[SOLVED]: Does multiple calls to analogWrite may lead to weird behavior?
Step73
Post by Step73 »
I wrote a simple fade function. I would like to use my own because I'm going to extend with some specific features.
Here how it should work:
typedef struct
  unsigned long refTime;
  int pin;
  float m;
  float q;
  float current;
  float duration;
  bool ended;
} Led_t;
Led_t led;
void led_fade(float target, float duration)
  if (target < 0.0) target = 0.0;
  target = target * 255.0 / 100.0;
  if (target > 255.0) target = 255.0;
  if (duration < 0) duration = 0;
  _led.refTime = millis();
  _led.duration = duration;
  _led.ended = false;
  _led.m = (target - _led.current) / duration;
  _led.q = _led.current;
void process_led()
  unsigned long currTime = millis();
  float t = ((float)currTime - _led.refTime) / 1000.0;
  if (t < _led.duration)
      _led[i].current = _led.m * t + _led.q;
      analogWrite(_led.pin, _led.current);
  else
      if (!_led.ended)
        _led.ended = true;
Usage:
  _led.refTime = currTime;
  _led.current = 0;
  _led.pin = LED_PIN;
  _led.ended = true;
  process_led();
  //when some conditions met:
  led_fade(100.0, 5.0);
It works, but during the transitions, the PWM signal is not good at all. With the oscilloscope I see another high-frequency PWM signal during the high level cycles. It goes away until I reach a stead-state. Are there any problems to call so frequently the `analogWrite()` function?
I may use the HardwareTimer but this is just a simple example.
In the real code, I have all the 20 pins pwm-ready for Nucleo F429ZI board and the user may select at run-time how many of them control in PWM.
Or I can pass any "pwm" pin to `setPWM` function?
Re: Does multiple calls to analogWrite may lead to weird behavior?
analogWrite() do all required init on each call so this is not efficient.
Step73
Post by Step73 »
fpiSTM wrote: Wed Jan 15, 2020 3:11 pm analogWrite() do all required init on each call so this is not efficient.
Got it.
I'm trying to use hardware timers. The frequency setting is incredible precise!
But I still have the weird behavior: when fading I see a 32 kHz square wave super-imposed on the actual PWM.
Here a minimal but complete sketch:
#define PWM_FREQ  1000
#define PWM_PIN   PA0
typedef struct
  int pin;
  uint32_t channel;
  HardwareTimer *timer;
  float m;
  float q;
  float current;
  float duration;
} Led_t;
Led_t _led;
  _led.current = 0;
  _led.pin = PWM_PIN;
  TIM_TypeDef *Instance = (TIM_TypeDef *)pinmap_peripheral(digitalPinToPinName(_led.pin), PinMap_PWM);
  _led.channel = STM_PIN_CHANNEL(pinmap_function(digitalPinToPinName(_led.pin), PinMap_PWM));
  _led.timer = new HardwareTimer(Instance);
  _led.timer->setPWM(_led.channel, _led.pin, PWM_FREQ, 0);
  // start fade to 80% in 10 s
  _led.duration = 10.0;
  _led.m = (80.0 - _led.current) / _led.duration;
      _led.current = _led.m * t + _led.q;
      _led.timer->setPWM(_led.channel, _led.pin, PWM_FREQ, _led.current);
I attach some pictures: two taken during fading (where you can see the "noise") and another at the end (good PWM).
Image Image Image
What am I missing this time?
Step73
Post by Step73 »
Solved using:
_led.timer->setCaptureCompare(_led.channel, _led.current, PERCENT_COMPARE_FORMAT);
