How does the Setup works on F411 Blackpill
AlainBo26
Post by AlainBo26 »
Hello,
I do not understand what really happens in Setup() function on a WeAct Blackpill F411 V3.1.
When I write Serial.println("setup complete") at the end of my setup, I cannot see it if I don't do put a delay(1000); before.
Why do I have to put a so long delay()?
I also use a SSD1306 display, connected to I2C via PB6 and PB7 but connecting the SSD1306's SCL to PB6 prevents any Serial.Println() to work in Setup() (at least the 4.7K pullup because I still didn't connect the SSD1306). According to my oscillo, I2C seems to output something...
Serial.println() work in loop() any way.
What is the problem?
Alain
Answers: 109
Re: How does the Setup works on F411 Blackpill
If the Serial is linked to USB, USB have to be initialized.
You can add a while(!Serial);
https://www.arduino.cc/reference/en/lan ... /ifserial/
