L432KC and NRF24L01
spookyy524
L432KC and NRF24L01
Post by spookyy524 »
I cannot get these L432KC nucleo boards communicating over NRF24L01 transceivers. I am very confident on the wiring as I have checked it many times so I feel like it is somehow a software issue. However, running the exact same code on two f411RE nucleo boards it works perfectly. I need to get the two L4 boards communicating for this project and I need help!
I have attached my transmit and receive code below and I would really appreciate any advice!
Transmit:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(7,8); //CE, CSN
const byte address[][6] = {"05140", "05141"};
const int buttonPinOpen = 3;
const int buttonPinClose = 4;
int buttonStateOpen = 0;
int buttonStateClose = 0;
pinMode(buttonPinOpen, INPUT);
pinMode(buttonPinClose, INPUT);
radio.begin();
radio.openWritingPipe(address[0]);
radio.setPALevel(RF24_PA_MAX);
radio.setChannel(125);
buttonStateOpen = digitalRead(buttonPinOpen);
buttonStateClose = digitalRead(buttonPinClose);
if (buttonStateOpen == HIGH){
const char text[] = "Open door";
if(radio.write(&text, sizeof(text))){
Serial.println("it did it");
Serial.println(text);
if (buttonStateClose == HIGH){
const char text[] = "Close door";
radio.write(&text, sizeof(text));
delay(500);
The receive code:
#include <SPI.h>
#include <RF24.h>
//#include <LiquidCrystal.h>
//const int rs = 9, en = 10, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
//LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//int backLight = 15;
int a = 7; //pinMap(Mapped Pin) - for mapped pin refer the attacted image
int b = 8;
RF24 radio(a,b); //CE, CSN
//pinMode(backLight, OUTPUT);
//digitalWrite(backLight, HIGH);
//lcd.begin(16, 2);
//lcd.print("hello, world!");
radio.begin();
radio.openReadingPipe(0, address[0]);
radio.setPALevel(RF24_PA_MIN);
radio.startListening();
if(radio.available()){
//lcd.clear();
char text[32] = "";
radio.read(&text, sizeof(text));
Serial.println("we");
//lcd.print(text);
delay(500);
//lcd.clear();
else{
//Serial.println("whoopsies");
//lcd.clear();
Would appreciate any advise!
Re: L432KC and NRF24L01
check if spi is working e.g. read the status registers etc from nrf24
Pay attention to the pin configuration. Lot of soldier bridges and same pins available on different headers...
fro
Post by fro »
I'd advise to:
- check the return value from radio.begin() (https://nrf24.github.io/RF24/classRF24. ... e6fb9c4ba8)
- try to explicitly specify the SPI pins (e.g. https://github.com/stm32duino/wiki/wiki ... tance-pins)
- check the Nucleo pins you are using again as fpiSTM suggests (https://www.st.com/resource/en/user_man ... ronics.pdf)
- glance over code examples in https://forum.arduino.cc/t/simple-nrf24 ... emo/405123
