makefile for stm32duino official core
below is a makefile i used successfully with stm32duino official core.
f401ccu black pill board
this is 'alpha' software, it apparently works (for me) but the dependencies are not verified
This Makefile sits in the workspace project directory for the project there are a few other (sub) directories that needs to reside in the workspace project folder specified in the Makefile comments.
you may need to make a copy of the startup asm files into src directory to build the sketch
e.g.
startup_stm32f401xc.s
system_stm32f4xx.c
the startup asm files are normally found in
Arduino_Core_STM32/system/Drivers/CMSIS/Device/ST/STM32Fxxyy/Source/Templates/gcc/startup_stm32Fxxyy.s
and
Arduino_Core_STM32/system/Drivers/CMSIS/Device/ST/STM32Fxxyy/Source/Templates/startup_stm32Fxxyy.c
# version 0 (alpha)
# This make file for stm32duino core is possibly *dangerous*
# i.e. it compiles the sources (in src and Arduino_Core_STM32) directory
# and overwrite all the stuff in $(out_dir)
# $(out_dir) is the binary directory where the object files are dumped there
# make clean *deletes* the *$(out_dir)* (coded here as bin )
# this is a relative path makefile
# the directory structure needs to be
# Root (project folder)
#   +-- src (your sources e.g. the sketch
#   |        the files has to be cpp, c or h, no ino)
#   +-- Arduino_Core_STM32 (copy from the stm32duino core)
#   +-- CMSIS_5
#   +-- Makefile (this makefile)
# the make needs to be run from the root of this file structure
# the make is relative path from this Root
# generated object files and binaries (elf, bin) are placed into the
# $(out_dir) - bin
# make clean  - *deletes* $(out_dir)
# make all  - starts the build
# This software released into the public domain.
# Anyone is free to copy, modify, publish, use, compile, sell, or
# distribute this software, either in source code form or as a compiled
# binary, for any purpose, commercial or non-commercial, and by any
# means.
# In jurisdictions that recognize copyright laws, the author or authors
# of this software dedicate any and all copyright interest in the
# software to the public domain.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
# EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
# MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
# IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY CLAIM, DAMAGES OR
# OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
# ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
# OTHER DEALINGS IN THE SOFTWARE.
# this folder is deleted with make clean
out_dir := build
# this is the name of the subdirectory under STM32F1/variants
# it needs to match, this caters to a single variant
variant := Generic_F401Cx
build_series := STM32F4xx
build_arch := STM32
#build_board := GenF4
build_board := BLACKPILL_F401CC
product_line := STM32F401xC
#flash offset
ld_flash_offset := 0x0
#flash size
# 256K
ld_flash_size := 0x40000
#sram size
# 64K
ld_sram_size += 0x10000
# these are the defines passed to gcc, g++ and the assembler
# use += to add more definitions
defines := ARDUINO=189
defines += $(build_series)
defines += ARDUINO_$(build_board)
defines += ARDUINO_ARCH_$(build_arch)
defines += BOARD_NAME=\"$(build_board)\"
defines += $(product_line)
#defines += VECT_TAB_SRAM
defines += VECT_TAB_OFFSET=0
defines += DEBUG_LEVEL=DEBUG_NONE
defines += F_CPU=84000000L
defines += HSE_VALUE=25000000L
defines += HAL_UART_MODULE_ENABLED
defines += HAL_PCD_MODULE_ENABLED
defines += USBCON
defines += USBD_VID=0x0483
defines += USBD_PID=0x5740
