How to set OUTPUT_OPEN_DRAIN with HardwareTimer?
leonzhao101
Post by leonzhao101 »
Hi, I have searched for hours but could not find a solution to this issue.
I am using a STM32F103 board (blue pill) and I need to output a few channels of 5V PWM signals. I have learned to use the HardwareTimer library to output PWM signals, but they are only 3.3V. I have read on other posts that this can be achieved by setting the pinmode to OUTPUT_OPEN_DRAIN and using additional pull-up resistors. But since the pin configuration is handled by the HardwareTimer library, I could not find a way to set pinmode myself.
The only walkaround I can find so far is to use "software PWM" instead of hardware PWM, as shown in this example:
https://github.com/stm32duino/STM32Exam ... ration.ino
But it does not seem to be the best solution...
Any suggestions? Many thanks!!
Re: How to set OUTPUT_OPEN_DRAIN with HardwareTimer?
Hi @leonzhao101
Right, we set by default to PP with PULLUP
https://github.com/stm32duino/Arduino_C ... Pins.c#L87
You can simply redefine this array at sketch level to change the default behavior:
https://github.com/stm32duino/Arduino_C ... nmap-array
const PinMap PinMap_TIM[] = {
  {PA_0,       TIM2, STM_PIN_DATA_EXT(STM_MODE_AF_OD, GPIO_NOPULL, AFIO_NONE, 1, 0)}, // TIM2_CH1
  {NC,         NP,   0}
