OneWire with DS18B20
kiloWATT21
Post by kiloWATT21 »
i'm using a board with STM32L051K8, and i'm having trouble reading temperature from DS18B20.
I have tried all kinds of libraries and codes without the library, but non of it seems to work.
Is the L0 chips just too slow for OneWire protocol. Do i have to use the solution using USART solution with the diode ( https://cnnblike.com/post/stm32-OneWire/ )?
Re: OneWire with DS18B20
Hi @kiloWATT21
if you use the STM32 core then simply use this library: https://github.com/PaulStoffregen/OneWire
many libraries may not work 'out of the box' if they use atmega specific features e.g. hardware timers
https://create.arduino.cc/projecthub/Th ... ino-9cc806
https://lastminuteengineers.com/ds18b20 ... -tutorial/
what can be done is to review the codes and adapt/port it across to use stm32timers
examples for using the stm32 hardware timer are here (STM core)
it is quite easy once you get used to using the stm32 hardware timers, basically 'bit bang' the signals on a port.
you won't need a uart for it as the signals are pretty much 'slow' > 10us.
try the blink examples with stm32 hardware timers to figure out how to control duration, duty cycle, interrupt callback etc
hardware timer codes looks mostly like this
HardwareTimer *Tim1 = new HardwareTimer(TIM1);
void Update_IT_callback() {
	//timer calls this every period
	//e.g. digitalWrite(pin), digitalRead(pin);
	Tim1->pause();
	Tim1->setMode(channel, TIMER_OUTPUT_COMPARE_PWM1);
	Tim1->setOverflow(10, MICROSEC_FORMAT); // 10 microseconds
	Tim1->attachInterrupt(Update_IT_callback);
	Tim1->refresh();
	Tim1->resume();
	// other sketch codes goes here
	// you can still pause(), refresh(), resume() the timer from here
	// the connection between here and the timer callback is to use global variables or arrays
	// use a global variable to manage state
Return to “STM32L0 based boards”