defines += USB_MANUFACTURER=\"Unknown\"
defines += USB_PRODUCT=\"$(build_board)\"
# usb serial
defines += USBD_USE_CDC
# HID keyboard and mouse
#defines += USBD_USE_HID_COMPOSITE
defines += LED_BUILTIN=PC13
defines += HAVE_INITFINI_ARRAY
# points to the root folder of stm32duino core
# this should be 1 level above STM32F1 folder
# use of this is not encouraged, it is safer to copy the STM32F1
# folder into the current directory
# omit the final slash after the directory
core_root := /home/user/workspace/STM32F4STduino-blinky
core_name := Arduino_Core_STM32
build_core_path = $(core_root)/$(core_name)/cores/arduino
build_system_path = $(core_root)/$(core_name)/system
CMSIS_path := $(core_root)/CMSIS_5
# This is for the CMSIS math lib
CMSIS_LD_PATH := $(core_root)/CMSIS/DSP/Lib/GCC
cmsis_lib_gcc := arm_cortexM4lf_math
start_file_path := $(build_system_path)/Drivers/CMSIS/Device/ST/$(build_series)/Source/Templates/gcc
# these are the source directories for the libmaple core
# and variant, normally they stay unchanged
# if you want to place the libmaple core directory somewhere else,
# define core_root above
coredir := $(core_root)/$(core_name)/cores/arduino
coredir += $(core_root)/$(core_name)/libraries/SrcWrapper/src
#coredir += $(build_system_path)/Drivers/$(build_series)_HAL_Driver/Src
#coredir += $(build_system_path)/$(build_series)
#coredir += $(build_system_path)/Middlewares/ST/STM32_USB_Device_Library/Core/Src
#variantdir := $(core_root)/variants/$(variant)
#local variannt dir
variantdir := $(core_root)/$(core_name)/variants/$(variant)
#coredir += $(variantdir)
# source directories
# these are the initial directories to search for sources
# relative to this build (root) directory
# if you use libraries either put them in a sub-directory in src
srcdir := src
# or add it here
#srcdir += library1
srcdir += $(variantdir)
srcdir += $(core_name)/libraries/SPI/src
#this is the ld script in STM32F1/variants/$(variant)/ld to use
#ldscript := bootloader_20.ld
ldscript := ldscript.ld
LD_SCRIPT_PATH := $(variantdir)/$(ldscript)
#LD_SCRIPT_PATH := variants/Pill_F401CC/$(ldscript)
#add_ld_script:=src/board.ld
#this is the startup asm file, mcu specific
start_mcu_name := stm32f401xc
start_asm_file := ${start_file_path}/startup_${start_mcu_name}.s
#the includes i.e. the -Ipath needs to be exlicitly stated
#no automatic recursive searching
#if you use libraries you may want to add it here
includedir := $(srcdir)
includedir += $(variantdir)
includedir += $(CMSIS_path)/CMSIS/Core/Include
includedir += $(build_system_path)/Drivers/CMSIS/Device/ST/$(build_series)/Include/
#includedir += $(build_system_path)/Drivers/CMSIS/Device/ST/$(build_series)/Source/Templates/gcc/
includedir += $(CMSIS_path)/CMSIS/DSP/Include
includedir += $(build_core_path)
includedir += $(build_core_path)/avr
includedir += $(build_core_path)/stm32
includedir += $(build_core_path)/stm32/LL
includedir += $(build_core_path)/stm32/usb
includedir += $(build_core_path)/stm32/usb/hid
includedir += $(build_core_path)/stm32/usb/cdc
includedir += $(build_system_path)/Drivers/$(build_series)_HAL_Driver/Inc
includedir += $(build_system_path)/Drivers/$(build_series)_HAL_Driver/Src
includedir += $(build_system_path)/$(build_series)
includedir += $(build_system_path)/Middlewares/ST/STM32_USB_Device_Library/Core/Inc
includedir += $(build_system_path)/Middlewares/ST/STM32_USB_Device_Library/Core/Src
#if you use core_root, you would need to add that as a prefix
#includedir := $(addprefix $(core_root)/,$(includedir))
