NUCLEO-G474RE Arduino
oyuncumalphite8
Post by oyuncumalphite8 »
Hello everyone,
I'm new here, I want to start like this first.
Today I bought the NUCLEO-G474RE card. I will use this card in a battery management system.
My previous system was DC2026C+DC2792B(LTC6820)+DC2350B(LTC6813), this way I can read voltages via Arduino.
I managed to upload the same coding to NUCLEO-G474RE+DC2792B(LTC6820)+DC2350B(LTC6813) via Arduino IDE, but I cannot communicate. The communication LEDs are blinking, but I cannot see any communication. I cannot read the voltages.
Re: NUCLEO-G474RE Arduino
you should probably provide more info in terms of the details e.g. schematics, datasheet (e.g. of the sensor) etc
and your sketch / codes
and have you tried the usual blink test ? and making sure you selected the correct board in the IDE e.g.
	pinMode(LED_BUILTIN, OUTPUT);
	digitalWrite(LED_BUILTIN, ! digitalRead(LED_BUILTIN));
	delay(100);
for anything more than that, it'd depends on what you are connecting, analog, digital, the interfaces i2c, spi etc
for 'complicated' setups, it may take using a scope, logic analyzer to check the signals
there is a cheap low speed open source logic analyzer based on the weact stm32f401/f411
viewtopic.php?t=116
oyuncumalphite8
Yes, I did the experiment you mentioned in Arduino and it worked. I am sharing the codes.
/*! Analog Devices DC2350A-B Demonstration Board.
* LTC6813: Multicell Battery Monitors
*@verbatim
*NOTES
* Setup:
*   Set the terminal baud rate to 115200 and select the newline terminator.
*   Ensure all jumpers on the demo board are installed in their default positions from the factory.
*   Refer to Demo Manual.
*USER INPUT DATA FORMAT:
* decimal : 1024
* hex     : 0x400
* octal   : 02000  (leading 0)
* binary  : B10000000000
* float   : 1024.0
*@endverbatim
* https://www.analog.com/en/products/ltc6813-1.html
* https://www.analog.com/en/design-center/evaluation-hardware-and-software/evaluation-boards-kits/dc2350a-b.html
* Copyright 2019(c) Analog Devices, Inc.
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
*  - Redistributions of source code must retain the above copyright
*    notice, this list of conditions and the following disclaimer.
*  - Redistributions in binary form must reproduce the above copyright
*    notice, this list of conditions and the following disclaimer in
*    the documentation and/or other materials provided with the
*    distribution.
*  - Neither the name of Analog Devices, Inc. nor the names of its
*    contributors may be used to endorse or promote products derived
*    from this software without specific prior written permission.
*  - The use of this software may or may not infringe the patent rights
*    of one or more patent holders.  This license does not release you
*    from the requirement that you obtain separate licenses from these
*    patent holders to use this software.
*  - Use of the software either in source or binary form, must be run
*    on or directly connected to an Analog Devices Inc. component.
* THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES "AS IS" AND ANY EXPRESS OR
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, NON-INFRINGEMENT,
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
* IN NO EVENT SHALL ANALOG DEVICES BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, INTELLECTUAL PROPERTY RIGHTS, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/*! @file
    @ingroup LTC6813-1
/************************************* Read me *******************************************
In this sketch book:
  -All Global Variables are in Upper casing
  -All Local Variables are in lower casing
  -The Function wakeup_sleep(TOTAL_IC) : is used to wake the LTC681x from sleep state.
   It is defined in LTC681x.cpp
  -The Function wakeup_idle(TOTAL_IC) : is used to wake the ICs connected in daisy chain
   via the LTC6820 by initiating a dummy SPI communication. It is defined in LTC681x.cpp
/************************* Includes ***************************/
#include "LTC6813.h"
#include "LTC681x.h"
#include "LT_SPI.h"
#include "Linduino.h"
#include "UserInterface.h"
#include <Arduino.h>
#include <SPI.h>
#include <Timer.h>
#include <stdint.h>
/************************* Defines *****************************/
#define ENABLED 1
#define DISABLED 0
#define DATALOG_ENABLED 1
#define DATALOG_DISABLED 0
#define PWM 1
#define SCTL 2
#define TFT_MOSI 11   // Data pin for SPI MOSI (Master Out Slave In)
#define TFT_MISO 12   // Data pin for SPI MISO (Master In Slave Out)
#define TFT_SCLK 13   // Data pin for SPI SCLK (Clock)
#define TFT_CS   10   // Chip select pin for TFT
#define TFT_DC   8    // Data/Command control pin for TFT
#define TFT_RST  9    // Reset pin for TFT
/**************** Local Function Declaration *******************/
void measurement_loop(uint8_t datalog_en);
void print_menu(void);
void print_wrconfig(void);
void print_wrconfigb(void);
void print_rxconfig(void);
void print_rxconfigb(void);
void print_cells(uint8_t datalog_en);
void print_aux(uint8_t datalog_en);
void print_stat(void);
void print_aux1(uint8_t datalog_en);
void print_sumofcells(void);
void check_mux_fail(void);
void print_selftest_errors(uint8_t adc_reg, int8_t error);
void print_overlap_results(int8_t error);
void print_digital_redundancy_errors(uint8_t adc_reg, int8_t error);
void print_open_wires(void);
void print_pec_error_count(void);
int8_t select_s_pin(void);
int8_t select_ic(void);
void print_wrpwm(void);
void print_rxpwm(void);
void print_wrsctrl(void);
void print_rxsctrl(void);
void print_wrpsb(uint8_t type);
void print_rxpsb(uint8_t type);
void print_wrcomm(void);
void print_rxcomm(void);
void check_mute_bit(void);
void print_conv_time(uint32_t conv_time);
void check_error(int error);
void serial_print_text(char data[]);
void serial_print_hex(uint8_t data);
char read_hex(void);
char get_char(void);
  Setup Variables
  The following variables can be modified to configure the software.
