How to use analogWrite
forfrends
Post by forfrends »
Hello!
Tell me how to do analogWrite correctly? I use simple code, but it does not work, the LED just turns on and off:
const int thisPin = PC13;
    pinMode(thisPin, OUTPUT);
    for (int brightness = 0; brightness < 65536; brightness++) {
      analogWrite(thisPin, brightness);
      delay(10);
Answers: 109
Re: How to use analogWrite
Don't know which board you use but the PC13 must have PWM capabilities.
Moreover the analogWrite has a default resolution so using 65535 values is not good, default is 8bits so there is 255 values.
https://www.arduino.cc/reference/en/lan ... alogwrite/
forfrends
Post by forfrends »
I'm sorry, I forgot to indicate board. I am using STM32F103S8T6 (Blue Pill). The kernel is using this: https://github.com/stm32duino/Arduino_Core_STM32
For some reason, AnalogWright does not work. I tried like this, the result is the same:
    pinMode(PC13, OUTPUT);
    analogWrite(PC13, 64);
The LED either turns on or off. There is no PWM (I checked with an oscilloscope).
forfrends
Post by forfrends »
Hmm ... it’s not clear ... I just replaced PC13 with PA3 (for the test). There is PWM on PA3, but not on PC13. It seems that the PWM core is not configured for all pins.
Answers: 109
forfrends wrote: Wed Jan 22, 2020 7:56 am Hmm ... it’s not clear ... I just replaced PC13 with PA3 (for the test). There is PWM on PA3, but not on PC13. It seems that the PWM core is not configured for all pins.
So if there is no PWM linked to PC13, the analogWrite simply use it as a digitla IO. If the requested value is less than the half of the resolution value it is LOW else HIGH.
Moreover if the pin has DAC capabilities then the DAC is used in prority.
i've not really tried stm32 core deep in, but if the speeds isn't too fast. i'd like to suggest one could hook timer interrupts. that would kind of allow one to pwm any pins by doing so using gpio. there are real speed limits with this approach though. it seemed gpio bit banging often has rather low thresholds, but it'd take experiments to find out. so for those needing the speeds, using actual hardware timer pins would be the best approach.
but if one wants 'generic' pwm on any pins, timer interrupts could be a 'work around'
Answers: 109
There is a lot of pins linked to a Timer.
The analogWrite well use the timer if available on the requested pins.
One other solution is to use directly the HardwareTimer api:
https://github.com/stm32duino/wiki/wiki ... er-library
This is what is called by the analogWrite when Timer is available.
To simulate a pwm on a pin without timer, this is the same, use the HardwareTimer librarly. This is done for the servo.
For analogWrite it is also possible to change frequency and resolution:
 * \brief Set the resolution of analogWrite parameters. Default is 8 bits (range from 0 to 255).
 * \param res
extern void analogWriteResolution(int res);
 * \brief Set the frequency of analogWrite. Default is PWM_FREQUENCY (1000) in Hertz.
 * \param freq
extern void analogWriteFrequency(uint32_t freq);