# update this to match
# this should be the install base location of ARM_NONE_EABI_GCC toolchain
ARM_NONE_EABI_PATH := /opt/arduino/gcc-arm-none-eabi-8-2018-q4-major
# this should be the location of the arm standard libraries c & c++
# the arm-none-eabi/lib select the folder matching the arch
# compile options e.g. thumb and v7-m
LD_TOOLCHAIN_PATH := $(ARM_NONE_EABI_PATH)/arm-none-eabi/lib/thumb/v7e-m+fp
# recursive wildcard function, call with params:
#  - start directory (finished with /) or empty string for current dir
#  - glob pattern
# (taken from http://blog.jgc.org/2011/07/gnu-make-recursive-wildcard-function.html)
rwildcard=$(foreach d,$(wildcard $1*),$(call rwildcard,$d/,$2) $(filter $(subst *,%,$2),$d))
cfiles := $(strip $(foreach s, $(srcdir), $(call rwildcard,$(s),*.c)))
cxxfiles := $(strip $(foreach s, $(srcdir), $(call rwildcard,$(s),*.cpp)))
asfiles := $(strip $(foreach s, $(srcdir), $(call rwildcard,$(s),*.s)))
asfiles += ${start_asm_file}
$(info $(asfiles))
core_cfiles += $(subst $(core_root)/,,$(strip $(foreach s, $(coredir), $(call rwildcard,$(s),*.c))))
core_cxxfiles += $(subst $(core_root)/,,$(strip $(foreach s, $(coredir), $(call rwildcard,$(s),*.cpp))))
core_asfiles += $(subst $(core_root)/,,$(strip $(foreach s, $(coredir), $(call rwildcard,$(s),*.s))))
#exclude due to repeat system init
#core_cfiles := $(filter-out libraries/SrcWrapper/src/stm32/system_stm32yyxx.c,$(core_cfiles))
#$(info $(core_cfiles))
src_files := $(cfiles) $(cxxfiles) $(asfiles)
core_files := $(core_cfiles) $(core_cxxfiles) $(core_asfiles)
files := $(src_files) $(core_files)
sdirs := $(sort $(dir $(files)))
#hfiles := $(foreach s, $(includedir), $(call rwildcard,$(s),*.h))
#hfiles += $(foreach s, $(srcdir), $(call rwildcard,$(s),*.h))
#incdirs = $(sort $(dir $(hfiles)))
TOOLPREFIX := arm-none-eabi-
CC      = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)gcc
CXX     = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)g++
AS      = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)as
OBJCOPY = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)objcopy
OBJDUMP = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)objdump
AR      = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)ar
SIZE    = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)size
NM      = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)nm
LD      = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)ld
DFUUTIL = dfu-util
RM      = /usr/bin/rm
MKDIR   = /usr/bin/mkdir -p
TEST	= /usr/bin/test
DEFINES := $(addprefix -D,$(defines))
INCLUDES := $(addprefix -I,$(includedir))
#optimise
# -O0 - none
# -Os - optimise size
# -O1 - optimise
# -O2 - optimise more
# -O3 - optimise most
# -Og - optimise debug
OFLAG := -Os
#debug
# default none
# -g - debug
# -g1 - minimal
# -g3 - maximal
DFLAG = -g
COMMON_OFLAGS := -Wl,--gc-sections $(OFLAG) $(DFLAG) \
                 -ffunction-sections -fdata-sections \
                 -fmessage-length=0 -fsigned-char \
                 -ffreestanding -fno-move-loop-invariants \
                 --specs=nano.specs -Wall -Wextra
FPU_FLAGS := -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant
#FPU_FLAGS := -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -fsingle-precision-constant
TARGET_FLAGS += -mcpu=cortex-m4 -march=armv7e-m+fp -mthumb \
                 $(FPU_FLAGS) \
                 $(INCLUDES) $(DEFINES)
GLOBAL_CFLAGS := $(COMMON_OFLAGS) $(TARGET_FLAGS)
TARGET_CFLAGS :=
GLOBAL_CXXFLAGS := -fno-rtti -fno-exceptions \
                   -fno-use-cxa-atexit -fno-threadsafe-statics \
                   $(COMMON_OFLAGS) \