const uint8_t TOTAL_IC = 1; //!< Number of ICs in the daisy chain
 ADC Command Configurations. See LTC681x.h for options
const uint8_t ADC_OPT = ADC_OPT_DISABLED;         //!< ADC Mode option bit
const uint8_t ADC_CONVERSION_MODE = MD_7KHZ_3KHZ; //!< ADC Mode
const uint8_t ADC_DCP = DCP_DISABLED;             //!< Discharge Permitted
const uint8_t CELL_CH_TO_CONVERT = CELL_CH_ALL;   //!< Channel Selection for ADC conversion
const uint8_t AUX_CH_TO_CONVERT = AUX_CH_ALL;     //!< Channel Selection for ADC conversion
const uint8_t STAT_CH_TO_CONVERT = STAT_CH_ALL;   //!< Channel Selection for ADC conversion
const uint8_t SEL_ALL_REG = REG_ALL;              //!< Register Selection
const uint8_t SEL_REG_A = REG_1;                  //!< Register Selection
const uint8_t SEL_REG_B = REG_2;                  //!< Register Selection
const uint16_t MEASUREMENT_LOOP_TIME = 500;       //!< Loop Time in milliseconds(ms)
//Under Voltage and Over Voltage Thresholds
const uint16_t OV_THRESHOLD = 41000; //!< Over voltage threshold ADC Code. LSB = 0.0001 ---(4.1V)
const uint16_t UV_THRESHOLD = 30000; //!< Under voltage threshold ADC Code. LSB = 0.0001 ---(3V)
//Loop Measurement Setup. These Variables are ENABLED or DISABLED. Remember ALL CAPS
const uint8_t WRITE_CONFIG = DISABLED; //!< This is to ENABLED or DISABLED writing into to configuration registers in a continuous loop
const uint8_t READ_CONFIG = DISABLED;  //!< This is to ENABLED or DISABLED reading the configuration registers in a continuous loop
const uint8_t MEASURE_CELL = ENABLED;  //!< This is to ENABLED or DISABLED measuring the cell voltages in a continuous loop
const uint8_t MEASURE_AUX = DISABLED;  //!< This is to ENABLED or DISABLED reading the auxiliary registers in a continuous loop
const uint8_t MEASURE_STAT = DISABLED; //!< This is to ENABLED or DISABLED reading the status registers in a continuous loop
const uint8_t PRINT_PEC = DISABLED;    //!< This is to ENABLED or DISABLED printing the PEC Error Count in a continuous loop
  END SETUP
 Global Battery Variables received from 681x commands
 These variables store the results from the LTC6813
 register reads and the array lengths must be based
 on the number of ICs on the stack
cell_asic BMS_IC[TOTAL_IC]; //!< Global Battery Variable
//cell_asic BMS_compare[TOTAL_IC]; // Copy the BMS_IC to make the sorting
 Set configuration register. Refer to the data sheet
bool REFON = true;        //!< Reference Powered Up Bit
bool ADCOPT = false;        //!< ADC Mode option bit
bool GPIOBITS_A[5] = {false, false, true, true, true};                                                     //!< GPIO Pin Control // Gpio 1,2,3,4,5
bool GPIOBITS_B[4] = {false, false, false, false};                                                         //!< GPIO Pin Control // Gpio 6,7,8,9
uint16_t UV = UV_THRESHOLD;        //!< Under voltage Comparison Voltage
uint16_t OV = OV_THRESHOLD;        //!< Over voltage Comparison Voltage
bool DCCBITS_A[12] = {false, false, false, false, false, false, false, false, false, false, false, false}; //!< Discharge cell switch //Dcc 1,2,3,4,5,6,7,8,9,10,11,12
bool DCCBITS_B[7] = {false, false, false, false, false, false, false};                                     //!< Discharge cell switch //Dcc 0,13,14,15
bool DCTOBITS[4] = {true, false, true, false};                                                             //!< Discharge time value //Dcto 0,1,2,3  // Programed for 4 min
/*Ensure that Dcto bits are set according to the required discharge time. Refer to the data sheet */
bool FDRF = false;               //!< Force Digital Redundancy Failure Bit
bool DTMEN = true;               //!< Enable Discharge Timer Monitor
bool PSBITS[2] = {false, false}; //!< Digital Redundancy Path Selection//ps-0,1
 \brief  Initializes hardware and variables
  @return void
unsigned long statPrintInterval = 2000;  // 2 saniye
unsigned long updateVolInterval = 500;   // 0.5 saniye
unsigned long previousStatPrintMillis = 0;
unsigned long previousUpdateVolMillis = 0;
/*Customize Global Variable*********************************************/
bool start_discharge = false;
bool start_balance = false;
bool discharge_stat[TOTAL_IC][18] = {false};
