What causes the stm32 RTC to reset?
Bambo
Post by Bambo »
Hi, i have a question about the RTC library, what would cause the RTC to reset?
by fpiSTM » Wed May 20, 2020 2:02 pm
Bambo wrote: Wed May 20, 2020 11:21 am Bug report created here: https://github.com/stm32duino/STM32LowPower/issues/22
This is not a bug.
Simply wrong usage of the API. See my comment here:
https://github.com/stm32duino/STM32LowP ... -631491658
Re: What causes the stm32 RTC to reset?
No Vbat
Bambo
Post by Bambo »
Looks like when you use LowPower.shutdown() it also resets the RTC
Bambo
Post by Bambo »
It says in the documentation that the RTC doesn't reset over reboots, but when the unit reboots the RTC is reset?
See: https://github.com/stm32duino/STM32RTC at the bottom "Reset time management By default, if a time is set it will not be reset after a reboot."
Bambo
Post by Bambo »
Additionally if you use LowPower.deepSleep() the unit carries on processing, you have to use something like this:
#include <STM32RTC.h>
#include <STM32LowPower.h>
STM32RTC& rtc = STM32RTC::getInstance();
volatile bool sleeping = false;
void callback(void*data)
	sleeping = false;
	Serial.println("Callback!");
	Serial.flush();
	Serial.println("Started");
	Serial.flush();
	LowPower.begin();
	rtc.begin();
	if (!rtc.isTimeSet())
		Serial.println("Time did not persist.");
		Serial.flush();
	else
		Serial.println("Time persisted!");
		Serial.flush();
	rtc.setHours(5);
	rtc.setMinutes(5);
	rtc.setSeconds(1);
	rtc.setWeekDay(1);
	rtc.setDay(1);
	rtc.setMonth(1);
	rtc.setYear(20);
	LowPower.enableWakeupFrom(&rtc, callback);
	Serial.println("Shutting down!");
	Serial.flush();
	int epochNow = rtc.getEpoch();
	int epochEnd = epochNow + 5;
	sleeping = true;
	rtc.setAlarmEpoch(epochEnd);
	LowPower.deepSleep();
	while (sleeping)
	Serial.print("EPOCH: ");
	Serial.println(rtc.getEpoch());
	Serial.println("Done!");
	Serial.flush();
You need to set RTC source to LSE if you want it to work in shutdown mode or without power (just with RTC battery).
Bambo
Post by Bambo »
ok thank you, do you know what impact using the LSE clock for the RTC will have? does it affect TIM3 or any other timers? Thanks again.
It's just source for RTC, nothing else.
Don't know what board you're using, but with blue pills I found built-in RTC unreliable, probably due to bad quality oscillators.
Bambo
Post by Bambo »
Ok so i've added the setClockSource() to the RTC code but now it doesn't restart at all once shutdown is called? Here is the code i'm using to test it.
void callback(void* data)
	sleeping = false;
	Serial.flush();
	Serial.flush();
	LowPower.begin();
	rtc.begin();
	rtc.setClockSource(STM32RTC::LSE_CLOCK);
		Serial.flush();
	else
		Serial.flush();
	rtc.setHours(5);
	rtc.setMinutes(5);
	rtc.setSeconds(1);
	rtc.setWeekDay(1);
	rtc.setDay(1);
	rtc.setMonth(1);
	rtc.setYear(20);
	Serial.flush();
	LowPower.shutdown(1000);
	Serial.flush();
The output is
11:45:12.586 -> Started
11:45:12.722 -> Time did not persist.
11:45:12.757 -> Shutting down!
And then it doesn't start back up.
Which board? It have an LSE?