                   $(TARGET_FLAGS)
TARGET_CXXFLAGS :=
GLOBAL_ASFLAGS  := $(TARGET_FLAGS)
#TARGET_ASFLAGS  := -Wl,--gc-sections $(OFLAG) $(DFLAG) -Xassembler -Wall
#				   -nostdlib
#                  -nodefaultlibs
#                  -nostartfiles
#                  -Wl,--gc-sections
GLOBAL_LDFLAGS := --specs=nano.specs \
                  -Xlinker --gc-sections
TARGET_LDFLAGS := $(TARGET_FLAGS) \
                  -Xlinker -T$(LD_SCRIPT_PATH) \
                  -L $(variantdir)
#                  -Xlinker -T$(add_ld_script)
TARGET_LDFLAGS += -Wl,--defsym,LD_FLASH_OFFSET=$(ld_flash_offset) \
                  -Wl,--defsym,LD_MAX_SIZE=$(ld_flash_size) \
                  -Wl,--defsym,LD_MAX_DATA_SIZE=$(ld_sram_size)
CFLAGS   = $(GLOBAL_CFLAGS) $(TARGET_CFLAGS)
CXXFLAGS = $(GLOBAL_CXXFLAGS) $(TARGET_CXXFLAGS)
CPPFLAGS =
ASFLAGS  = $(GLOBAL_ASFLAGS) $(TARGET_ASFLAGS)
# Add toolchain directory to LD search path
TOOLCHAIN_LDFLAGS := -L $(LD_TOOLCHAIN_PATH) -L $(CMSIS_LD_PATH) -l $(cmsis_lib_gcc)
LDFLAGS = $(GLOBAL_LDFLAGS) $(TARGET_LDFLAGS) $(TOOLCHAIN_LDFLAGS)
#build lists of object files relative to $(out_dir)
COBJS = $(addprefix $(out_dir)/,$(patsubst %.c,%.o,$(cfiles)))
CXXOBJS = $(addprefix $(out_dir)/,$(patsubst %.cpp,%.o,$(cxxfiles)))
ASOBJS =  $(addprefix $(out_dir)/,$(patsubst %.s,%.o,$(asfiles)))
CORE_COBJS = $(addprefix $(out_dir)/,$(patsubst %.c,%.o,$(core_cfiles)))
CORE_CXXOBJS = $(addprefix $(out_dir)/,$(patsubst %.cpp,%.o,$(core_cxxfiles)))
CORE_ASOBJS =  $(addprefix $(out_dir)/,$(patsubst %.s,%.o,$(core_asfiles)))
variant.ELF = $(out_dir)/$(variant).elf
variant.BIN = $(out_dir)/$(variant).bin
.PHONY: all clean mkdir
all: mkdir $(variant.BIN)
	@echo
	@$(SIZE) $(variant.ELF)
	@echo
	@ls -l $(variant.BIN)
	@echo
	@$(OBJDUMP) --section-headers $(variant.ELF)
	@echo
	@echo Source dirs
	@echo $(srcdir) $(coredir) | sed 's/ /\n/g'
	@echo
	@echo $(sort $(dir $(src_files))) | sed 's/ /\n/g'
	@echo $(addprefix $(core_root)/,$(sort $(dir $(core_files)))) | sed 's/ /\n/g'
	@echo
	@echo Includes
	@echo $(INCLUDES) | sed 's/ /\n/g'
	@echo
	@echo Defines
	@echo $(DEFINES) | sed 's/ /\n/g'
install: all
	$(DFUUTIL) -d 0483:df11 -a 0 -s 0x8000000 -D $(variant.BIN)
$(variant.BIN): $(variant.ELF)
	$(OBJCOPY) -v -Obinary $(variant.ELF) $@
$(variant.ELF): $(ASOBJS) $(COBJS) $(CXXOBJS) \
                $(CORE_COBJS) $(CORE_CXXOBJS) $(CORE_ASOBJS)
	$(CXX) $(LDFLAGS) -o $@ -Wl,-Map,$(out_dir)/$(variant).map $+
# General directory independent build rules, generate dependency information
$(COBJS): $(out_dir)/%.o: %.c
	$(CC) $(CFLAGS) -MMD -MP -MF $(@:%.o=%.d) -MT $@ -o $@ -c $<
$(CXXOBJS): $(out_dir)/%.o: %.cpp
	$(CXX) $(CXXFLAGS) -MMD -MP -MF $(@:%.o=%.d) -MT $@ -o $@ -c $<
$(ASOBJS): $(out_dir)/%.o: %.s
	@echo $(ASOBJS)
	$(CC) $(ASFLAGS) -MMD -MP -MF $(@:%.o=%.d) -MT $@ -o $@ -c $<
$(CORE_COBJS): $(out_dir)/%.o: $(core_root)/%.c
$(CORE_CXXOBJS): $(out_dir)/%.o: $(core_root)/%.cpp
$(CORE_ASOBJS): $(out_dir)/%.o: $(core_root)/%.s
# create the build directories
tgtdirs := $(addsuffix .dir,$(addprefix $(out_dir)/,$(sdirs)))
mkdir: $(tgtdirs)
# the .dir file is a marker file that the directory is created
$(tgtdirs) : $(out_dir)/.dir
	$(MKDIR) $(dir $@)
	@touch $@
$(out_dir)/.dir:
	$(MKDIR) $(dir $@)
	@touch $@
clean:
	@echo clean
	$(RM) -r $(out_dir)
DEPENDS := $(COBJS:%.o=%.d) $(CXXOBJS:%.o=%.d) $(ASOBJS:%.o=%.d)
DEPENDS += $(CORE_COBJS:%.o=%.d) $(CORE_CXXOBJS:%.o=%.d) $(CORE_ASOBJS:%.o=%.d)
-include $(DEPENDS)
note this is *unofficial*, it is my personal Makefile hack and it so happens that it works for me.