int num_of_finish = 0;
double vmin[TOTAL_IC];
double vmax[TOTAL_IC];
double consvmax[TOTAL_IC] = {0};
double consvmin[TOTAL_IC];
double avgvol[TOTAL_IC];
double sumvol[TOTAL_IC];
bool shutdown_status = true;
  quikeval_SPI_connect();
  spi_enable(SPI_CLOCK_DIV16); // Bu, Linduino'yu 1MHz Saatle ayarlayacaktır
  LTC6813_init_cfg(TOTAL_IC, BMS_IC);
  LTC6813_init_cfgb(TOTAL_IC, BMS_IC);
  for (uint8_t current_ic = 0; current_ic < TOTAL_IC; current_ic++)
    LTC6813_set_cfgr(current_ic, BMS_IC, REFON, ADCOPT, GPIOBITS_A, DCCBITS_A, DCTOBITS, UV, OV);
    LTC6813_set_cfgrb(current_ic, BMS_IC, FDRF, DTMEN, PSBITS, GPIOBITS_B, DCCBITS_B);
  LTC6813_reset_crc_count(TOTAL_IC, BMS_IC);
  LTC6813_init_reg_limits(TOTAL_IC, BMS_IC);
  print_menu();
  for (int i = 0; i < 18; i++)
    vmin[i] = 5;
    consvmax[i] = 5;
  //clear all discharge
  wakeup_sleep(TOTAL_IC);
  LTC6813_clear_discharge(TOTAL_IC, BMS_IC);
  LTC6813_wrcfg(TOTAL_IC, BMS_IC);
  LTC6813_wrcfgb(TOTAL_IC, BMS_IC);
  pinMode(13, OUTPUT);
/**********************************Start of Customize Function*******************************/
void voltage_update()
  int8_t error = 0;
  LTC6813_adcv(ADC_CONVERSION_MODE, ADC_DCP, CELL_CH_TO_CONVERT);
  error = LTC6813_rdcv(SEL_ALL_REG, TOTAL_IC, BMS_IC); // Set to read back all cell voltage registers
  check_error(error);
  for (int j = 0; j < TOTAL_IC; j++)
    vmin[j] = 5;
    vmax[j] = 0;
    avgvol[j] = 0;
    sumvol[j] = 0;
    for (int i = 0; i < BMS_IC[0].ic_reg.cell_channels; i++)
      sumvol[j] += BMS_IC[j].cells.c_codes[i] * 0.0001;
      vmin[j] = min(vmin[j], BMS_IC[j].cells.c_codes[i] * 0.0001);
      vmax[j] = max(vmax[j], BMS_IC[j].cells.c_codes[i] * 0.0001);
    avgvol[j] = sumvol[j] / 18;
  Maximum();
  Minimum();
void starttowork()
  run_command(92);
  Serial.println();
  Serial.println();
  for (int current_ic = 0; current_ic < TOTAL_IC; current_ic++)
    Serial.print(F("Sum voltage of IC "));
    Serial.print(current_ic + 1);
    Serial.print(F(" : "));
    Serial.print(sumvol[current_ic], 4);
    Serial.print(F("   "));
    Serial.print(F("Average voltage of IC "));
    Serial.println(avgvol[current_ic], 4);
    Serial.print(F("MAX difference Voltage_"));
    Serial.print(F("IC "));
    Serial.print(vmax[current_ic] - vmin[current_ic], 4);
    Serial.print(F("Highest Voltage:"));
    Serial.print(vmax[current_ic], 4);
    Serial.print(F("Lowest Voltage:"));
    Serial.println(vmin[current_ic], 4);
  print_cells(DATALOG_DISABLED);
  if (start_balance)
    battery_charge_balance();
  if (start_discharge)
    moniV();
    Serial.println(F("Discharging!!!!!!!"));
void moniV()
  uint32_t conv_time = 0;
  int8_t error = 0;
  bool finish = true;
  conv_time = LTC6813_pollAdc();
  check_error(error); // Check error to enable the function
  Serial.println(F("Discharging Status :"));
    Serial.print("  ");
      if (BMS_IC[current_ic].cells.c_codes[i] * 0.0001 < consvmin[current_ic])
        LTC6813_clear_custom2_discharge(i + 1, current_ic, TOTAL_IC, BMS_IC);
        discharge_stat[current_ic][i] = false;
      finish = finish && !(discharge_stat[current_ic][i]);
      Serial.print("C");
      Serial.print(i);
      Serial.print(":");
      Serial.print(discharge_stat[current_ic][i]);
      Serial.print(" ");
    Serial.println();
  if (finish)
    Serial.println(F("!!!!!!!!!!!!!!!!!!!Discharge finished!!!!!!!!!!!!!!!!!!!!!"));
void battery_charge_balance()
  int8_t error = 0;
  double charge_buffer = 0;
  int light;
  run_command('AOV');
    light = 0;
    charge_buffer = 0;
      if (light > 2)
        charge_buffer = 0.05;
      if (BMS_IC[current_ic].cells.c_codes[i] * 0.0001 > BMS_IC[current_ic].stat.stat_codes[0] * 0.0001 * 30 / 18 + 0.05 + charge_buffer)
        light = light + 1;
        LTC6813_set_custom_discharge(i + 1, current_ic, TOTAL_IC, BMS_IC);
      else
void Maximum()
    if (vmax[current_ic] > 3.73)
      Serial.println(F("Over Voltage > 3.73 !"));
      shutdown_status = false;
void Minimum()
    if (vmin[current_ic] < 0)
      Serial.println(F("Under Voltage < 0 !"));
/***************************************End of Customize Function****************************/
  \brief Main loop
