Page 2 of 3
Re: NUCLEO-H7A3ZI-Q Code loads but does not run
Posted: Thu Jan 09, 2025 3:38 pm
Hard to tell.
Could your share your changes. Ideally on GitHub.
Are you using git repo?
Posted: Thu Jan 09, 2025 4:13 pm
by byquip
Posted: Fri Jan 10, 2025 5:05 pm
I've track down the first issue with the build.
The gerated product line is not correct:
- GenH7.menu.pnum.GENERIC_H7A3ZITXQ.build.product_line=STM32H7A3xx
+ GenH7.menu.pnum.GENERIC_H7A3ZITXQ.build.product_line=STM32H7A3xxQ
Like this no need to defined the PWR_DIRECT_SMPS_SUPPLY as it is properly defined as SMPS is defined.
I will fix the script generating this line
Posted: Sat Jan 11, 2025 9:22 am
@byquip
Please, could you file an issue on GitHub?
Posted: Mon Jan 13, 2025 8:07 am
by byquip
@fpiSTM
thank you for response,
I will do the tests and report the issue
Posted: Mon Jan 13, 2025 1:38 pm
@byquip
Your last issue is the RAM size in the boards.txt:
- maximum_data_size=1458176
+ maximum_data_size=1048576
1458176 is the total but in the ldscript RAM is 1024k.
Posted: Mon Jan 13, 2025 1:46 pm
by byquip
fpiSTM wrote: Mon Jan 13, 2025 1:38 pm
changed but same problem, after upload no reaction.
Posted: Mon Jan 13, 2025 1:49 pm
I've tested and blink works.
Here my branch with the generic:
https://github.com/fpistm/Arduino_Core_ ... o_H7A3ZI_Q
Posted: Mon Jan 13, 2025 3:29 pm
by byquip
I did several tests and both yours and mine branches works.
I just realized that LED_BUILTIN is PNUM_NOT_DEFINED and not PB0.
Thank you for support
Posted: Mon Jan 13, 2025 3:41 pm
Welcome. Thank for the issue raised, I will fix it.
