[SOLVED]Timer changes since 1.6
BennehBoy
Post by BennehBoy »
Hi Fred,
I'm revisiting an older project that users a click encoder.
I used to set up the timer like this:
#define TIMER_ENC  TIM4
static stimer_t TimHandle;
/* Set TIMx instance. */
TimHandle.timer = TIMER_ENC;
/* Timer set to 1ms */
TimerHandleInit(&TimHandle, 1000 - 1, ((uint32_t)(getTimerClkFreq(TIMER_ENC) / (1000000)) - 1));
attachIntHandle(&TimHandle, checkenc);
What do I need to change to make this work in 1.8?
Feel free to point me at a relevant example.
by Ralf9 » Thu Jan 23, 2020 12:13 pm
maybe you need this
MyTim->setMode(2, TIMER_OUTPUT_COMPARE);
viewtopic.php?f=62&t=117
Re: Timer changes since 1.6
Hi Ben
Check in the wiki the HardwareTimer page and the STM32Examples, you will find what you search from.
BennehBoy
Post by BennehBoy »
I forgot about the wiki :D
BennehBoy
Post by BennehBoy »
OK so I think I know what I need to do... I want a time based interrupt that will fire every millisecond, so I just need to set up a 1000 hz timer? Based on the below example code?
  MyTim->setOverflow(10, HERTZ_FORMAT); // 10 Hz
  MyTim->attachInterrupt(Update_IT_callback);
  MyTim->resume();
I'll give it a try.
Ralf9
Post by Ralf9 »
maybe you need this
BennehBoy
Post by BennehBoy »
Ralf9 wrote: Thu Jan 23, 2020 12:13 pm maybe you need this
I just need to fire an interrupt every millisecond, if I was doing the pin handling myself (and not using a library) then yeah a comparison would be the way to go.
EDIT As it stands the interrupt doesn't fire my callback, I must be missing something.
BennehBoy
Post by BennehBoy »
Open to suggestions....
globals:
// Timer STM32
void checkenc(HardwareTimer*)
  clickEncoder->service();
setup:
  TIM_TypeDef *Instance = TIMER_ENC;
  HardwareTimer *stimer_t = new HardwareTimer(Instance);
  stimer_t->setOverflow(1000, HERTZ_FORMAT); // 1000 Hz
  stimer_t->attachInterrupt(checkenc);
  stimer_t->resume();
Like Ralf9 said
For 1.8 you need to do the setMode.
This will not be needed for next release.
Anyway, as you get the example on the master it is not present.
See:
https://github.com/stm32duino/STM32Exam ... 0a3352f716
BennehBoy
Post by BennehBoy »
Doh, my apologies then.
BennehBoy
Post by BennehBoy »
Solved, thanks.
