STM32RTC: How to trigger an interrupt every second
forfrends
Post by forfrends »
Hello everyone!
I am using the STM32F103C8T6 board (blue pill) and kernel: "STM32 Cores by STMicroelectronycs" https://github.com/stm32duino/wiki/wiki/Getting-Started
I am using the STM32RTC library: https://github.com/stm32duino/STM32RTC
I need to call an interrupt 1 time per second. Can you give an example of how to do this? In the library there are only examples for interruption for a specific time (for example: 07:25:00). I need interruption to happen every second.
as an example, there is an RTClock library, but this library does not work on this kernel. There is a command in this library:
#include <RTClock.h>
RTClock rt (RTCSEL_LSE); // initialise
uint32 tt;
void SecondsInterrupt()       // This function is called in the attachSecondsInterrpt
    // some code
    rt.attachSecondsInterrupt(SecondsInterrupt);// Call SecondsInterrupt
Is there something similar in the STM32RTC library?
Please help me with an example.
by stas2z » Tue Apr 21, 2020 7:17 pm
forfrends wrote: Tue Apr 21, 2020 7:09 pmAn example using a timer interrupt causes a lot of errors: https://github.com/stm32duino/STM32Exam ... llback.ino
you need example shipped with core or use specific commit compatible with your core version
latest commits are for upcoming 1.9.0 core
stas2z
Answers: 8
Re: STM32RTC: How to trigger an interrupt every second
Post by stas2z »
If you need just an every second interrupt, use HardwareTimer library
fredbox
Post by fredbox »
That is the right place to start. Select API References, Hardware Timer. There are examples there.
You can also use systick which happens 1000 times per second. See viewtopic.php?p=644#p644
forfrends
Post by forfrends »
How accurate will the HardwareTimer be? If I count every second, what will be the difference with RTC?
It will be more accurate than the STM32RTC usage.
Currently, with the current STM32RTC, you could set an Alarm to match the second but you will have to reload the alarm at each interrupt.
It currently does not implement the subsecond.
forfrends wrote: Tue Apr 21, 2020 1:56 pm How accurate will the HardwareTimer be? If I count every second, what will be the difference with RTC?
The real question is, "How accurate are your needs?" Then a comparison can be made to reality.
Generic 8MHz crystals on a $2 Blue Pill are not going to be the very best quality, but will be adequate for most purposes. Were you to order a crystal, you would see numerous choices that an engineer would be presented:
Screenshot from 2020-04-21 10-43-27.png (40.92 KiB) Viewed 15967 times
As the digital clock module on the microcontroller is based on the accuracy of the crystal, the better the crystal the better the clock long-term accuracy.
stas2z
Answers: 8
Post by stas2z »
mrburnette wrote: Tue Apr 21, 2020 2:47 pm
same can be said about rtc
pill's 32.768kHz crystal is not a very precise part also
forfrends
Post by forfrends »
I do not need super high accuracy. + - 1-3 minutes a day - for me it is permissible.
I was just stuck with choosing a timing source. I need an interrupt every second. The RTClock library has such a function, but does not work on the kernel from STMicroelectronycs. The STM32RTC library runs on this core, but does not have the necessary function. An example using a timer interrupt causes a lot of errors: https://github.com/stm32duino/STM32Exam ... llback.ino
Blink:45:26: error: invalid conversion from 'void (*)()' to 'void (*)(HardwareTimer*)' [-fpermissive]
   45 |   MyTim->attachInterrupt(Update_IT_callback);
      |                          void (*)()
In file included from C:\Users\�����\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.8.0\cores\arduino/stm32/analog.h:45,
                 from C:\Users\�����\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.8.0\cores\arduino/board.h:8,
                 from C:\Users\�����\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.8.0\cores\arduino/wiring.h:41,
                 from C:\Users\�����\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.8.0\cores\arduino/Arduino.h:32,
                 from sketch\Blink.ino.cpp:1:
C:\Users\�����\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.8.0\cores\arduino/HardwareTimer.h:129:33: note:   initializing argument 1 of 'void HardwareTimer::attachInterrupt(void (*)(HardwareTimer*))'
  129 |     void attachInterrupt(void (*handler)(HardwareTimer *)); // Attach interrupt callback which will be called upon update event (timer rollover)
exit status 1
Blink:2:2: error: #error "Due to API change, this sketch is compatible with STM32_CORE_VERSION  >= 0x01090000"
    2 | #error "Due to API change, this sketch is compatible with STM32_CORE_VERSION  >= 0x01090000"
exit status 1
stas2z
Answers: 8
Post by stas2z »
forfrends
Post by forfrends »
Thanks!
I did a little test. I made a timer interrupt every second, and counted seconds, minutes, and hours. Along with starting the program, I also started a timer on the phone. After 12 hours, he verified the testimony. The timer on STM32 showed a value of 3 seconds more than on the phone. This is perfect for my device!
Thanks for the help!
