EEPROM Lib, having problems, what am I doing wrong?
Mangy_Dog
Post by Mangy_Dog »
Hi all, So im having issues with the EEPROM emulation on rogers core.
Ive placed
  EEPROM.PageBase0 = 0x08000000;
  EEPROM.PageSize = 0x400;
  EEPROM.init();
in setup();
somewhere else i call
  EEPROM.write(0,0);
and then somewhere else I call
  readCHK = EEPROM.read(0);
and i get back 255.
If i call format, the eeprom block gets formated to 0xffff
This also crashes my program.
I thought the lib is meant to set a partitioned block of flash off from the main program?
Or do i need to place it somewhere else?
Anyway what am i doing wrong?
Mangy_Dog
Re: EEPROM Lib, having problems, what am I doing wrong?
Post by Mangy_Dog »
ok got it working... sort of.
still having some issues.
  EEPROM.PageBase0 = 0x0801F000;
  EEPROM.PageBase1 = 0x0801F400;
placing at what i thought would be the last KB of memory in the program. As I was wrong to assume the library partitions off the storage from the program space. So as long as my program doesnt feel the whole memory space up it should be safe...
However. i have some code thats meant to store touch screen config data.
    if (((EEPROM.read(0) >> 8) != 0x7c))
      GD.self_calibrate();
      // for (int i = 0; i < 24; i++) Serial.println(GDTR.rd(REG_TOUCH_TRANSFORM_A + i), HEX);
      for (int i = 0; i < 12; i++)
          if (i == 0)
              EEPROM.write(0, ((0x7c << 8) | GD.rd(REG_TOUCH_TRANSFORM_A))); // is written!
          else
              EEPROM.write(i, GD.rd( ((REG_TOUCH_TRANSFORM_A + (i * 2)) << 8) | GD.rd(REG_TOUCH_TRANSFORM_A + (i * 2) + 1)));
  else
          if (i == 0)
              GD.wr(REG_TOUCH_TRANSFORM_A + (1), (EEPROM.read(0)) & 0xff); // taking the bottom 8 bits ignoring top 8.
          else
              GD.wr(REG_TOUCH_TRANSFORM_A + (i * 2),(EEPROM.read(i) >> 8 & 0xff)); //& prolly not needed but enforced mask
              GD.wr(REG_TOUCH_TRANSFORM_A + (i * 2) + 1,(EEPROM.read(i) & 0xff));
// for reference assuming everything is 8 bits.
//  if ((EEPROM.read(0) != 0x7c))
//      GD.self_calibrate();
//      EEPROM.write(1 + i, GD.rd(REG_TOUCH_TRANSFORM_A + i));
//      EEPROM.write(0, 0x7c);  // is written!
//  else
//        GD.wr(REG_TOUCH_TRANSFORM_A + i, EEPROM.read(1 + i));
but when loaded the config data is coming back wrong and the touch screen not accurate. The commented out code is the original loop, where as I took the 8bit data and reworked it to fit the 16bit data address blocks...
But I decided to hard code a few values and the data isnt being stored where I expected and its confusing me...
The data isnt going where i expected. There seems to be loads of header space.... Is something wrong?
Lots of hits in the old static forum: just google as shown...
eeprom site:stm32duinoforum.com
Re: Saving a Variable in FLASH - MAPLE MINI
Post by RogerClark » Fri Sep 01, 2017 10:29 am
https://github.com/rogerclarkmelbourne/ ... ies/EEPROM
You may even have some of the old RTC modules in a box from the Atmega early days, just use the I2C 24C32 eeprom ... you will be much happier.
https://breadboardtronics.wordpress.com ... d-arduino/
Mangy_Dog
Post by Mangy_Dog »
kinda seems i got it working now... Reading back seems to work now... still strange behavior that it doesnt appear to write where id expect it to. But reading the address where im writing seems to work now.
I also had a bug in my loop.
As for external eeprom... yeah sure in another project. But this one just has the on board chip flash at the moment.