   @return void
  unsigned long currentMillis = millis();
  if (Serial.available()) // Check for user input
    uint32_t user_command;
    user_command = read_int(); // Read the user command
    if (user_command == 'm')
      print_menu();
    else
      Serial.println(user_command);
      run_command(user_command);
  // Zamanlayıcı güncellemeleri
  if (currentMillis - previousStatPrintMillis >= statPrintInterval)
    previousStatPrintMillis = currentMillis;
    starttowork();
  if (currentMillis - previousUpdateVolMillis >= updateVolInterval)
    previousUpdateVolMillis = currentMillis;
    voltage_update();
  if (shutdown_status)
    digitalWrite(13, HIGH);
  else
    digitalWrite(13, LOW);
  \brief executes the user command
    @return void
void run_command(uint32_t cmd)
  uint8_t streg = 0;
  int8_t error = 0;
  int8_t s_pin_read = 0;
  int8_t s_ic = 0;
  switch (cmd)
  case 1: // Write and read Configuration Register
    LTC6813_wrcfg(TOTAL_IC, BMS_IC);  // Write into Configuration Register
    LTC6813_wrcfgb(TOTAL_IC, BMS_IC); // Write into Configuration Register B
    print_wrconfig();
    print_wrconfigb();
    wakeup_idle(TOTAL_IC);
    error = LTC6813_rdcfg(TOTAL_IC, BMS_IC); // Read Configuration Register
    check_error(error);
    error = LTC6813_rdcfgb(TOTAL_IC, BMS_IC); // Read Configuration Register B
    check_error(error);
    print_rxconfig();
    print_rxconfigb();
    break;
  case 2: // Read Configuration Register
    check_error(error);
    check_error(error);
    print_rxconfig();
    print_rxconfigb();
    break;
  case 3: // Start Cell ADC Measurement
    //print_conv_time(conv_time);
    break;
  case 4: // Read Cell Voltage Registers
    check_error(error);
    //print_cells(DATALOG_DISABLED);
    break;
  case 23: // Enable a discharge transistor
    s_pin_read = select_s_pin();
    LTC6813_set_discharge(s_pin_read, TOTAL_IC, BMS_IC);
    print_wrconfig();
    print_wrconfigb();
    check_error(error);
    check_error(error);
    print_rxconfig();
    print_rxconfigb();
    break;
  case 'm': //prints menu
    print_menu();
    break;
  case 'AOV': //Start Combined Cell Voltage and Sum of cells
    LTC6813_adcvsc(ADC_CONVERSION_MODE, ADC_DCP);
    check_error(error);
    error = LTC6813_rdstat(SEL_REG_A, TOTAL_IC, BMS_IC); // Set to read back stat register A
    check_error(error);
    //print_avgofvoltage();
    break;
  case 86: //start discharge to the lowest voltage of all cells and ICs
    check_error(error);                                  //Check error to enable the function
    for (int i = 0; i < TOTAL_IC; i++)
      consvmin[i] = vmin[i];
    //Serial.println(consvmin[current_ic], 4);
        if (BMS_IC[current_ic].cells.c_codes[i] * 0.0001 > consvmin[current_ic])
          discharge_stat[current_ic][i] = true;
    start_discharge = true;
    Serial.println(F("start discharge"));
    break;
  case 87: //charge balance
    Serial.println(F("Ha Ha !!"));
    check_error(error);
    start_balance = true;
    Serial.println(F("start balance !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!"));
    break;
  case 88:
    Serial.println(F("Stop !!"));
    check_error(error);
    Serial.println(F("Stop balance !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!"));
    break;
  case 89: //clear discharge of seleted cell of all ICs
    LTC6813_clear_custom_discharge(s_pin_read, TOTAL_IC, BMS_IC);
    //print_wrconfig();
    //print_wrconfigb();
    check_error(error);
    check_error(error);
    //print_rxconfig();
    //print_rxconfigb();
    break;
  case 90: //clear discharge of seleted cell of selected ICs
    Serial.println("Clear Discharge !!");
    s_ic = select_ic() - 1;
    LTC6813_clear_custom2_discharge(s_pin_read, s_ic, TOTAL_IC, BMS_IC);
    //print_wrconfig();
    check_error(error);
    check_error(error);
    //print_rxconfig();
    break;
  case 91: //set discharge of seleted cell of selected ICs
    Serial.println(F("Set Discharge !!"));
    LTC6813_set_custom_discharge(s_pin_read, s_ic, TOTAL_IC, BMS_IC);
    //print_wrconfig();
    check_error(error);
    check_error(error);
    //print_rxconfig();
    break;
  case 92: //calculate minimal and maxium
