nucleo-H743Zi clock misconfiguration. V.2.0.0.
MasterT
Post by MasterT »
File: variant_NUCLEO_H743ZI.cpp
Having hard time to make SPI working on nucleo-H743ZI2, noticed that
clock to SPI123 selector default settings is PLL1-Q1, same time divider set to 2.
  RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
  RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
  RCC_OscInitStruct.PLL.PLLN = 120;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
Max freq. for this line is 200 Mhz, Table 59. Kernel clock distribution overview RM0433. Divider 2 means 480 MHz
Answers: 109
Re: nucleo-H743Zi clock misconfiguration. V.2.0.0.
Hi @MasterT
yes you're right there is a mistake here.
I was currently looking an issue with SPI on H7 and found this issue also.
Thanks for reporting this will be fixed soon.
MasterT
Post by MasterT »
I try SPI_loop example, provided by IDE. It's not working as it is on H743zi, than I replace this assignment:
//  SPI.setMOSI(MOSI_PIN);
//  SPI.setMISO(MISO_PIN);
//  SPI.setSCLK(SCK_PIN);
  SPI.setMOSI(PA7);
  SPI.setMISO(PA6);
  SPI.setSCLK(PA5);
and it did a trick. I was not able to locate PIN_SPI_MOSI PIN_SPI_MISO PIN_SPI_SCK PIN_SPI_SS anywhere in H7 files, so this is probably a reason for failure.
Answers: 109
MasterT wrote: Tue May 11, 2021 1:04 pm I was not able to locate PIN_SPI_MOSI PIN_SPI_MISO PIN_SPI_SCK PIN_SPI_SS anywhere in H7 files, so this is probably a reason for failure.
By default they are set to:
https://github.com/stm32duino/Arduino_C ... .h#L43-L65
A variant can redefine them. In the case of Nucleo-H743ZI they are not redefined as they are correct.
https://github.com/stm32duino/Arduino_C ... #L150-L152
By default the SPI_loop example use them so strange you need to redefined them. I've tested on a Nucleo H743ZI2 and had no issue with default example.
Return to “PR's bugs and enhancements”
