not able to get seriaEvent working
jonghaboy
Post by jonghaboy »
i have been trying to get the serialEvent() call working with no success
i have read this closed issue https://github.com/stm32duino/Arduino_C ... issues/584
and tried to follow exactly but am having trouble
i am sending data through serial3 ports and am trying to listen to it with serialEvent
i am not getting anything.
i know its not a wiring issue because the Serial.available code which is commented works just fine
but when i try to use serial event, nothing works
can anyone help?
here is my build_opt.h code
-DENABLE_HWSERIAL3
and here is my main code
bool toggle = true;
pinNumber_T pin1 = PA2;
void serialEvent3()
  Serial.write(Serial3.read());
  Serial.println("++++++++++++++++++++++++++++++++++++++++");
  if(toggle)
    digitalWrite(pin1, HIGH);
  else
    digitalWrite(pin1, LOW);
  toggle = !toggle;
  Serial3.begin(115200);
  pinMode(pin1, OUTPUT);
 //  put your main code here, to run repeatedly:
// if(Serial3.available())
//    digitalWrite(pin1,HIGH);
//   Serial.println(char(Serial3.read()));
//    delay(200);
//    digitalWrite(pin1,LOW);
//   delay(200);
    Serial.println("not getting data");
    //delay(200);
Answers: 109
Re: not able to get seriaEvent working
First your code can't build by default as pinNumber_T is udefined. So I guess your code is not complete.
Anyway after update it to build, you're right it's not work.
It seems the default void serialEventRun(void) is not properly attached. :shock:
That's why it's not work.
Defining it in the sketch solve the issue, anyway this should work per default, this is a regression.
As a workaround, add this to your sketch:
#if defined(HAVE_HWSERIAL3)
  if (serialEvent3 && Serial3.available()) {
    serialEvent3();
Note: I've reopened and update your issue on GitHub as this is a regression.
jonghaboy
Post by jonghaboy »
i forgot to include this in the sample code
#include <stdint.h>
#include "common.h"
and common has piNumber_T defined so that wasn't the problem
i have added the solution you have given me but still nothing works
here is the common.h
#pragma once
////////// External Files //////////
#include <stdint.h>
#if defined(ARDUINO) && ARDUINO >= 100
#include "arduino.h"
#else
#include "WProgram.h"
////////// END: External Files //////////
typedef uint8_t pinNumber_T;
////////// Hardware Definition //////////
const pinNumber_T BALL_SENSOR_PIN = 5;
//const pinNumber_T VIBRATION_SENSOR_PIN = PA2;
//const pinNumber_T LED_BAR_PIN = PA3;
//const pinNumber_T LED_BAR_PIN_GREEN = PA4;
//const pinNumber_T LED_BAR_PIN_RED = PA5;
//const pinNumber_T LED_BAR_2_PIN = PA6;
//const pinNumber_T LED_BAR_2_PIN_GREEN = PA7;
//const pinNumber_T LED_BAR_2_PIN_RED = PA8;
////////// End: Hardware Definition //////////
here is my whole code now
#include <stdint.h>
#include "common.h"
bool toggle = true;
//HardwareSerial Serial3(PA10, PA9);
void serialEvent3()
  if(toggle)
  else
  toggle = !toggle;
    serialEvent3();
//    delay(200);
//   delay(200);
    delay(200);
Answers: 109
With this I get it working.
Try the default SerialEvent example in Aruduino menu.
Answers: 109
I've tested your code (I've made some clean) and it works:
void serialEvent3()
  digitalToggle(LED_BUILTIN);
    serialEvent3();
  pinMode(LED_BUILTIN, OUTPUT);
Answers: 109
