Hi all!
Im working on a project where I am building a flight control system for a model aircraft using the stm 32.
The system is compromised of 2 parts, the flight controller (and sensors fitted to the aircraft) and a windows application (.net/c#). Part of the goal is to have a fast telemetry link between the 2 so you can see what the aircraft is doing in real time.
The telemetry link consists of simple 3DR radios that connects to the stm32 via serial and to a pc over usb connection.
My question is has anyone had any experiance with telemetry protocols over these sorts of radios? i have a large number of variables that need to be transmitted back and forth. So far ive user a system where a certain character is used to identify each variable such as P090 for a pitch of 090. The problem is that this seems to be unreliable. Anyone have any advice?
Thanks, George
Ideas for stm32 to pc comms via radio
- Ground station software.
- image.JPG (51.18 KiB) Viewed 3513 times
Re: Ideas for stm32 to pc comms via radio
Parsing is fine for IoT with JSON, or even SDF with GPS. But, parsing is a P.I.T.A. for realtime systems. I would suggest exploring binary file transfer of all variables using a structure. Here is an example/discussion of how it may be done in the Arduino world:georgesshed wrote: Mon May 18, 2020 5:46 pm ...
see Felix's reply #2
https://lowpowerlab.com/forum/moteino/d ... -(solved)/
(There are many gems on Felix's lowpowerlab site ... great rainy day reading)
Good luck,
Just as a side, if you do need to move from the Arduino to a PC for presentation, I have used JSON serial formatted (I call this faux-JSON) to USB to the PC using NodeRED. Works great,
https://www.hackster.io/rayburne/arduin ... asy-28882d
NodeRED runs fantastic on a RaspberryPi3B or 4x. Inexpensive and professional capabilities.
i think the 'simplier' ones use ppm for the control signals, i'm not familiar with them though
https://www.dronetrest.com/t/rc-radio-c ... -dsm2/1357
there are some pretty impressive open source stm32 based drones
https://github.com/betaflight/betaflight
the boards are readily available on the likes of ebay, amazon, aliexpress etc
i think even the complete drones are available
https://www.aliexpress.com/wholesale?ca ... betaflight
