STM32G431CBU6 (and others) : how to make LPUART1 to work ?
trimarco232
Post by trimarco232 »
this code works :
HardwareSerial Serial3(PB11, PB10);  /// USART3 works
uint64_t millis_duration = 100, millis_begin;
  Serial.begin(115200); // USB
  Serial3.begin(19200);
  if (millis() - millis_begin >= millis_duration) {  // debug uart
    millis_begin += millis_duration;
    Serial3.write("UUU"); // PB10
this one don't :
  SerialLP1.begin(19200);
    SerialLP1.write("UUU"); // PB11
    Serial.println(RCC->CCIPR, BIN);  /// debug
the problem could be that LPUART1 is configured to work with HSI16 clock , instead of PCLK , even when it is not used
if I try to clear the LPUART1SEL[1] bit manually , it won't work , and in addition , USART3 gets a false clock
so not the right way : please which is the working one ?
Re: STM32G431CBU6 (and others) : how to make LPUART1 to work ?
Hi @trimarco232
LPUART1 has some constraint around clock vs speed.
* Note that LPUART clock source must be in the range
* [3 x baud rate, 4096 x baud rate]
* check Reference Manual
trimarco232
Hi @ fpiSTM
OK , thanks , my fault , again : now LPUART1 and RCC_CCIPR are configured ok since I use an adequate baudrate
BUT , it didn't output or input anything , I had to set manually the MODER and the AFR[1] registers of the PORTB , in order to make it to work : is there any else secret reason for this ?
It is not normal, the pin is configured using the value from peripheral pins.
Anyway looking at your code, I don't see how you instantiate SerialLP1?
If you used the generic target then LPUART1 is well initialized but for pins PAx not the one rol PBx. This would explain your issue. Simply change the default pins used by the one you want.
trimarco232
a blank sketch with just :
HardwareSerial SerialLP1(PB10, PB11); // LPUART1_RX , LPUART1_TX
outputs the error :
multiple definition of `SerialLP1' ?
(so I thought PB10 , PB11 are the generic target ...)
This is normal it is already instantiate.
Here the default pins used for Serial instance (defined to be SerialLP1):
https://github.com/stm32duino/Arduino_C ... #L158-L170
See the wiki which explain how it works and how change default pins.
https://github.com/stm32duino/Arduino_C ... wareserial
So if you want use PB10/11, do in setup() before Serial.begin (SerialLP1.begin()):
    Serial.setRx(PB10);
    Serial.setTx(PB11);
Return to “PR's bugs and enhancements”
