unable to have I2C2 working on a bluepill
Jblb
Post by Jblb »
Hi all
i try to use 2 I2C bus on a bluepill and and I can't get the second one working.
here is my code to setup them
// second I2C on PB_11 (SDA) PB_10 (SCL)
TwoWire Wire2(PB_11, PB_10);
  //alternate pin for I2C1 (wire)
  Wire.setSCL(PB_8);
  Wire.setSDA(PB_9);
  Wire2.setSCL(PB_10);
  Wire2.setSDA(PB_11);
nothing works on Wire2 but if i swap devices on Wire this is working with the same (ajusted) code.
any ideas where to look to get it working ?
Re: unable to have I2C2 working on a bluepill
Some fixes have been made on I2C for this issue.
You should try the master.
Jblb
Post by Jblb »
fpiSTM wrote: Thu Feb 06, 2020 5:28 pm You should try the master.
Ok i see, now new question: how to use the master ?
@Jblb
Is it ok ?
About your sketch, by default Wire use I2C1 with PB7 (SDA) / PB6 (SCL).
So seems you want to use also I2C1 on PB9/PB8 which is fine using setSCL/SDA.
For the Wire2 as you already instantiate it with the proper pins, you don't need to re-set the pins using:
Jblb
Post by Jblb »
hi @fpiSTM
yes it's works, i just miss the wiki page about this, title did not tel me it was about this....
about the second instantiate it's come from tests i made to have it working and forgot to remove :|
Fine.
Anyway, one time if you need some support, we can meet few hours ;)
Jblb
Post by Jblb »
@fpiSTM
if i remove
Wire2 is not working any more....
need to set my my logic analyzer to get a closer look to signal
OK, I think I know why.
You use the Pin Name instead of the pin number:
TwoWire Wire2(PB11, PB10);
Probably, the second constructor could be added to avoid this kind of issue.
Anyway I guess you should have a warning about argument type.
Jblb
Post by Jblb »
fpiSTM wrote: Sat Feb 08, 2020 10:18 am OK, I think I know why.
fine you gt it, when I change it's works !
I didn't understand very well the naming of pins/pins number there is something in the wiki about this ?
I set arduino.logLevel to verbose and there is not any warning