    //conv_time = LTC6813_pollAdc();
    check_error(error);
      vmin[j] = 5;
      vmax[j] = 0;
        vmin[j] > BMS_IC[j].cells.c_codes[i] * 0.0001 ? vmin[j] = BMS_IC[j].cells.c_codes[i] * 0.0001 : 1;
        vmax[j] < BMS_IC[j].cells.c_codes[i] * 0.0001 ? vmax[j] = BMS_IC[j].cells.c_codes[i] * 0.0001 : 1;
      Serial.print(F("min : "));
      Serial.print(vmin[j], 4);
      Serial.print(F("  max : "));
      Serial.println(vmax[j], 4);
    break;
  default:
    char str_error[] = "Incorrect Option \n";
    serial_print_text(str_error);
    break;
 \brief For writing/reading configuration data or measuring cell voltages or reading aux register or reading status register in a continuous loop
 @return void
  int8_t error = 0;
  char input = 0;
  Serial.println(F("Transmit 'm' to quit"));
  while (input != 'm')
    if (Serial.available() > 0)
      input = read_char();
    if (WRITE_CONFIG == ENABLED)
      print_wrconfig();
      print_wrconfigb();
    if (READ_CONFIG == ENABLED)
      check_error(error);
      check_error(error);
      print_rxconfig();
      print_rxconfigb();
    if (MEASURE_CELL == ENABLED)
      LTC6813_pollAdc();
      error = LTC6813_rdcv(0, TOTAL_IC, BMS_IC);
      check_error(error);
      print_cells(datalog_en);
    if (MEASURE_AUX == ENABLED)
      LTC6813_adax(ADC_CONVERSION_MODE, AUX_CH_ALL);
      LTC6813_pollAdc();
      error = LTC6813_rdaux(0, TOTAL_IC, BMS_IC); // Set to read back all aux registers
      check_error(error);
      print_aux(datalog_en);
    if (MEASURE_STAT == ENABLED)
      LTC6813_adstat(ADC_CONVERSION_MODE, STAT_CH_ALL);
      LTC6813_pollAdc();
      error = LTC6813_rdstat(0, TOTAL_IC, BMS_IC); // Set to read back all aux registers
      check_error(error);
      print_stat();
    if (PRINT_PEC == ENABLED)
      print_pec_error_count();
    delay(MEASUREMENT_LOOP_TIME);
  \brief Prints the main menu
  @return void
  Serial.println(F("List of LTC6813 Command:"));
  Serial.println(F("Write and Read Configuration: 1                            |Loop measurements with data-log output : 12                            |Set Discharge: 23   "));
  Serial.println(F("Read Configuration: 2                                      |Clear Registers: 13                                                    |Clear Discharge: 24   "));
  Serial.println(F("Start Cell Voltage Conversion: 3                           |Run Mux Self Test: 14                                                  |Write and Read of PWM : 25"));
  Serial.println(F("Read Cell Voltages: 4                                      |Run ADC Self Test: 15                                                  |Write and  Read of S control : 26"));
  Serial.println(F("Start Aux Voltage Conversion: 5                            |ADC overlap Test : 16                                                  |Clear S control register : 27"));
  Serial.println(F("Read Aux Voltages: 6                                       |Run Digital Redundancy Test: 17                                        |SPI Communication  : 28"));
  Serial.println(F("Start Stat Voltage Conversion: 7                           |Open Wire Test for single cell detection: 18                           |I2C Communication Write to Slave :29"));
  Serial.println(F("Read Stat Voltages: 8                                      |Open Wire Test for multiple cell or two consecutive cells detection:19 |I2C Communication Read from Slave :30"));
  Serial.println(F("Start Combined Cell Voltage and GPIO1, GPIO2 Conversion: 9 |Open wire for Auxiliary Measurement: 20                                |Enable MUTE : 31"));
  Serial.println(F("Start  Cell Voltage and Sum of cells : 10                  |Print PEC Counter: 21                                                  |Disable MUTE : 32"));
  Serial.println(F("Loop Measurements: 11                                      |Reset PEC Counter: 22                                                  |Set or reset the gpio pins: 33 \n "));
  Serial.println(F("Print 'm' for menu"));
  Serial.println(F("Please enter command: \n "));
 \brief Prints the configuration data that is going to be written to the LTC6813
 to the serial port.
