Servo Library using HardwareTimer
What are you developing?
mpetrasinovic
Post by mpetrasinovic »
Hi all,
My name is Miloš Petrašinović and I am part of the Aerospace Engineering Department at the University of Belgrade and Aerospace Company called PR-DC. We often use Arduino_Core_STM32 for all kinds of research and development. We just uploaded our library for Servo motor control that uses HardwareTimer on every i/o pin to generate the PWM signal needed.
This library is available at:
https://github.com/PR-DC/PRDC_ServoHT
Last edited by mpetrasinovic on Wed Dec 29, 2021 12:19 pm, edited 1 time in total.
Re: Servo Library using HardwareTimer
Hi Miloš
Thanks for sharing.
Note that the next release will change interrupt API.
@ABOSTM would be interested by your implementation 😉
mpetrasinovic
Thank you for your reply.
fpiSTM wrote: Fri Apr 17, 2020 7:45 pm Note that the next release will change interrupt API.
I am not sure if we would need to change something because we do not use interrupt API, we just configure timer and channel.
Return to “Projects”
