Compilation error on Arduino IDE 2.0.3
Phono
Post by Phono »
Hi all,
I am moving a set of sketches from an old computer to a new one. I also decided to try the newest versions of the tools, so I installed the Arduino IDE 2.03 and the STM32 set of boards.
I have tried to compile several files. Some succeeded (I did not test if they actually run in the board), but some fail, with the following error:
In file included from C:\Users\tamba\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\system/STM32F1xx/stm32f1xx_hal_conf_default.h:304,
                 from C:\Users\tamba\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\system/STM32F1xx/stm32f1xx_hal_conf.h:13,
                 from C:\Users\tamba\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\system/Drivers/STM32F1xx_HAL_Driver/Inc/stm32f1xx_hal.h:30,
                 from C:\Users\tamba\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\system/Drivers/CMSIS/Device/ST/STM32F1xx/Include/stm32f1xx.h:255,
                 from C:\Users\tamba\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\cores\arduino/stm32/stm32_def.h:28,
                 from C:\Users\tamba\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\cores\arduino/stm32/clock.h:19,
                 from C:\Users\tamba\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\cores\arduino/wiring_time.h:23,
                 from C:\Users\tamba\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\cores\arduino/wiring.h:38,
                 from C:\Users\tamba\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\cores\arduino/Arduino.h:36,
                 from C:\Users\tamba\AppData\Local\Temp\arduino-sketch-914E0190BA916DC4D5869D00550E1CE3\sketch\PasserelleTimonerieWifi6.ino.cpp:1:
C:\Users\tamba\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\system/Drivers/STM32F1xx_HAL_Driver/Inc/stm32f1xx_hal_flash.h:118:35: error: expected identifier before numeric constant
  118 | #define HAL_FLASH_ERROR_PROG      0x01U  /*!< Programming error */
What is the problem?
Answers: 109
Re: Compilation error on Arduino IDE 2.0.3
I've tried to build for F1 (BP F103C8) AnalogReadSerial.ino with Arduino IDE 2.0.3 ans had no issue.
Maybe the core installation was corrupted or linked to your sketch.
Return to “IDE's”
