Clock frequency
mebab
Answers: 4
Clock frequency
Post by mebab »
Hi everybody,
I have already tested NucleoL64 with regard to changing the clock frequency. I have developed an STM32L476 based system where I change the clock frequency again to see the possible power saving. I use CubeMX to generate the code and update the variant_generic.cpp afterward. However, there is no change in power consumption changing frequency from 2 to 80 MHz. The following represents the WEAK related to System Clock Config:
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  RCC_OscInitStruct.MSICalibrationValue = 0;
  RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_5;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
    Error_Handler();
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV8;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_I2C3
                              |RCC_PERIPHCLK_ADC;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_SYSCLK;
  PeriphClkInit.I2c3ClockSelection = RCC_I2C3CLKSOURCE_SYSCLK;
  PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_SYSCLK;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    Error_Handler();
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
    Error_Handler();
I know that it is better to include this WEAK in my Arduino code. But for now, I want to know if there is anything wrong with changing the clock frequency?
Thanks for any help
Re: Clock frequency
take a look at the datasheet, or port over the CMSIS SystemCoreClockUpdate() to your environment and see what it reports.
Re: Clock frequency
if you want to reduce power you need to turn off the *peripherals* like your gpios, spi, uart, i2c, adc, timers, usb etc
mebab
Answers: 4
Re: Clock frequency
Post by mebab »
Thank you! I will do so.
Re: Clock frequency
and normally to do nothing there is a strange command
	asm("wfi");
wait for interrupt, normally you are waiting for systick interrupt 1ms intervals, if you disable systick, millis() and delay() won't work.
but otherwise this means sleep till the next interrupt (which is normally systick)
mebab
Answers: 4
Re: Clock frequency
Post by mebab »
ag123 wrote: Thu Jun 10, 2021 12:37 pm and normally to do nothing there is a strange command
	asm("wfi");
Thank you! I have already used this.