 @return void
  int cfg_pec;
  Serial.println(F("Written Configuration A Register: "));
    Serial.print(F("CFGA IC "));
    Serial.print(current_ic + 1, DEC);
    for (int i = 0; i < 6; i++)
      Serial.print(F(", 0x"));
      serial_print_hex(BMS_IC[current_ic].config.tx_data[i]);
    Serial.print(F(", Calculated PEC: 0x"));
    cfg_pec = pec15_calc(6, &BMS_IC[current_ic].config.tx_data[0]);
    serial_print_hex((uint8_t)(cfg_pec >> 8));
    serial_print_hex((uint8_t)(cfg_pec));
    Serial.println("\n");
 \brief Prints the Configuration Register B data that is going to be written to
 the LTC6813 to the serial port.
  @return void
  int cfg_pec;
  Serial.println(F("Written Configuration B Register: "));
    Serial.print(F("CFGB IC "));
      serial_print_hex(BMS_IC[current_ic].configb.tx_data[i]);
    cfg_pec = pec15_calc(6, &BMS_IC[current_ic].configb.tx_data[0]);
 \brief Prints the configuration data that was read back from the
 @return void
  Serial.println(F("Received Configuration A Register: "));
      serial_print_hex(BMS_IC[current_ic].config.rx_data[i]);
    Serial.print(F(", Received PEC: 0x"));
    serial_print_hex(BMS_IC[current_ic].config.rx_data[6]);
    serial_print_hex(BMS_IC[current_ic].config.rx_data[7]);
 \brief Prints the Configuration Register B that was read back from
  @return void
  Serial.println(F("Received Configuration B Register: "));
      serial_print_hex(BMS_IC[current_ic].configb.rx_data[i]);
    serial_print_hex(BMS_IC[current_ic].configb.rx_data[6]);
    serial_print_hex(BMS_IC[current_ic].configb.rx_data[7]);
  \brief Prints cell voltage codes to the serial port
  @return void
    if (datalog_en == 0)
      Serial.print("IC ");
      Serial.print(",");
        Serial.print(" C");
        Serial.print(i + 1, DEC);
        Serial.print(":");
        Serial.print(BMS_IC[current_ic].cells.c_codes[i] * 0.0001, 4);
        Serial.print(",");
      Serial.println();
    else
      Serial.print(F(" Cells, "));
        Serial.print(F(","));
  \brief Prints GPIO voltage codes and Vref2 voltage code onto the serial port
  @return void
      Serial.print(" IC ");
      for (int i = 0; i < 5; i++)
        Serial.print(F(" GPIO-"));
        Serial.print(":");
        Serial.print(BMS_IC[current_ic].aux.a_codes[i] * 0.0001, 4);
        Serial.print(",");
      for (int i = 6; i < 10; i++)
        Serial.print(i, DEC);
        Serial.print(":");
      Serial.print(F(" Vref2"));
      Serial.print(":");
      Serial.print(BMS_IC[current_ic].aux.a_codes[5] * 0.0001, 4);
      Serial.println();
      Serial.print(" OV/UV Flags : 0x");
      Serial.print((uint8_t)BMS_IC[current_ic].aux.a_codes[11], HEX);
      Serial.println();
    else
      Serial.print(" AUX, ");
      for (int i = 0; i < 12; i++)
        Serial.print((uint8_t)BMS_IC[current_ic].aux.a_codes[i] * 0.0001, 4);
        Serial.print(",");
  \brief Prints Status voltage codes and Vref2 voltage code onto the serial port
  @return void
    double itmp;
    Serial.print(F(" IC "));
    Serial.print(F(" SOC:"));
    Serial.print(BMS_IC[current_ic].stat.stat_codes[0] * 0.0001 * 30, 4);
    Serial.print(F(" Itemp:"));
    itmp = (double)((BMS_IC[current_ic].stat.stat_codes[1] * (0.0001 / 0.0076)) - 276); //Internal Die Temperature(°C) = ITMP • (100 µV / 7.6mV)°C - 276°C
    Serial.print(itmp, 4);
    Serial.print(F(" VregA:"));
    Serial.print(BMS_IC[current_ic].stat.stat_codes[2] * 0.0001, 4);
    Serial.print(F(" VregD:"));
    Serial.print(BMS_IC[current_ic].stat.stat_codes[3] * 0.0001, 4);
    Serial.println();
    Serial.print(F(" OV/UV Flags:"));
    serial_print_hex(BMS_IC[current_ic].stat.flags[0]);
    serial_print_hex(BMS_IC[current_ic].stat.flags[1]);
    serial_print_hex(BMS_IC[current_ic].stat.flags[2]);
    Serial.print(F("\tMux fail flag:"));
    serial_print_hex(BMS_IC[current_ic].stat.mux_fail[0]);
    Serial.print(F("\tTHSD:"));
    serial_print_hex(BMS_IC[current_ic].stat.thsd[0]);
    Serial.println();
  \brief Prints GPIO voltage codes (GPIO 1 & 2)
  @return void
      for (int i = 0; i < 2; i++)
        Serial.print(F(":"));
    else
      Serial.print(F("AUX, "));
