Stduino learning - 3 color LED module
What are you developing?
jacobli
Post by jacobli »
Description
Tri-color LED module made of a full-color LED, through the PWM voltage input of the three pins R, G, B can adjust the intensity of the three base colors (red/blue/green) so as to achieve the full-color color mixing effect. R, G, B correspond to the control of red, green, blue three LED pins.
Experimental purpose
LED to achieve from green to red, from red to blue, from blue to green.
Equipment
Four-legged three-color LED light module, breadboard, Stduino Uno/Nano, DuPont wire
Circuit connection
The LED tricolor light module generally has four pins, of which "-" is connected to GND.
The other three are connected to the pins on the Stduino Uno board that are capable of PWM output (i.e. the pins with wavy lines after the pin number).
Here A4 is connected to the red LED pins, A5 to the green LED pins, and A6 to the blue LED pins.
code
int RedLED = A4;
int GreenLED =A5;
int BlueLED = A6;
  pinMode(RedLED,OUTPUT);
  pinMode(GreenLED,OUTPUT);
  pinMode(BlueLED,OUTPUT);
void setColor(int red,int green,int blue)
  analogWrite(RedLED,red);
  analogWrite(GreenLED,green);
  analogWrite(BlueLED,blue);
  int i,j;
  //Green to red gradient
  for(i=0,j=255;i<256;i++)
    setColor(i,j,0);
    delay(4);
    j--;
  //Red to blue gradient
    setColor(j,0,i);
    delay(4);
    j--;
  //Blue to green gradient
    setColor(0,i,j);
    delay(4);
    j--;
Re: Stduino learning - 3 color LED module
Note:
Your LED module (appears) to have 3x 150 Ohm resistors for limiting the current. Unfortunately, with the same voltage applied simultaneously to G, R, and B, the LED will not produce white light. Not so important in just fading the colors one-to-another, but certainly something everyone needs to be made aware.
The above is due to (largely) the Voltage Drop (forward Vd) of the LED junction.
A second reason for the difference is that the R, G, B LEDs do not produce the same intensity for a finite current.
You can work around these issues with changing resistances (thus current) but the Blue LED is problematic with a 3.3 Volt system because the Vd is rather large and the junction will unlikely be driven efficiently.
Suggest using FET drivers for the LEDs, Vcc of 5V for LEDs, and separate resistors determined by experimentation. Remember, the human eye processes color intensity non-linearly.
jacobli
Post by jacobli »
What you say makes perfect sense, thanks for the correction!
I'll try it as you said!
Return to “Projects”
