp.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/VCP/usbd_cdc_vcp.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/VCP/usbd_desc.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/VCP/usbd_desc.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -g -Os -Wall -MMD -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4/VCP/usbd_usr.c -o /tmp/arduino_build_64894/core/libmaple/usbF4/VCP/usbd_usr.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/ext_interrupts.cpp -o /tmp/arduino_build_64894/core/ext_interrupts.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/WString.cpp -o /tmp/arduino_build_64894/core/WString.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/Stream.cpp -o /tmp/arduino_build_64894/core/Stream.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/cxxabi-compat.cpp -o /tmp/arduino_build_64894/core/cxxabi-compat.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/HardwareTimer.cpp -o /tmp/arduino_build_64894/core/HardwareTimer.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/Print.cpp -o /tmp/arduino_build_64894/core/Print.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/boards.cpp -o /tmp/arduino_build_64894/core/boards.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/IPAddress.cpp -o /tmp/arduino_build_64894/core/IPAddress.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/new.cpp -o /tmp/arduino_build_64894/core/new.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/pwm.cpp -o /tmp/arduino_build_64894/core/pwm.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/usb_serial.cpp -o /tmp/arduino_build_64894/core/usb_serial.cpp.o
jcbuntu
Re: Imposible to flash with STLink v2 key ( STM32F1xx and STM32F4xx)
Post by jcbuntu »
Thirth part ... and last ! Big work to read this ...
I've read in Arduino IDE help that Ports should be named ttyACMx or ttyUSBx . And it's not that is wrote in .rules files ...
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/wirish_analog.cpp -o /tmp/arduino_build_64894/core/wirish_analog.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/wirish_digital.cpp -o /tmp/arduino_build_64894/core/wirish_digital.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/wirish_math.cpp -o /tmp/arduino_build_64894/core/wirish_math.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/wirish_shift.cpp -o /tmp/arduino_build_64894/core/wirish_shift.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/wirish_time.cpp -o /tmp/arduino_build_64894/core/wirish_time.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/HardwareSerial.cpp -o /tmp/arduino_build_64894/core/libmaple/HardwareSerial.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -g -Os -Wall -MMD -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DERROR_LED_PIN=PA7 -mcpu=cortex-m4 -DARDUINO=10813 -DVARIANT_generic_f407v -DARDUINO_ARCH_STM32F4 -DCRYSTAL_FREQ=8 -DLED_BUILTIN=PA6 -DSERIAL_USB -DUSER_ADDR_ROM=0x08000000 -mthumb -D__STM32F4__ -DSTM32F4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/system/libmaple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/usbF4 -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple -I/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v /media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/cores/maple/libmaple/main.cpp -o /tmp/arduino_build_64894/core/libmaple/main.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/exc.S.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/start.S.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/stm32_isrs.S.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/stm32_vector_table.S.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/avr/dtostrf.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/itoa.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/adc.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/bkp.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/dac.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/dcmi.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/dmaF4.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/ethernet.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/exti.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/fpu.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/fsmc.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/gpio.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/i2c.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/iwdg.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/libc_repl.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/nvic.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/pwr.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/rccF4.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/rtc.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/sdio.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/spi.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/spi_f4.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/start_c.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/syscalls.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/systick.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/timer.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/timer_map.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usart.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_Device_Library/Class/cdc/src/usbd_cdc_core.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_Device_Library/Core/src/usbd_core.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_Device_Library/Core/src/usbd_ioreq.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_Device_Library/Core/src/usbd_req.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_OTG_Driver/src/usb_core.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_OTG_Driver/src/usb_dcd.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/STM32_USB_OTG_Driver/src/usb_dcd_int.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/VCP/misc.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/VCP/usb_bsp.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/VCP/usbd_cdc_vcp.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/VCP/usbd_desc.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/VCP/usbd_usr.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/usbF4/usb.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/util.c.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/HardwareTimer.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/IPAddress.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/Print.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/Stream.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/WString.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/boards.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/cxxabi-compat.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/ext_interrupts.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/HardwareSerial.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/libmaple/main.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/new.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/pwm.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/usb_serial.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/wirish_analog.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/wirish_digital.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/wirish_math.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/wirish_shift.cpp.o
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino_build_64894/core/core.a /tmp/arduino_build_64894/core/wirish_time.cpp.o
Archivage du noyau construit (mise en cache) dans :  /tmp/arduino_cache_82205/core/core_38bac80489b9a68b83c79a9bd45e11dd.a
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -Os -Wl,--gc-sections -mcpu=cortex-m4 -T/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v/ld/jtag.ld -Wl,-Map,/tmp/arduino_build_64894/Blink.ino.map -L/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/STM32F4/variants/generic_f407v/ld -Wl,--wrap=atexit,--wrap=__cxa_atexit,--wrap=exit -specs=nano.specs -o /tmp/arduino_build_64894/Blink.ino.elf -L/tmp/arduino_build_64894 -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group /tmp/arduino_build_64894/sketch/Blink.ino.cpp.o /tmp/arduino_build_64894/core/generic_f407v.cpp.o -Wl,--whole-archive /tmp/arduino_build_64894/core/core.a -Wl,--no-whole-archive -Wl,--end-group
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary /tmp/arduino_build_64894/Blink.ino.elf /tmp/arduino_build_64894/Blink.ino.bin
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/portable/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /tmp/arduino_build_64894/Blink.ino.elf
Le croquis utilise 18040 octets (3%) de l'espace de stockage de programmes. Le maximum est de 514288 octets.
Les variables globales utilisent 5544 octets (4%) de mémoire dynamique, ce qui laisse 125528 octets pour les variables locales. Le maximum est de 131072 octets.
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/tools/linux/stlink_upload /tmp/arduino_build_64894/Blink.ino.bin
/media/jean/Trav_01/Electronik/Arduino/Arduino_sys/arduino-1.8.13/hardware/Arduino_STM32-master/tools/linux/stlink/st-flash: error while loading shared libraries: libusb-1.0.so.0: cannot open shared object file: No such file or directory
Maybe you have to install libusb-1.0?
I do not have experience with linux at all.
Return to “STLink”
