two I2Cs simultaneously,
madhavan
Post by madhavan »
hi, i am trying to use two i2c device simultaneously . Individually single port is function is ok like wise PB7 -SDA , PB6 -SCL or PB11-SDA & PB10 -SCL
when i am scanning first i2c port with just
Wire,begin(); it's giving first device address details ....
When i am scanning second i2c port with
Wire.setSDA(PB11);
Wire.setSCL(PB10);
Wire.begin(); it's giving asecond device address details ....
When i try to use simultaneously - only first device address is coming ..no second device address
  Wire.begin();
  TwoWire Wire2(PB11,PB10);
  Wire2.begin();
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++) {
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0) {
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
      nDevices++;
    else if (error == 4) {
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
  if (nDevices == 0)
    Serial.println("No I2C devices found");
  else
    Serial.println("done");
  delay(5000);           // wait 5 seconds for next scan
Board: blue pill . Core : Stm32 Duino
by GonzoG » Thu Sep 23, 2021 10:16 pm
madhavan wrote: Tue Sep 21, 2021 1:31 pm
  Wire.begin();
  Wire2.begin();
It won't work.
You define Wire2 only in setup, and it's not accessible outside setup() function.
You need to define it as a global object.
TwoWire Wire2(PB11,PB1);
void setup(){
Re: two I2Cs simultaneously,
I2C is generally used as a "bus" topology when 2 or more devices are needed:
https://electronics.stackexchange.com/q ... sda-and-a5
If 2 separate I2C embedded controllers are used, two I2C instances are required, but this is really wasteful on SRAM resources as 2 object variables must be in RAM. The consideration is that both devices have different addresses ... some devices can be jumpered to avoid address conflicts.
  Wire.begin();
  Wire2.begin();
It won't work.
void setup(){