  \brief Prints Status voltage codes for SOC onto the serial port6
void print_avgofvoltage(void)
    Serial.print(F(" AOV:"));
    Serial.print(BMS_IC[current_ic].stat.stat_codes[0] * 0.0001 * 30 / 18, 4);
  \brief Function to check the MUX fail bit in the Status Register
   @return void
  int8_t error = 0;
  for (int ic = 0; ic < TOTAL_IC; ic++)
    Serial.println(ic + 1, DEC);
    if (BMS_IC[ic].stat.mux_fail[0] != 0)
      error++;
    if (error == 0)
      Serial.println(F("Mux Test: PASS \n"));
    else
      Serial.println(F("Mux Test: FAIL \n"));
  \brief Prints Errors Detected during self test
   @return void
  if (adc_reg == 1)
    Serial.println("Cell ");
  else if (adc_reg == 2)
    Serial.println("Aux ");
  else if (adc_reg == 3)
    Serial.println("Stat ");
  Serial.print(error, DEC);
  Serial.println(F(" : errors detected in Digital Filter and Memory \n"));
  \brief Prints the output of  the ADC overlap test
   @return void
  if (error == 0)
    Serial.println(F("Overlap Test: PASS \n"));
  else
    Serial.println(F("Overlap Test: FAIL \n"));
  \brief Prints Errors Detected during Digital Redundancy test
   @return void
  if (adc_reg == 2)
  Serial.println(F(" : errors detected in Measurement \n"));
  \brief Prints Open wire test results to the serial port
    if (BMS_IC[current_ic].system_open_wire == 65535)
      Serial.print("No Opens Detected on IC ");
      Serial.println();
    else
      Serial.print(F("There is an open wire on IC "));
      Serial.print(F(" Channel: "));
      Serial.println(BMS_IC[current_ic].system_open_wire);
   \brief Function to print the number of PEC Errors
   @return void
    Serial.println("");
    Serial.print(BMS_IC[current_ic].crc_count.pec_count, DEC);
    Serial.print(F(" : PEC Errors Detected on IC"));
    Serial.println(current_ic + 1, DEC);
  \brief Function to select the S pin for discharge
  @return void
  int8_t read_s_pin = 0;
  Serial.print(F("Please enter the Spin number: "));
  read_s_pin = (int8_t)read_int();
  Serial.println(read_s_pin);
  return (read_s_pin);
  \brief Function to select the IC for discharge
  @return void
  int8_t read_s_ic = 0;
  Serial.print(F("Please enter the ic number: "));
  read_s_ic = (int8_t)read_int();
  Serial.println(read_s_ic);
  return (read_s_ic);
  \brief prints data which is written on PWM register onto the serial port
  @return void
  int pwm_pec;
  Serial.println(F("Written PWM Configuration: "));
      serial_print_hex(BMS_IC[current_ic].pwm.tx_data[i]);
    pwm_pec = pec15_calc(6, &BMS_IC[current_ic].pwm.tx_data[0]);
    serial_print_hex((uint8_t)(pwm_pec >> 8));
    serial_print_hex((uint8_t)(pwm_pec));
  \brief Prints received data from PWM register onto the serial port
  @return void
  Serial.println(F("Received pwm Configuration:"));
      serial_print_hex(BMS_IC[current_ic].pwm.rx_data[i]);
    serial_print_hex(BMS_IC[current_ic].pwm.rx_data[6]);
    serial_print_hex(BMS_IC[current_ic].pwm.rx_data[7]);
  \brief prints data which is written on S Control register
  @return void
  int sctrl_pec;
  Serial.println(F("Written Data in Sctrl register: "));
    Serial.print(F(" IC: "));
    Serial.print(F(" Sctrl register group:"));
      serial_print_hex(BMS_IC[current_ic].sctrl.tx_data[i]);
    sctrl_pec = pec15_calc(6, &BMS_IC[current_ic].sctrl.tx_data[0]);
    serial_print_hex((uint8_t)(sctrl_pec >> 8));
    serial_print_hex((uint8_t)(sctrl_pec));
  \brief prints data which is read back from S Control register
  @return void
  Serial.println(F("Received Data:"));
      serial_print_hex(BMS_IC[current_ic].sctrl.rx_data[i]);
    serial_print_hex(BMS_IC[current_ic].sctrl.rx_data[6]);
    serial_print_hex(BMS_IC[current_ic].sctrl.rx_data[7]);
  \brief Prints data which is written on PWM/S control register group B onto
  the serial port
   @return void
  int psb_pec = 0;
  Serial.println(F(" PWM/S control register group B: "));
    if (type == 1)
      Serial.print(F(" 0x"));
      serial_print_hex(BMS_IC[current_ic].pwmb.tx_data[0]);
      serial_print_hex(BMS_IC[current_ic].pwmb.tx_data[1]);
      serial_print_hex(BMS_IC[current_ic].pwmb.tx_data[2]);
      psb_pec = pec15_calc(6, &BMS_IC[current_ic].pwmb.tx_data[0]);
