NUCLEO-H7A3ZI-Q Code loads but does not run
Re: NUCLEO-H7A3ZI-Q Code loads but does not run
Hard to tell.
Could your share your changes. Ideally on GitHub.
Are you using git repo?
I've track down the first issue with the build.
The gerated product line is not correct:
- GenH7.menu.pnum.GENERIC_H7A3ZITXQ.build.product_line=STM32H7A3xx
+ GenH7.menu.pnum.GENERIC_H7A3ZITXQ.build.product_line=STM32H7A3xxQ
Like this no need to defined the PWR_DIRECT_SMPS_SUPPLY as it is properly defined as SMPS is defined.
I will fix the script generating this line
@byquip
Please, could you file an issue on GitHub?
byquip
Post by byquip »
@fpiSTM
thank you for response,
I will do the tests and report the issue
@byquip
Your last issue is the RAM size in the boards.txt:
- maximum_data_size=1458176
+ maximum_data_size=1048576
1458176 is the total but in the ldscript RAM is 1024k.
byquip
Post by byquip »
fpiSTM wrote: Mon Jan 13, 2025 1:38 pm
changed but same problem, after upload no reaction.
I've tested and blink works.
Here my branch with the generic:
https://github.com/fpistm/Arduino_Core_ ... o_H7A3ZI_Q
byquip
Post by byquip »
I did several tests and both yours and mine branches works.
I just realized that LED_BUILTIN is PNUM_NOT_DEFINED and not PB0.
Thank you for support
Welcome. Thank for the issue raised, I will fix it.
