NUCLEO-F756ZG: Use of 5 serial ports + ethernet
quest4exit
Post by quest4exit »
Hello,
I have an interesting problem: For a project, I need to use 5 UART ports and ethernet (for mqtt). On a custom pcb I wired my serial connections like this:
UART2_RX: PD_6
UART2_TX: PD_5
UART4_RX: PC_11
UART4_TX: PC_10
UART5_RX: PD_2
UART5_TX: PC_12
UART6_RX: PG_9
UART6_TX: PG_14
UART7_RX: PE_7
UART7_TX: PE_8
Using this very basic code, the port on (PG9, PG14) works:
#include <DFRobotDFPlayerMini.h>
HardwareSerial Serial1(PG9,PG14);
DFRobotDFPlayerMini mp3Player1;
    Serial1.begin(9600);
    delay(500);
    mp3Player1.begin(Serial1);
    delay(500);
    mp3Player1.play(1);
But as soon, as I add ethernet functionality, I can't get the port to do anything:
#include <LwIP.h>
#include <STM32Ethernet.h>
byte mac[] = {0xDA,0x30,0xDE,0xEE,0xDE,0xEC};
IPAddress ip(192, 168, 178, 177);
IPAddress gateway(192,168,178,1);
IPAddress subnet(255,255,255,0);
EthernetClient ethClient;
    Ethernet.begin(mac, ip);
    delay(500);
    delay(500);
    delay(500);
    mp3Player1.play(1);
I didn't find any obvious conflicts regarding the pins PG9 and PG14 ... and now I'm running out ouf ideas. Any suggestion would be highly appreciated.
by fpiSTM » Sat May 07, 2022 7:47 am
Currently Ethernet configure all pins available in PinMap_Ethernet array. PG14 is one of them: https://github.com/stm32duino/Arduino_C ... ins.c#L414
You have to redefine this array with only the required pins.
Re: NUCLEO-F756ZG: Use of 5 serial ports + ethernet
quest4exit
Thank you so much - that did the trick!
