ILI 9488
djcleckie
ILI 9488
Post by djcleckie »
Hi
I am using a Nucleo F401RE and Arduino IDE 2.3.2.
I have several TFT displays. 2.2", 3.2" and 3.5"
My 2.2" and 3.2" displays use the ILI 9341 driver
#include "Adafruit_ILI9341.h"
and work fine with the F401RE board.
My 3.5" uses the ILI 9488 driver and when I compile for the F401RE
#include <ILI9488.h>
I get the error below.
C:\Users\djcle\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.7.1\cores\arduino/pins_arduino.h:143:38: error: invalid conversion from 'volatile uint32_t*' {aka 'volatile long unsigned int*'} to 'int32_t*' {aka 'long int*'} [-fpermissive]
143 | #define portOutputRegister(P) (&(P->ODR))
| volatile uint32_t* {aka volatile long unsigned int*}
Now if I try compiling for a F103C series I don't get any compilation errors.
It also compiles and works with a nano though it is pretty slow.
Answers: 109
Re: ILI 9488
Hi which library you used ?
Issue is that the type used in the library is not correct to call portOutputRegister
