[Solved]blue pill and ILI9341 tft
svod616
Post by svod616 »
Hi, I immediately apologize if I created the topic in the wrong section and ask me to send it in the right direction. In the STM32 topic recently, before that, I used the arduino mini for a long time, but in the current project I’m sorely lacking in speed for normal operation with a display based on the ILI9341 chip.
The problem is that I just can’t connect this display to my blue pill. The first time I used this core: https://github.com/rogerclarkmelbourne/Arduino_STM32, but on the built-in library I could not even compile example, now I installed the officially core from STM, substituted the libraries from the first kernel: Adafruit_ILI9341_STM, Adafruit_GFX_AS , SPI, as well as the official Adafruit_GFX library (without it, the sample code did not compile). Now when I try to initialize the display with the command
Adafruit_ILI9341_STM tft = Adafruit_ILI9341_STM (PA4, PB1, PA7, PA5, PB10, PA6);
when compiling, I get the message: no matching function for call to 'Adafruit_ILI9341_STM :: Adafruit_ILI9341_STM (int, int, int, int, int, int) int' 'as I understood the pin numbers that I declared do not match the data type, but in all the manuals that I saw written appeal to the pin only by full name! Tell me where can I find a solution to this problem?well, or tell me where you can find the manual for using this display with stm32duino.
version of arduino IDE 1.8.9 flashing through Chinese Stlink 2.
and apologize for my bad english i use google translator
by ag123 » Tue Mar 17, 2020 11:37 am Go to full post
svod616
Re: blue pill and ILI9341 tft
Post by svod616 »
svod616 wrote: Mon Mar 16, 2020 5:31 pm not match the data type, but in all the manuals that I saw written appeal to the pin only by full name!
upd: in file variant.cpp (way^ appdata\local\arduino15\packages\stm32\hardware\stm32\1.8.0\variants/pill_f103xx) i find next:
PB_9, //D0
PB_8, //D1
PB_7, //D2
PB_6, //D3
PB_5, //D4
PB_4, //D5
PB_3, //D6
PA_15, //D7
PA_12, //D8 - USB DP
PA_11, //D9 - USB DM
PA_10, //D10
PA_9, //D11
PA_8, //D12
PB_15, //D13
PB_14, //D14
PB_13, //D15
PB_12, //D16 - LED Blackpill
/* Right side */
PC_13, //D17 - LED Bluepill
PC_14, //D18
PC_15, //D19
PA_0, //D20/A0
PA_1, //D21/A1
PA_2, //D22/A2
PA_3, //D23/A3
PA_4, //D24/A4
PA_5, //D25/A5
PA_6, //D26/A6
PA_7, //D27/A7
PB_0, //D28/A8
PB_1, //D29/A9
PB_10, //D30
PB_11, //D31
PB_2, //D32 - BOOT1
PA_13, //D33 - SWDI0
PA_14, //D34 - SWCLK
for test this numeration of pin I modified the blink example as follows:
  pinMode(17, OUTPUT);
  digitalWrite(17, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(100);                       // wait for a second
  digitalWrite(17, LOW);    // turn the LED off by making the voltage LOW
and the built-in LED on the board began to flash at a given frequency, I also checked PA_2, writing its number from the found table (22) and it worked again, however, substituting the port numbers in the display initialization, I again got the error no matching function for call to ' Adafruit_ILI9341_STM :: Adafruit_ILI9341_STM (int, int, int, int, int, int) 'what could be the problem? because above the line with the initialization code is a comment:
// If using the breakout, change pins as desired(PA4,PB1,PA7,PA5,PB10,PA6)
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
from which it follows that all 6 conclusions can be indicated. but in the library file I found only such a function that has 3 arguments:
Adafruit_ILI9341_STM(int8_t _CS, int8_t _DC, int8_t _RST = -1);
i'm desperate help me somebody.
stas2z
Answers: 8
Post by stas2z »
according to https://github.com/rogerclarkmelbourne/ ... 9341_STM.h this library have only one constructor
so your compile error is ok
it assume to use predefined hardware spi class, not bitbanging
but im not sure that lib will compile or work with this core anyway
svod616
Post by svod616 »
could you tell me which pins should be used for this?
stas2z
Answers: 8
Post by stas2z »
for F103 chip default spi pins are MOSI=PA7, MISO=PA6, SCK=PA5, SS=PA4
svod616
Post by svod616 »
SPI port 1, ok, I'll try it, thanks
svod616
Post by svod616 »
and what do we have? The SPI library requires the libmaple_types.h file from the Roger core version, which for some reason I can’t find in its core. The official core SPI library gives a compilation error:
C:\Users\����\Documents\Arduino\libraries\Adafruit_ILI9341_STM/Adafruit_ILI9341_STM.h:150:48: error: 'class SPIClass' has no member named 'write16'
 150 |   inline void    spiwrite16(uint16_t c) { mSPI.write16(c); } // 8 bit mode"
well, we’ll continue to figure out what the problem may be, if I still manage to launch this display with my blue pill, I’ll definitely post a step-by-step instruction here with all the libraries that will have to be fixed and the complete connection diagram. it’s unfair that it took me 15 minutes to start this display on uno / nano / mega8, and now it's the morning of the fourth day as I try to do the same with STM.
or maybe there’s still instructions for launching displays on ILI9341 and the blue pill in stm32duino and I was just not looking well enough?
If you use the STM32 core, then do not use Maple built-in library.
Use the standard Adafruit library not the custom one.
svod616
Post by svod616 »
please show me where can I get a library for working with my display using the SPI protocol?
This library http://www.rinkydinkelectronics.com/library.php?id=51 also does not work with the official STM core?