Re: makefile for stm32duino official core
one of those things i couldn't figure out is that those .s startup asm files normally have the vector tables that simply use a no-op default_handler.
i'm not sure if there may be another .s startup files with the nvic vectors which points into HAL.
that is quite critical if one wants to use HAL
i think it may be 'difficult' to find the 'HAL asm' files with the pre-patched vector tables as the .s vector tables are mcu specific. it can even vary between mcus in the same STM32Fxxyy e.g. F4xx family. my guess is Cube MX may generate pre-patched .s files, but i've not tried nor verified it.
i've got an updated makefile for stm32f407ve black board.
this is alpha codes i.e. it works for me but it may not work for you
post your comments/queries in this thread if you are attempting to use this makefile
this source codes is updated in the gist here as well
https://gist.github.com/ag88/908e1b1097 ... 7ea4aff60a
# version 0 (alpha)
# this is only tested in linux
# this is for this board https://stm32-base.org/boards/STM32F407VET6-STM32-F4VE-V2.0.html
#   +-- CMSIS_5
#   +-- variants (see below)
# this makefile can't handle the brackets/paranthesis naming convention used for the variants
# hence you need to create a local variant folder and copy all the files in
#   Arduino_Core_STM32/variants/STM32F4xx/F407V(E-G)T_F417V(E-G)T/
# to
#   variants/F407VX/
# the make needs to be run from the root(project folder) of this file structure
# $(out_dir) - bin
# means.
out_dir := build
# this is the name of the subdirectory under variants local folder
variant := F407VX
build_arch := STM32
build_board := BLACK_F407VE
variant_h := variant_BLACK_F407VX.h
product_line := STM32F407xx
#flash offset
#flash size
# 512K
ld_flash_size := 0x80000
#sram size
# 128K (sram)
ld_sram_size += 0x20000
# 64k (ccmram) - ccm ram is maint directly in ldscript
defines += VARIANT_H=\"$(variant_h)\"
defines += F_CPU=168000000L
defines += HSE_VALUE=8000000L
defines += USBCON
# usb serial
defines += LED_BUILTIN=PA6
# core_root points to the parent folder *containing* stm32duino core (e.g. Arduino_Core_STM32) in a sub-directory
# use of this is not encouraged, it is safer to copy the Arduino_Core_STM32
core_root := .
#local variannt dir
#variantdir := $(core_root)/$(core_name)/variants/$(variant)
#variantdir := $(core_name)/variants/$(build_series)/$(variant)
variantdir := variants/$(variant)
srcdir := src
# or add it here
#srcdir += library1
$(info $(srcdir))
start_mcu_name := stm32f407xx
#  - glob pattern
$(info $(asfiles))
$(info $(sdirs))
DFUUTIL = dfu-util
RM      = /usr/bin/rm
#optimise
# -O0 - none
# -O1 - optimise
OFLAG := -Os
#debug
# default none
# -g - debug
# -g1 - minimal
# -g3 - maximal
DFLAG = -g
                 $(FPU_FLAGS) \
TARGET_CFLAGS :=
                   $(COMMON_OFLAGS) \
                   $(TARGET_FLAGS)
TARGET_CXXFLAGS :=
#				   -nostdlib
#                  -nodefaultlibs
#                  -nostartfiles
#                  -Wl,--gc-sections
                  -L $(variantdir)
CPPFLAGS =
	@echo
	@echo
	@echo
	@echo
	@echo Source dirs
	@echo
	@echo
	@echo Includes
	@echo
	@echo Defines
install: all
	@echo $(ASOBJS)
mkdir: $(tgtdirs)
	$(MKDIR) $(dir $@)
	@touch $@
$(out_dir)/.dir:
	$(MKDIR) $(dir $@)
	@touch $@
clean:
	@echo clean
	$(RM) -r $(out_dir)
-include $(DEPENDS)
Return to “Code snippets”