      serial_print_hex((uint8_t)(psb_pec >> 8));
      serial_print_hex((uint8_t)(psb_pec));
    else if (type == 2)
      serial_print_hex(BMS_IC[current_ic].sctrlb.tx_data[3]);
      serial_print_hex(BMS_IC[current_ic].sctrlb.tx_data[4]);
      serial_print_hex(BMS_IC[current_ic].sctrlb.tx_data[5]);
      psb_pec = pec15_calc(6, &BMS_IC[current_ic].sctrlb.tx_data[0]);
  \brief Prints received data from PWM/S control register group B
   @return void
  Serial.println(F(" PWM/S control register group B:"));
  if (type == 1)
      serial_print_hex(BMS_IC[current_ic].pwmb.rx_data[0]);
      serial_print_hex(BMS_IC[current_ic].pwmb.rx_data[1]);
      serial_print_hex(BMS_IC[current_ic].pwmb.rx_data[2]);
      serial_print_hex(BMS_IC[current_ic].pwmb.rx_data[6]);
      serial_print_hex(BMS_IC[current_ic].pwmb.rx_data[7]);
  else if (type == 2)
      serial_print_hex(BMS_IC[current_ic].sctrlb.rx_data[3]);
      serial_print_hex(BMS_IC[current_ic].sctrlb.rx_data[4]);
      serial_print_hex(BMS_IC[current_ic].sctrlb.rx_data[5]);
      serial_print_hex(BMS_IC[current_ic].sctrlb.rx_data[6]);
      serial_print_hex(BMS_IC[current_ic].sctrlb.rx_data[7]);
  \brief prints data which is written on COMM register onto the serial port
  @return void
  int comm_pec;
  Serial.println(F("Written Data in COMM Register: "));
    Serial.print(F(" IC- "));
      serial_print_hex(BMS_IC[current_ic].com.tx_data[i]);
    comm_pec = pec15_calc(6, &BMS_IC[current_ic].com.tx_data[0]);
    serial_print_hex((uint8_t)(comm_pec >> 8));
    serial_print_hex((uint8_t)(comm_pec));
  \brief Prints received data from COMM register onto the serial port
  @return void
  Serial.println(F("Received Data in COMM register:"));
      serial_print_hex(BMS_IC[current_ic].com.rx_data[i]);
    serial_print_hex(BMS_IC[current_ic].com.rx_data[6]);
    serial_print_hex(BMS_IC[current_ic].com.rx_data[7]);
  \brief Function to check the Mute bit in the Configuration Register
   @return void
    Serial.print(F(" Mute bit in Configuration Register B: 0x"));
    serial_print_hex((BMS_IC[current_ic].configb.rx_data[1]) & (0x80));
  \brief Function to print the Conversion Time
  @return void
  uint16_t m_factor = 1000; // to print in ms
  Serial.print(F("Conversion completed in:"));
  Serial.print(((float)conv_time / m_factor), 1);
  Serial.println(F("ms \n"));
  \brief Function to check error flag and print PEC error message
  @return void
  if (error == -1)
    Serial.println(F("A PEC error was detected in the received data"));
  \brief Function to print text on serial monitor
  @return void
  Serial.println(data);
   \brief Function to print in HEX form
   @return void
  if (data < 16)
    Serial.print("0");
    Serial.print((byte)data, HEX);
  else
 \brief Hex conversion constants
char hex_digits[16] =
        '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E', 'F'};
 \brief Global Variables
char hex_to_byte_buffer[5] =
        '0', 'x', '0', '0', '\0'};
 \brief Buffer for ASCII hex to byte conversion
char byte_to_hex_buffer[3] =
        '\0', '\0', '\0'};
 \brief Read 2 hex characters from the serial buffer and convert them to a byte
 @return char data Read Data
char read_hex(void)
  byte data;
  hex_to_byte_buffer[2] = get_char();
  hex_to_byte_buffer[3] = get_char();
  get_char();
  get_char();
  data = strtol(hex_to_byte_buffer, NULL, 0);
  return (data);
 \brief Read a command from the serial port
 @return char
char get_char(void)
  // read a command from the serial port
  while (Serial.available() <= 0)
  return (Serial.read());
some data sheet info
https://www.analog.com/en/products/ltc6 ... umentation
https://www.analog.com/media/en/technic ... 6813-1.pdf
based on the codes you used a library there
apparently, LTC6813 communicates over SPI if I'm correct about it
in that case you have a dependency on the SPI library shipped with stm32duino core
https://github.com/stm32duino/Arduino_C ... ki/API#spi
https://github.com/stm32duino/Arduino_C ... raries/SPI
my guess is it may help to make a simpler sketch
just to test SPI with your sensor/device
e.g. to read some registers to see if they are after all correct.
