Board is generic from vcc-gnd.taobao.com.
MCU is STM32F103RCT6
Flashed bootloader on MCU using ST flash loader demonstrator and usb-serial converter with CH340G, used Global Erase option.
Used bootloader generic_boot20_pc13.bin
Installed the drivers by running the install_drivers.bat
Now when I plug the USB cable into the board, I see in Device Manager under Ports a so called "Maple Serial (Com5)".
When I go in Arduino and select Port: Com5 Maple Mini, and then click on Get board info, I get:
"BN: Maple Mini
VID: 0x1EAF
PID: 0x0004
SN: Upload any sketch to obtain it"
If I open Arduino Serial Monitor with 9600 Baud, I get:
"Congratulations, you have installed the STM32duino bootloader
See https://github.com/rogerclarkmelbourne/ ... bootloader
For more information about Arduino on STM32
See https://www.stm32duino.com"
When I try to upload a basic sketch via the stm32duino bootloader I get:
"maple_loader v0.1
Couldn't find the DFU device: [1EAF:0003]"
At this point, the LED flashes, and in Device Manager, STM Serial(COM 4) appears with an exclamation mark.
"This device cannot start. (Code 10)
A device which does not exist was specified."
Also the port is no longer available for Serial Monitor.
What am I doing wrong?
P.S. I checked and the board has a 1.5kohm pull-up on A12.
P.S. The board has a solder jumper for pulling boot1 up.
Soldered the jumper and connected the board to the PC.
Now all I get in device manager is the STM Serial (Com4) with the exclamation mark and the The device cannot start error, and the board's LED flashing.
Unable to upload sketch via stm32duino bootloader method
- Contact:
Re: Unable to upload sketch via stm32duino bootloader method
When you see in the Arduino message window
then press the reset buton.
